Source for metal ceiling panels?
MikeC55
CT
Hey guys, those of you who have used metal panels for garage ceiling, where did you buy them? I'm not having much luck finding basic interior panels in CT/Tri-State area. Did you buy them locally or have them shipped? I did search this site and didn't find too many leads.
PWC Repair
Arkansas
I'm out in the woods in nowheresville but there's a place about 30 miles away that rolls it out through dies to a couple different rib patterns, any color, any length. Surely to goodness there must be a place like this near you.
NUTTSGT
Northern Central Ohio
What exactly did you search, what words ? This may be part of your issue.
Don't use "metal panels"
try something like . . .
ribbed metal siding
pole building materials
post frame supplies
Amish builders
liner panels
Who in your area puts up the post frame buildings ? Where are they getting their supplies ?
NUTTSGT
Isn't liner panel just 29 gage?
Home depot, but be prepared to overpay
Yes, usually is.
If you're referring to my comment about not using "metal panels", that was in reference to search words trying to find what he needs. He may need to be more specific when utilizing his GoogleFu if he's having trouble searching.
PCustoms
VT
I wasn't, but I agree.
Any metal roofing supplier should be able to get 29 gage panels in whatever color he wants and most lengths. Home depot may have them in stock in a few options
@MikeC55 where in CT? I see a few ABC locations. Best bet may be a smaller yard, but not sure where/what's around you
MikeC55
CT
Thanks, guys. I was searching on 'metal ceiling panels'. I'll try the alternates. I'm between Danbury and Norwalk and will check with a local lumber yard (Rings End). I'm not sure who does metal buildings / pole barns in this area. I think 22/24 gage is a little heavier than for my needs.
PCustoms
VT
I'd be shocked if they can't get it
Edit: these guys definitely do, as I buy ABC up here and they list it:
Bert_
NW Iowa
If you are looking for suppliers, look for metal roofing. Then ask if they make a thinner interior rib panel.
manwithtools
Lebanon, TN
Road Trip!
Point being, your local lumberyard should be able to get the steel, but it’s not going to be the lowest price.
And neither are the big box stores, including Menards. The lowest cost supplier will be the folks that roll the metal in house. In most populous regions one should be within 100 miles.
