-Is this a taper pipe thread or a straight pipe thread? It makes a difference.I need an M16 x 1.25 pipe thread tap for a temp sensor in an oil pan.
-You're not looking with the right designation, I found some readily available.I just can't seem to find one on google. Is a metric pipe thread tap an oddball item or am I not looking with the right description?
Care to share?.
are you sure about that?Metric tapered pipe thread is usually a BSPT
Which is also called R threadMetric tapered pipe thread is usually a BSPT (British Standard Pipe Taper). Suppliers like McMaster have them.
I agree, BSPP or G thread which has straight threads and a sealing ring seem to be more common.are you sure about that?
