Metric sets I think in general have fewer skips. There are very few metric sizes that generally just aren’t used.
ANSI, JIS or DIN uses every metric hex size from 10-19mm (although, as mentioned, 11mm is rare and DIN-only).
Only after 19mm, you get skips in 20 and 23mm.
And anything M16 or bigger is frankly quite rare in any automotive application, so stopping at 19mm makes a lot of sense.
All true, but it depends on how you look at it. When you look at an ANSI, PRE ASME, PRE ISO std, there are skips, exactly like JIS, or DIN have. They are single stds and simply do not use every size.
If we had a trade embargo against Japanese cars for example, it’s very possible US tool companies would have skipped 12&14mm tools. Thinking back, pretty sure I had craftsman sets that skipped either 16, 18mm or both. They weren’t part of any stds then that anyone in the US knew about.
If you read the specs, which I’m sure
@Hohn has, you find a graph where for a given steel, they graph the tensile capability versus the contact pressure under the head. As you torque the fastener, stress in the bolt stretches it between the reaction in the threads and the surface contact under the head. If the head is small, you could compress (yield) the surface under the head. Especially for a bolt clamping up aluminum. A larger head could react more load without damaging the surface it’s clamping against.
Some design philosophies, Japanese for example, want to design an engine that never ever needs service. The idea of damaging a component during service Is FAR outweighed by the cost and weight of larger headed fasteners. Note, head size doesn’t just effect the weight of the fastener, but also the component it’s attaching. The German std is the opposite.
Since it’s the thread and not the head that establishes the torque reqt, the larger German heads have the advantage of reducing stress inside the wrench or socket which makes the fastener harder to damage.
The newer ISO std found a sweet spot between the two poles, JIS having small heads, DIN having larger ones.
Not a criticism, but I sometimes get the impression people think fastener heads are chosen by random selection, or car manufacturers choose heads to make repairs more difficult. Neither is true.
