DIY Economizer for Garage?
HoosierBuddy
Southern Indiana
Hey guys,
Recently we've had some summer weather. Typical day here in southern Indiana is seeing highs in the low 90's and lows about 70. My 3 car attached garage gets pretty oppressive and stays that way. The 3 ton ac for the bonus room above (also cools attached breezeway) has been running most of the time and during the heat of the day is unable to hold temperature upstairs in the bonus room.
Part of the issue is the garage gets hot and just stays hot. Even when I go out there in the morning when its 70 degrees outside it's pushing 90 in the garage.
The garage is 2X6 contruction R-19 walls. The garage ceiling/bonus room floor is insulated as well....but I have noticed the bonus room AC struggles much less if the garage is cooler so I've started opening all the doors while I have my morning coffee to get some air exchange. I have to close them when I leave for work though.
Soooo.....the garage has 3 rather large operable windows. My concept would be to use 2 of them, one in the south west corner and one in the north east corner, to mount fans. One would be set to intake, one to exhaust. Here's what one looks like:
I can't find CFH, but they are 4 speed 25 watts with a reversible motor for intake or exhaust. They include adjustable thermostatic control, but that's based on room temperature.
Strategy would be to plug them into a temperature controlled outlet that would power up when the exterior temperature dropped below maybe 78 degrees. Then leave the fans' interior t-stat setting at say 65 degrees. So, in the summer they would run any time the exterior temperature drops below 78 (normally about 2 AM here lately) and would keep running until temperature got back about 78 outside (normally about 11:00 am lately)
Using those style fans, total cost would be about $250.
I could opt for cheaper versions of the fans (without interior t-stat control) and get it done for more like $125. Actually for summer use, the interior t-stat isn't really needed anyway.
Anyone have experience with this sort of thing? Seems like it should work, but as always, any feedback you can provide is appreciated!
larry4406
Northern Virginia
Not sure on the fans, but seems helpful.
Attic truss on top of garage? If so, how is the back side of the kneewalls sealed off? Should be sealed off with Thermoply or similar. Old school was just to leave the batt exposed. This allows convective currents to occur and encourage heat transfer.
Are kneewalls blocked solid at bonus room baseboard level? If not, huge leakage path.
My prior bonus room had these sins. Once fixed, much nicer temps.
dcg9381
Austin, TX
Those fans directly, no... But I've got a 3-car with a bonus room above it, the room doesn't cover the entire garage area, so I installed an "attic fan" on a thermostat that will fire up if cars heat-soak the garage. It vents out the soffit...
I think your idea is solid.
WisJim
Menomonie, WI
If I was doing this, I would be using some cheap box fans that I see for $10 each at garage sales. Even new, they aren't expensive. For the difference in cost you can make available fans fit the windows. Then you could decide if fancier fans would be worth it or if a window AC unit would be better.
Copymutt
Colorado
I regulate home temps here by just manually controling windows. Open at night, close during the day, retired so being on site is ok. Works fine & no huge AC bill. Fortunate that humidity here is single to low double digits. Another approach would be to get that sun off the roof & walls if possible. I’ve measured 148* on the garage SW wall. Even w/ 2x6 R19 it causes heat soak. Soon be ordering shade cloth to cover the patio & that wall outside the garage. Shade cloth rather than an extended roof as I want the solar gain in the winter due to a huge southern window. That will make a huge difference.
That leaves the attic which gets unbearably hot. For all its benefits metal roofing maximizes heat gain. I have end vents but might someday modify the shed design roof to incorporate ridge venting at the top. It helps during site selection to plan for deciduous trees that are natures way of controlling unwanted solar gain.
Firebrick43
West central Indiana
I would run a program on the controller that starts circulating air any time the temp drops say 2 or more degrees from the high in the past 4 hours AND the inside temp is higher than the outside temp.
I think if you wait till 78 degrees outside temp you may already be behind the eight ball in cooling it down.
I would then shut off the fan if at any point the inside temp rises more than say 2 degrees past 6am. It would be counterproductive to let them run till 78 degrees.
I have been thinking of doing the same thing but with an AC infinity cloudline duct fan
H
HoosierBuddy
Southern Indiana
I appreciate the feedback guys.
I'm certain those that suggest a window AC are correct in that it would work better, but it also uses a magnitude greater (or more) power.
I found a cheaper/higher flow window fan and a couple of slightly less expensive digital temperature controllers with 2 meter corded temp sensors I can use for control. The equipment is supposed to be here Wednesday.
This morning when I got up it was 64 degrees outside and 82 degrees in my garage. I hope that with the proper fan control, I could see closer to a 2 or 3 degree differential in the morning (67 in the garage in today's example). Once the outside temperature gets above say about 74, the fans will shut off and my 6-inch insulated walls will help keep it cool....where right now they are just holding the heat inside.
We'll see. I'll post back on this thread on the results.
