Retired dozer fixer
I’ve seen off road tire guys put 4-6 large plugs into scraper tires and they held for years
Its not nearly dramatic as its made out to be. I had it happen a few months ago and it was obvious the handle was breaking before the steel even separated. It also bent. I had on gloves so not a big deal anyway plus its blunt, not sharp. I ended up clamping the rod in vise grips and finishing the job.I have a kit that came with a offroad jack I bought. Now I'm thinking it needs some metal-handle tools. Putting a steel rod through my palm is a new experience I can just skip.
I put mine in a cheap tool roll. Takes up much less space than a blow-mold case.
Hurts even more!its blunt, not sharp.
If you're really a tightwad on space, you could always loosen the allen, take the needle and reamer out of their sockets and stow them, the allen and some plug cords inside the hollow handles.I have a kit that came with a offroad jack I bought. Now I'm thinking it needs some metal-handle tools. Putting a steel rod through my palm is a new experience I can just skip.
I bought a Slime tire plug kit solely because my SIL had a thing for flat tires for a bit and I was getting phone calls for assistance. Since I bought the kit, I don't think I have gotten one call.I've used the Slime kits a few times and they've never caused issues. They've certainly saved my **** a couple times. Still running on one right now that I put in last November. The tires are almost at the end of tread life so it just needs to hold a couple more months.
That would be the Nealey plugs. They're installed a little differently, don't need glue, and IMHO they work somewhat better than the usual gummy rope worms.I remember @bwringer sharing a unique type of plug that twisted on the inside of the tire to seal the inside & out .. please refresh my memory on the brand if you see this, good sir
Is the screwdriver insert tool built well? I looked into those years ago but never pulled the trigger because I wasn't sold on the durability of the tools for truck tire applications. The strings themselves seem well made.That would be the Nealey plugs. They're installed a little differently, don't need glue, and IMHO they work somewhat better than the usual gummy rope worms.
I've installed dozens in motorcycle tires over the years, and car tires too.
When you remove the tire, you find a knot firmly stuck to the inside of the tire. It takes a substantial effort to pull it off from the inside with good pliers.
Not every puncture is pluggable, of course. Obviously tire damage has a significant random component. The only failures I've ever seen are when the puncture is too large or in the sidewall, etc. and even in these cases you can often get it to seal enough to limp home with a slow leak.
Yes, it's very strong and well-made. It's also not very large because it doesn't need to be, so not a lot of force is ever needed.Is the screwdriver insert tool built well? I looked into those years ago but never pulled the trigger because I wasn't sold on the durability of the tools for truck tire applications. The strings themselves seem well made.
Knot ? A knot of what ? Like a broken belt ?That would be the Nealey plugs. They're installed a little differently, don't need glue, and IMHO they work somewhat better than the usual gummy rope worms.
That's exactly what it looks like! I have a picture somewhere, but I can't find it.
quoting my own from last summer.I've had about 75 tires since 1986 that I've plugged and never leaked. In fact, I can't ever remember having one leak. So honestly I think all the folks that don't want you to plug a tire are just Nervous Nellies.
I generally try to use Safety seal because the tools that come in their kit are a little more sturdy, but I've used all manner of rope plugs and never had a problem with any of them.
I did not have good results from the Stop and Go tire plug kit that supposedly plugs the tire from the inside - about 50% failure rate on those.
If I'm not mistaken Discount Tire is in the business of selling tires - no surprise there. Breaking news: A furnace guy told me I needed a new furnace immediately - that was 23 years ago, and the last time his company entered my house...
