toolman0217
- Joined
- Jun 11, 2011
- Messages
- 132
"Machine screws" are fairly soft.Emailed Klein and they specified “machine screws”. A bit misleading in my opinion.
Gave you tried buying her a pair or two of the Midwest snips made for general shop use?I have a pair of nice sewing scissors and I beg my wife not to use them for plastic but she doesn't listen. She also uses my expensive cooking scissors for cutting plastic. Kills me everytime
Maybe I'm a tool Nazi. Tools last longer if they aren't abused.
The last thing my wife needs is a pair of snips.Gave you tried buying her a pair or two of the Midwest snips made for general shop use?
Also looks like the jaws were formed by a child using a rock.
I have at least 3 pairs of them and they work great
I assume you're talking about the lonngitudal misalignment. The vertical misalignment on all cuttets of this type is to prevent the blades destroying each other.The stock image on Amazon for XURON flush cutters shows the jaws mis aligned lol
Yes, that became apparent to me"Machine screws" are fairly soft.
Drywall screws - not so much.
We're you cutting screws just for the sake of it?Yes, that became apparent to me
Regardless, saying that your product can cut “screws” without specifying softer machine screws is a bit deceptive. In my mind, anyways
The only screw I've ever had a need to cut were machine screws, but maybe I'm missing out
Machine screws usually require a special cutter that doesn’t deform the diameter and the threads, unless the person cutting the machine screws feels like filing or grinding the end of the machine screw after cutting it.We're you cutting screws just for the sake of it?
^ We used an oscillating "mult-tool" with a metal blade for that task. Went through three or four packages of blades on that job.When you take a bunch of drywall down, the remaining screws can usually be removed with a driver or broken clean off with a hammer. Sometimes, they bend or break off proud of the stud, and have to be cut flush for the new drywall. Angle grinder is the best tool for the job but a hand tool that could trim the screws down would have been great.
Only times I EVER cut screws is when I’m installing toilets. Those brass base bolts often need cutting off so the cap fits. Household electrical plate covers is the other time.We're you cutting screws just for the sake of it?
In both instances, I run at least 2 good nuts on, torque them against each other so I have something to hold, then either put them in a vise and use a hack saw, or in the case of electrical I use bolt cutters.
I haven't tried anything else from them, but based on my engineer scissors, I imagine those snips are quite goodI use These Engineer snips. Ive been happy with them and not had any issues.
The cutting screws issue is a bit off topic.I'm confused. I thought this guy was asking about flush cutters for zip ties.
What's that have to do with cutting screws?
If you need to cut screws, buy a screw cutter:
Esco screw cutter
Ikogu screw cutter
Why on earth would you be trying to cut screws with a device designed to cut zip ties?
SMH
Did anyone share Swanstrom yet? The pair I bought have carbide inserts at the cutting edge. The ones I have are very sharp, and have lasted 3 or 4 years so far. The tool I have is M403C
They are small, have a nice handle, and fit well in the hand.
I have several pairs of Knipex, they are nice, but the first time someone uses them on even a soft copper wire, they are nicked and get tossed. I have Xuron (made in USA). they are nice, but not great precision...
I think I bought the Swanstrom because of a suggestion here on GJ. Definitely a winner and yes, I suspect that they were expensive, but I smile when I use them. This thread has made me think I need a larger pair for big zip ties.
I have a pair, bought on a recommendation from here. I don’t cut zip ties often at home, but always dig to fish those out. Does a better job than the zip tie guns at work.Did anyone share Swanstrom yet? The pair I bought have carbide inserts at the cutting edge. The ones I have are very sharp, and have lasted 3 or 4 years so far. The tool I have is M403C
Also have some of their Scissors and they're probably some of the best for the price i have used.I haven't tried anything else from them, but based on my engineer scissors, I imagine those snips are quite good
I buy Hakko cutters in packs of five on Amazon and scatter them around my environment so I can always find one when I need it. They work great and last reasonably well.The Hakko flush cutters work great and I seem to recall they are ~ $10 US
I've never used my flush cutters to remove a zip tie.A good sharp pair of small diagonals with the tips blunted work great for dismantling.
I tried the 8160 from that range and found them a little bit mismatched - pretty big and sturdy head, and relatively short handles (125mm, 5"). The head seemed like it belonged on 140-150mm diagonal cutters. Could by why they were a fair bit cheaper than the other sizes.the Lindstrom 8140s
