How come common metric sets only go to 19mm but common sae sets run to 1” which would be 25mm?
Nobody-named-Olli
@Nobody-named-Olli , I always wondered about this: above you mention 1/2" socket set with metric sized sockets......so the ratchet and extensions are 1/2" as expected. Was this drive size referred to as 1/2" in Europe or ? and same for 1/4", 3/8", 3/4" drives?
Was there ever a true metric sized drive in place?
I was born in ‘86 and haven’t known it any other way. The core drive systems have always been 1/4”, 3/8”, 1/2”, (…).
Some manufacturers, especially Hazet, Gedore come to mind here, do use a form of dual description in their catalogs: 6.3 and 1/4”, 10 and 3/8”, 12.5 and 1/2”, (…).
I’ve never heard anyone actually use the metric equivalents when referring to a drive system.
Certain pipes, fittings, hoses are referred to in their imperial measurements as well. It’s kind of natural/ just the way it is.
Kind regards,
Olli
f121
UK
So if you live in ”metric world” & have a no-skip 10-19 set that will do more than “Joe Average” ever needs. And again, is much more likely to add 8 & 7 to that before anything else. And maybe if “our” “Joe Average” is an avid DIYer he goes for an additional 22 for M14 connection found on tools like mixers, angle grinders, wheel barrow axles. (…)
Working on a lot of larger German sedans (a6/5 series etc), the larger sizes are necessary for suspension fasteners. I think the 21, 22, 24 get the most use, although I’m sure 23 comes out to play occasionally.
This may have changed on the newer sedans, I haven’t yet seen anything past 2018 in that category, although obviously all the SUVs have big suspension fasteners and we see a lot of them.
RobBob21
Kansas
The only large metric fasteners I have seen over here are on big European made farm equipment. Like Claas silage choppers and the new Fendt tractors I have seen popping up. I am not sure if the bigger sizes are metric or SAE still on the new domestic made equipment, the little bolts are all metric now.
mikey03
I bet they call them 12.7mm but the real question isn’t what the tool companies call them but what nickname do regular tool people use.
Nobody-named-Olli
No argument there, if you need them - you need them. My sets exceed 19 by far as well and go well below 10, but I was trying to keep it related/ specific to that very basic set a 10-19 is, as Mikey was questioning why many sets don’t come with larger sizes - unless it’s a specific set that covers more than basics. :)
you always make good posts @Nobody-named-Olli. Between you and dave you make us all look bad with your picture game 😍
but now I just got to know what this triangular tool is that looks like it has three socket ends or are they fixed
It’s a leftover tool from my childhood and was part of the tool pouch I had on my bicycles over the years. It’s a Y shaped, three way socket wrench with 3 fixed sockets: 8, 10, 12. It has lost its cushioned/plasti dip grip.
Similar tool: https://www.parktool.com/en-us/product/3-way-socket-wrench-st-3?category=General+Shop+Tools
These Y shaped three way wrenches exist in multiple configurations (hex, 1/4” drive, …) and you’ll typically find them in the bicycle aisle at a DIY/ big box store here.
Nothing to write home about, but I used it a few times as a kid and it’s one of the few tools that “survived” from that time. It’s earned it’s keep and sits in the toolbox for sentimental reasons only.
Kind regards,
Olli
john.k
Brisbane Qld Australia
Atlas Copco tried to launch 5/8 (16mm) squar drive to replace both 1/2 and 3/4 small sizes .......socket sets ,sockets , drives,rattle guns and industrial drives ........you still see odd 5/8 tools around,especially the A/C 5/8 air impacts.
Ultradog MN
Twin Cities
When you see common sets of tools be it wrenches be it sockets be it whatnot, the metric sizes always include 10 to 19mm and the SAE sometimes stop at 3/4” which is the approximation of 19mm but more oft than not they run to 1”
So leads me to wonder what causes this and I came up with thoughts
maybe metric hardware uses smaller head to body ratio so a metric bolt with a 19mm head is about the same diameter bolt as a 1” sae head. I doubt this but it’s easy to confirm or dispute. I’d honestly assume the same head to body ratio.
could be sae is older cars primarily and older cars used bigger hardware with bigger bolts and cars got smaller over time and used smaller bolts so a newer car only uses up to 19mm heads on most things whereas older cars might run up to 1” heads for the same components. Of course on modern cars you got fastener bigger than 19 head but I mean like for the same component like engine bay mostly caps at 19mm heads
could be because metric don’t really use 20, or 22 or 23 as oft then to run 10 to 24 as your set introduces 3 wasted sizes whereas to run in 1/16 to 1” don’t waste since all sizes are used. And 25 is closest to 1” but that’s not used either
could be tools have gotten more expensive since the old days of sae so a 10 to 19 set today costs about the same adjusted for inflation as 3/8 to 1” back in the days so its like making the bag of potato chips smaller for the same price rather than raise the price. They made the tool set smaller and honestly people don’t miss it as much they can add in singles of 21 and 24 and be good.
So anyways I know that you can buy no skip sets from 10 to 24 but is most common to see sets like 3/8” to 1” and 10mm to 19mm and I’m wondering the reason.
SAE tools work off a different metric.
Winterborne
For any professional in “metric world” 10-19 covers the most basic needs - complete no brainer to have those sizes.
Kind regards,
Olli
An excellent post laying out the three metric standards.
I wanted to add my personal experience when I was in industrial working on machinery made in Holland. All the fasteners were DIN and M5 hex head cap screws were prevalent throughout (8mm wrench/socket). You mentioned at the beginning of your post that you would add 8 before 22-24 > excellent advice. On the Holland machinery there was only one use for the 22 (mounting bolts on a high torque reduction gearbox), and none for the 24 that I recall.
If you look at McMaster-Carr, the metric hardware is DIN based as well.
steve855
PA
At one of the popular tool store websites here in Europe, the best selling metric wrench sets go up to these sizes:
  1. 24mm
  2. 32
  3. 22
  4. 24
  5. 41
  6. 32
  7. 19
  8. 22
  9. 19
  10. 34
edit - to be clear, those numbers are the largest sizes in each of the top 10 selling sets. For example, the top selling set ends at 24mm, the 2nd best seller ends at 32mm.
NoahG
Detroit, MI
Even tho 15/16” is far more useful in 1/2dr, I still get annoyed when a 3/8dr set stops at 7/8”.
I wish sets skipped 1" and included 1-1/16" instead.
Give this man an award
It's true I can't even remember the last time I used 1" either. 5/8 bolt is usually 15/16 drive size. 3/4 jumps to 1-1/8.
I have used 1” for exactly two purposes:
-The draw bolt on Greenlee knock-out punches (6pt std. chrome)
-lug nuts on a NASCAR. (6pt deep impact)
KnurledNut
n/a
Same. I have a dedicated long pattern ratcheting wrench in my set.
Greenlee includes one in some of their sets. I've handled this version and its really comfortable.
I also use 1" on K&N oil filters with the integrated nut.
  • Like
Reactions: LWB
Hohn
Diesel Central, Indiana
Yea but I’m not talking about increments I’m talking about max size of 19mm versus 1 inch as the stopping point
but your point could be there’s more mm tools since the increment size is smaller so they don’t want to sell more expensive sets of more pieces to run to 24mm
Metric sets I think in general have fewer skips. There are very few metric sizes that generally just aren’t used.
ANSI, JIS or DIN uses every metric hex size from 10-19mm (although, as mentioned, 11mm is rare and DIN-only).
Only after 19mm, you get skips in 20 and 23mm.
And anything M16 or bigger is frankly quite rare in any automotive application, so stopping at 19mm makes a lot of sense.
dnschmidt
Phoenix, AZ
The reason is not complicated. Cars have gotten smaller and so have the fasteners that hold them together. In the old days 1/2" and 9/16 inch wrenches would take apart most Chevrolets. Today 8, 10, 12, 14 and 17mm will disassemble everything on a Toyota with the occasional 24mm thrown into the mix for drain plugs on transmissions. It's called evolution.
AEAdam
SE PA
All true, but it depends on how you look at it. When you look at an ANSI, PRE ASME, PRE ISO std, there are skips, exactly like JIS, or DIN have. They are single stds and simply do not use every size.
If we had a trade embargo against Japanese cars for example, it’s very possible US tool companies would have skipped 12&14mm tools. Thinking back, pretty sure I had craftsman sets that skipped either 16, 18mm or both. They weren’t part of any stds then that anyone in the US knew about.
If you read the specs, which I’m sure @Hohn has, you find a graph where for a given steel, they graph the tensile capability versus the contact pressure under the head. As you torque the fastener, stress in the bolt stretches it between the reaction in the threads and the surface contact under the head. If the head is small, you could compress (yield) the surface under the head. Especially for a bolt clamping up aluminum. A larger head could react more load without damaging the surface it’s clamping against.
Some design philosophies, Japanese for example, want to design an engine that never ever needs service. The idea of damaging a component during service Is FAR outweighed by the cost and weight of larger headed fasteners. Note, head size doesn’t just effect the weight of the fastener, but also the component it’s attaching. The German std is the opposite.
Since it’s the thread and not the head that establishes the torque reqt, the larger German heads have the advantage of reducing stress inside the wrench or socket which makes the fastener harder to damage.
The newer ISO std found a sweet spot between the two poles, JIS having small heads, DIN having larger ones.
Not a criticism, but I sometimes get the impression people think fastener heads are chosen by random selection, or car manufacturers choose heads to make repairs more difficult. Neither is true.
mikey03
can you please explain this more? Or honestly see if I understand
Japan is saying “don’t take our engines apart, they never need servicing” and are using smaller fasteners because Smaller ones are lighter, so cheaper and better gas mileage but the trade off is smaller fasteners are more likely to break if you take the engine apart?
dnschmidt
Phoenix, AZ
I doubt that's the message. What you now find is 15 10mm bolts holding something together rather than six 9/16" bolts. This tons of little bolts rather than a couple of big ones is simply the Japanese philosophy.
AEAdam
SE PA
Kinda. Look at something like a valve cover or an oil pan. Picture a baking pan with a flange around it, drilled to mate with another surface. For any given thread size, take M8 say, the Japanese fastener head is smaller, so the counterbore for the fastener head, or the width of the flange, is closer to the sides of the pan, which makes the pan lighter, because don't have to take as much bending across the mating flange.
So why don't they just use 100 3/16" fasteners? Because of the cost of the fasteners and the time required to install them in the factory.
When you look at something like M10 thread, the German head is a 17mm while the Japanese head is 14mm. That's a pretty big difference. The ISO std compromised and used a 15 or 16mm for that sized fastener.
Really wish someone would make this chart sticky.
Not break. Just not maybe designed for tons of ins and outs. Careful torquing is required (always) to not damage the parts being bolted down.
Some of this is a bit dated, but back in the day, Japan was pushing to have spark plugs that could survive the life of the vehicle (for example). So they felt they could (and sometimes did) bury them.
German cars USED to be built to be repaired, such that they could run forever. Some German engines were extremely over designed. The old VW/AUDI 1.8L 4 cylinder was one such engine. Some were sleeved so they could be renewed cost effectively. Sad to say modern German engines are messing around with stuff like Aluma-sil and other bore coatings that can go bad and total the vehicle. And that's just the start of it. Volvo was the same or in some ways better than German cars. People, some here, collect Volvos and restore them. Like old Land Rovers.
Even interiors were once designed to come apart with actual metal fasteners. Now they are held together with near one time use plastic rivets. They were cheap and easy for the factory but not great for us.
The design philosphy is to get cars to be more like microwave ovens. It's an appliance that runs until it doesn't. Then you throw it away and get a new one. We're also moving toward cars as a common shared resource, where you are basically just renting it. Leases are like that.
Bryan/College Station, Texas
This is something that dawned on me the other day! How come we use metric sockets on a 1/4, 3/8, 1/2 designated SAE measurement?!!
only if you count "6.3 mm" as a drive size.
Olli's explanation makes the most sense.
The earliest metric socket sets on the American market only went up to 19mm - the "why" part is most likely because anything larger than that was rarely encountered by a DIY customer.
I've often wondered why some metric socket sets include every size clear up to 35-36mm - what is the application for a 31mm socket?
Same question, just in reverse. At what point does "no skips" simply become ridiculous?
  • Granco Industries NSN 5120-01-116-6047 23-pc 1.2 dr metric socket set 01.jpg
  • Granco Industries NSN 5120-01-116-6047 23-pc 1.2 dr metric socket set 02.jpg
Nobody-named-Olli
@four.cycle
As far as I know 31 is a special case. While it is not standard, it’s not that uncommon either if you work on commercial (heavy) trucks. (Probably more on our side of the big pond.)
To the best of my knowledge, and it’s been a minute since I looked that up, it’s sometimes found on steering linkages & tie rods & castle nuts of afore mentioned vehicles.
Also older commercial/heavy & military trucks use(d) that size on lug nuts & axles.
But again, this is not from personal experience - only from research quite some time ago.
Facom, KS Tools, Force, Milwaukee are all brands from which 31mm sockets are readily available today. And judging by Amazon reviews, they are being bought and used.
Kind regards,
Olli
^ Granco was an aerospace industry contract supplier. 100% government contract for NASA and Air Force. I only paid $40 bucks for that set (including shipping) - and the sockets were all brand new. Real goofy deal. Gave it to my buddy because he was lacking an 18mm socket.
Wanted to make sure he had a matching set. (y)
sparky 1971
Central Iowa
I went through my old toolbox in the wood shop last weekend. I haven't used anything in it for years but have tossed several things in it, the kinds of things that were too good of a deal not to buy even though I'll probably never use it. Among those treasures were at least four sets of standard depth 3/8" SAE sockets, both chrome and impact. Some started at 5/16, some at 3/8, but all of them topped out at 3/4. The 3/8 sets in the real shop end at 1" and 22mm but don't recall using anything larger than 3/4 and 19. As far as 1" goes, I use a 1" wrench to break oil filters loose; the gold filters have a 1" nut welded on.
^ Probably 90% of your "basic 3/8" drive SAE socket sets" will contain 7 sockets - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, and 3/4
"Extended" sets might push that out to 5/16" - 1", as Sparky's sets in his "real shop".
Metric socket sets - from the "beginning" (if we can call it that) included an odd mix: 9, 10, 11, 12, 13, 15, 17, and 19 (which in today's world makes absolutely no sense.)
WHY they stopped at 19 is really anybody's guess, but it boils down to "how many sizes actually get used by the majority?"
