Drywall Finish Costs - Mud and Tape
bagsanthony
Guys, if there is one task I don't like doing myself it's finishing drywall. Currently, I'm weighing my options. My current auto repair space is drywalled however no wall insulation is in place. I was leaning towards going to dense pack cellulose insulation (based on recommendations on this forum) to eliminate tearing down the existing and having to reinstall once traditionally insulated.
There then comes the cost of drywall finishing. With the cost of having any work done these days being astronomical, what are you guys' thinking are ballpark figures for finishing approx 1000 sqft of drywall? The wall spaces are 13 feet high. I guess this overall will determine if it's worth my time to rip it down or just blow in and patch a bunch of holes. Thanks!
Adaylate
Washington
My location in SW Washington with 8-18' ceilings and average 12' walls.
175 sheets of Sheetrock bought, 4X12' sheets, hung, taped, textured, pva primer and ready to paint.
Bid came to right at $100. per sheet.
About one fifth of the material was fire rock.
This bid was for a combination shop/ living quarters.
Good luck with your project
finn
The UP, God's country
Shortage of skilled drywallers, cement guys, and roofers now, for obvious reasons.
Labor prices for trades like that are skyrocketing, if you can find someone to do it.
I wouldn’t think what someone paid a year ago would be relevant anymore.
dcg9381
Austin, TX
I was gonna question the "obvious reasons" but I get it. You're in the UP, labor rates up there for this stuff is off the charts. It's crazy how much skilled labor goes for.
Drywall has "levels" of finishing that can swing the job 500% or more. I'd be stopping by any new construction that I see where drywall is going in. Or just do what I did and throw up OSB. Works well enough, easily taken down... but it's not a fire-stop.
finn
I’m talking about labor availability in the city, since the labor pool is being rounded up., but yes, rates are high here too.
All the young guys here want to be a GC and retire by the time they’re forty. They can charge what they want, to some extent since the baby boom contractors have aged out.
Hole in the wall mechanics are charging $150/hr with no overhead, operating out of a pole barn with no overhead.
I paid $4000 for an 8’x14’ four inch thick slab last year, and I did all the site work with my skid steer. He made the forms called the batch plant, and finished it. The guy had a pockup truck, but borrowed the finishing tools from his employer and do my job on a Saturday.
Not loo long ago I paid $5k for a 16’x20’ slab done by a crew of five or six.
Hank11
Tennessee
Might think about cutting the top 2 feet out, unscrewing the cut out, blowing in to fill then filling the 2 foot cut out with batts and screw the 2 feet of drywall back up. Probably get the best job that way. If your hatred of finishing overcomes you, at least you will be more comfortable inside your unfinished but drywalled shop.
You might ask around at places that sell drywall for names. Might find a couple guys who want to work on Saturday for some spending money. Even just 2 coats would make it pretty OK for a shop.
bagsanthony
Thanks, interesting suggestion. I'm just wondering if I would be paying somebody to dense pack (it's my understanding the rental machines are only capable of loose fill) why I would even bother opening and cutting the wall myself.... I would let the installer do that to get the cellulose installed.
Firebrick43
West central Indiana
You can not dense pack with drywall in place. There is netting that lets the air dump at the site of where cellulose is packing. Trying to fill a closed cavity has air blow back and creates cavities, that still may settle but no where near the density of dense pack. The following is the only way dense pack happens.
I have done two and its hard enough to make sure all cavities are filled when you can see them.
Any one telling you that you can dense pack thru a small hole doesn't understand the term. Any one trying to sell you a dense pack job thru a hole is lying.
dcg9381
Austin, TX
Yea, I can't touch that, it's one of those "not on this forum" things.
I don't know the north, but the key is to get the guys doing the work, not the GC that's wrapping the work.
I'll pay $150/hr for a mechanic that charges me actual time (not book time), is good (meaning he's faster than book), and isn't behind a service manager. But I get it.
I think I'm paying like 1/2 that for 10x10 pads down south. I have a brother pouring big concrete slabs and hiring the actual "labor crews" that work for GCs, paying them a little more to do the work on weekends, he's at 50% of what I pay. It was $15k here 6 years ago for 2400 sqft of "easy job".... I hate concrete...
matt_i
SE Michigan
If you committed 1 hr per day to it, you will a) get better at it, and b) be done before you really know it. I used to passionately hate that too, but got into a position where I had no other choice without a giant delay in my project. The worst thing that's really possible is a big mess (eg apply 5 gallons of mud and sand 3 of it back off).
A couple of things that really helped me...1) using a trigger spray bottle filled with water to easily fine tune the viscosity of the drywall mud that comes out of the pail 2) watched a few guys doing a giant wall, and they taper away from a **** seam a full 12" on each side of the centerline 3) using sanding screens (rough, then fine) to make sanding faster. 4) use a flashlight at a low angle to show where the defects are, you won't be able to see them at first looking straight-on.
driftpin
Getting some ceiling patched in a SFR rental we have, damage from roof leakage, before we decided it was time for a complete re-roof, and not just doing patches where the leakage was at, of the shingle roof. The re-roof was a tear-off of asphalt shingles, removing about a foot directly above the poured concrete tie-beam, to install strap-over galvanized steel strapping, w/two concrete screws/strap per roof truss at the tie-beam. The 65 year old CMU dwelling had clips for the trusses originally, before we decided it was time to do the strap-over truss method. Code calls for a secondary water barrier (stick-down) before the paper/shingling.
Here in So. FL, we have to carry 3 insurance policies: homeowner's, wind-only (the most-expensive), and flood-only. A 1,600 sq. ft SFR on a third-of-an-acre, and the wind-only policy was >$4,400/year. Getting the strap-over addition to the low-end of the roof trusses cut the wind-only policy to < 1/3 of the former premium. The cost to add the strap-over system was < $3K.
This week, I'm getting a couple of ceiling areas done by a licensed drywall contractor recommended by the roofing contractor, and the bid came-in at ~$200/hour, and done in < 1 full day. I'll prime & paint. There were several places I had done myself, where the 5/8" sheetrock was still intact & tight, but needed a bit of spackle and prime/paint.
Hank11
Tennessee
It is possible to mud your walls and ceiling without sanding. (good enough for a garage or shop) The key is carefully applying just enough mud and knifing it well. First two coats do not have to be sanded if you do it right. Use hot mud mixed from powder.
67King
Friendsville, TN (Knoxville area)
This. Just moved out of a house I was in for 19 years. IN the past couple of years, I renovated all of the bathrooms, which involved a lot of drywall work. The garage was a wreck, I tore out a lot of teh drywall that was there to make it cleaner (I had run 240V throughout for my lift, a mill, bandsaw, welders, etc). Had to do the ceiling, too, where I had to box in the columns for the lift. Anyway, I absolutely hated drywall, but still did it, as most of it was going to be hidden behind cabinets or mirrors in the house, and the garage didn't need as much detail work. Well, funny thing happened, I actually got pretty decent at it.
pcmeiners
True but If you want your taping job to look good it requires a very quick sanding basically to catch small high spots. Between coats an average room takes about 25 minutes of sanding between coats (wall and ceiling). Yes the "professionals" do not sand between coat but the results show it.
CraigStu
Blacksburg, Va
Another technique to look into is using a wet sponge vs sandpaper. Get the sponge in the drywall section of the store so you get the right type. Cleaning sponges don't work as well unless you know exactly what type to get.
bagsanthony
Thanks guys for the suggestions/info.
Update - After a third quote I got a real good price for dense packing cellulose this week. Significantly cheaper than the first two. For $3200, I'm strongly leaning towards doing the cellulose.... ripping the exist drywall down, installing insulation all to just reinstall drywall and then of course finishing.... and most importantly my time is pushing me to this option. Not to mention, the high R-value that the cellulose will provide since I will have approx.. 7.5" densely packed in.
manwithtools
Lebanon, TN
Absolutely not necessary to sand between coats. If sanding between coats is required, too much mud has been applied. Anyone who does much drywall finishing figgures this out very quickly.
manwithtools
Lebanon, TN
For a garage you can get away with no sanding, if you want no "holidays" is 25 minutes per room to much work for you?
No, I can do a Level 5 finish without sanding between coats and so can a few million other people in this country. Have you ever watched a capable crew? There is simply no reason to sand between coats. When I'm done mudding, I'll sand with one of these, you will never know I was there:
Ultradog MN
Twin Cities
If I could give you a 1 hour lesson I could make a good drywall taper/mudder out of you. There's only about 3 things you need to know
Jerry
Was a pretty good mudder before I retired.)
CraigStu
Blacksburg, Va
When I drywalled my add-on 16x22 bay I thought a lot about drywall. What I found was it is best to buy whatever size you need so most of your joints are beveled edge to beveled edge. I had 10ft ceiling but the bottom foot or so was block. So I bought 10ft drywall and cut a foot off so I could install vertically so all the wall joints were bevel to bevel. After a day of mudding the ceiling to wall joints and the 22ft long **** to **** joint down the middle of the ceiling, and having to undress to my undies in the garage before I could take a shower, AND not happy w/ the results, I bought a couple sheets of one side nice 1/4" plywood. I cut it in to strips 2-4' wide. Used them to cover the joints and even made crown molding w/ a 2" on the ceiling and a 3" on the wall. Less than a day to finish w/ the 1/4" ply. When you paint it all the same color that 1/4" disappears well enough for a garage. BTW, I chose a very light grey paint color and rented a sprayer. Painted walls, ceiling and block all the same. Paint dried fast enough I started in one corner and worked around. By the time I got to the start point, it was dry, so I just kept spraying. Paint done by 2pm including pickup, cleaning and returning the sprayer.
NUTTSGT
Northern Central Ohio
$3200 for insulation install only ?
WildBill
PNW
Guy that I hired to mud/tape when I built my house didn't sand anything and it was perfect. He just used a broom to brush off the random little dingle at the edge of the feathered areas when he was done. 22 years later its still perfect. He said if you need to sand you need to get a different job. He also told me exactly how he wanted the sheet rock done because I was putting it up.
