Who makes good flush cutters?
redwrench60
East Tennessee
Overall I think Knipex makes the best flush cutting pliers. They have cutting area from the tip, all the way back to the pivot, they have nice pointed tips to sneak in and nip a zip tie out of a bundle of wires without cutting or knicknig a conductor and the spring can be pulled if you don’t want spring loaded handles. They are incredibly durable and well made. IMG_3886.jpeg
neophyte
Pennsylvannia
I have a pair of nice sewing scissors and I beg my wife not to use them for plastic but she doesn't listen. She also uses my expensive cooking scissors for cutting plastic. Kills me everytime
Maybe I'm a tool Nazi. Tools last longer if they aren't abused.
Gave you tried buying her a pair or two of the Midwest snips made for general shop use?
CGarage
United States/Switzerland
Facom ~ 30-40 years ago made a whole range of cutters with different blade / jaw material depending on what you were cutting.
I felt that was a very professional approach, with metallurgy and jaw design being application specific.
L.Cheapo
I have the Knipex and the Snap On. I prefer the Snap on. I like the handles better and the little plastic clip that came with it to protect the blades and keep it closed when not in use.
AJHD
My vote is Snap On or Icon, depending on your budget.
I've had a pair of SO for many years now. I bought the Icon when they came out. I recommend both.
Not sure what it would take to wear them out. I used the Snap On pair 5-6 days per week for nearly a year, maybe longer. They still work fine.
mike93lx
Richmond, VA
Yes, that became apparent to me :D
Regardless, saying that your product can cut “screws” without specifying softer machine screws is a bit deceptive. In my mind, anyways
We're you cutting screws just for the sake of it?
The only screw I've ever had a need to cut were machine screws, but maybe I'm missing out
Hakeem
Chicago
When you take a bunch of drywall down, the remaining screws can usually be removed with a driver or broken clean off with a hammer. Sometimes, they bend or break off proud of the stud, and have to be cut flush for the new drywall. Angle grinder is the best tool for the job but a hand tool that could trim the screws down would have been great.
I use the dedicated machine screw cutters on strippers for cutting machine screws to size
neophyte
Pennsylvannia
Machine screws usually require a special cutter that doesn’t deform the diameter and the threads, unless the person cutting the machine screws feels like filing or grinding the end of the machine screw after cutting it.
There are plenty of other screw types, from wood screws, to deck screws, to drywall screws that might need to be cut down.
Cutting down screws because the only screws you have on hand are too long is not uncommon, and the same applies to nails,
Cutting down screws after installation, because you didn’t realize the screw/s were too long is also common.
Someone on the Philly Reddit section was complaining that their neighbor has a fence with numerous screws sticking out the back, probably because the fence was assembled by someone who bought or only had screws that where too long.
This is the type of thing where someone would need to either disassemble the fence, or go thru and cut every screw down screw down, and then hopefully go thru with sander or grinder to flatten the ends of the screws.
It would not surprise me if drywall screws were used, since drywall screws seem to be the quick go to general purpose screw nowadays, mainly due to the **** silly putty soft wood screws that tend to be readily available.
^ We used an oscillating "mult-tool" with a metal blade for that task. Went through three or four packages of blades on that job.
AEAdam
SE PA
Only times I EVER cut screws is when I’m installing toilets. Those brass base bolts often need cutting off so the cap fits. Household electrical plate covers is the other time.
In both instances, I run at least 2 good nuts on, torque them against each other so I have something to hold, then either put them in a vise and use a hack saw, or in the case of electrical I use bolt cutters. I have cut the toilet bolts insitu, but do the same thing with extra nuts.
Then obviously you can file the ends or not then unthread the nuts to straighten out the cut threads. Easy peasy.
Otherwise, honestly for absolutely everything else, I buy the right bolt or machine it properly on the miller.
Sparky Six Axis
Buy a pair of Klein strippers. They have built in machine screw cutters that don't damage the thread. You can cut 6-32 and 8-32.
neophyte
Pennsylvannia
I'm confused. I thought this guy was asking about flush cutters for zip ties.
What's that have to do with cutting screws?
If you need to cut screws, buy a screw cutter:
Esco screw cutter
Ikogu screw cutter
Why on earth would you be trying to cut screws with a device designed to cut zip ties?
SMH
The cutting screws issue is a bit off topic.
Someone mentioned Klein D-2000 cutters being able to cut “a lot more than that”.
Hakeem responded in post #39 that his Klein cutters that could supposedly “cut screws” where damaged cutting drywall screws.
Hence the slight off topic posts about cutting “screws” and what the term “screws” can and should be inferred as meaning,
ahh okay....
I think the first time I had to cut down a screw I was maybe 12 or 13. I had a tiny 2-inch clamp-on vise on my desk in my bedroom, and I had an X-acto razor saw, and I had a small file. (And not much more at that time in the way of "tool".)
I double-nutted the screw (as described above), sliced off the end of the screw with the little X-acto saw, and then filed the top smooth.
Then I worked a slight chamfer on the threads, and put it into service. Worked dandy.
I've never used diagonal cutters for nipping off screws or nails - I use an old pair of linemans pliers (branded Indestro, probably made by Klein). They seem to have been doing okay for the last 50+ years.
ToolFanGeoff
So Cal
Did anyone share Swanstrom yet? The pair I bought have carbide inserts at the cutting edge. The ones I have are very sharp, and have lasted 3 or 4 years so far. The tool I have is M403C
They are small, have a nice handle, and fit well in the hand.
I have several pairs of Knipex, they are nice, but the first time someone uses them on even a soft copper wire, they are nicked and get tossed. I have Xuron (made in USA). they are nice, but not great precision...
I think I bought the Swanstrom because of a suggestion here on GJ. Definitely a winner and yes, I suspect that they were expensive, but I smile when I use them. This thread has made me think I need a larger pair for big zip ties.
decableguy2000
Have some Tsunoda in my cart right now. I have been using the Doyles with descent results. I have broken the the ones with the wire catcher though. Kleins are holding up well as well. Have the Icons in my home box. They are good as well but can be pricey when not on sale.
KnurledNut
n/a
The Swanstrom 710/Snap-on E710 are my all time favorite.
The red cushion grips with black cable tie below:
These German ones with the on/off spring, steep angled head, box joint and ball end handles were my go-to for a while. I believe they were VBW. Also the 90° head flush cuts work wonders when the others wont fit and need a straight shot. Knipex makes a nice pair of them too:
I currently keep a pair of old large head 1755 Platos in my work kit and I use Swanstrom S710s when I need the reach or leverage in the shop. The Italian Hakko CHP-170's get some exercise too and are good disposable cheapos:
Edit to add:
A good sharp pair of small diagonals with the tips blunted work great for dismantling. This lowers the chance of damage to the base material. I try to save my flush cuts for installation if time allows. There are some cutters designed for just removal but I have never used them nor felt the need for them.
These USA Williams have a similar 710 design and size but are not flush cutters. I blunted the tips for the purpose stated:
Squankum
Southeast
Just wait until she uses a tip of one as a pry bar!
I have a pair, bought on a recommendation from here. I don’t cut zip ties often at home, but always dig to fish those out. Does a better job than the zip tie guns at work.
bwringer
Indianapolis
The Hakko flush cutters work great and I seem to recall they are ~ $10 US
I buy Hakko cutters in packs of five on Amazon and scatter them around my environment so I can always find one when I need it. They work great and last reasonably well.
I have one that was deliberately mangled to remove carburetor float pins, and doing so was not inconvenient or a tragedy of any sort because I have several other pairs.
I've never used my flush cutters to remove a zip tie.
I'll grab anything that will snip them off without damaging what they're holding. Usually diagonal cutters or a small pair of shears:
YesIHaveAHammer
the Lindstrom 8140s
I tried the 8160 from that range and found them a little bit mismatched - pretty big and sturdy head, and relatively short handles (125mm, 5"). The head seemed like it belonged on 140-150mm diagonal cutters. Could by why they were a fair bit cheaper than the other sizes.
oh ... just for reference:
Klein D275-5
^ These things are garbage. I bought them on impulse because they were crazy cheap. I gave this pair to my buddy to get rid of them. I felt so bad about it, I had a pair of both the Tsunoda KBN150 and KBN125 flush cutters drop-shipped to him and told him to throw these away.
He told me he already had done so.
