What the heck is this thing?
snapmom
Florida
I have no clue what this box is. In my garage ceiling where my garage door opener plugs in. has about a 14 gauge wire coming out of it.
cgrutt
Assuming its plugged in on other side of outlet my guess would be a transformer / low voltage power supply of some sort. Do you have any low voltage lights etc outside garage? Maybe for old telecom equipment or alarm? Dog fence (underground wire/ collar system)?
snapmom
Florida
No low voltage stuff, I do have an alarm, but the control box for it is inside the house. maybe I will unplug it and see what happens. The single wire coming out is odd
cgrutt
What is the device on top of the light? Maybe old converter to make opener compatible with newer style remote controls? Auto door closer?
PCustoms
VT
Garage door opener thingy
Looks like the wires snake immediately into the ceiling. I'd guess doorbell or thermostat, and not garage door.
It's also overheating.
I would unplug it and start watching for what doesn't work.
mervyn
Missouri
Ok. I thought she was talking about that little box. Upon closer inspection I would get up in the attic and see where those wires go.
The box does look discolored
mrb1
Miami County, Ohio
Couldn't see what was going on up top...if not doorbell, alarm, or lights like mentioned....old Carbon Monoxide alarm? Crack the cover loose. Or at least unplug and see if there is a manufacturers label underneath.
nadogail
Coronado, CA
IMHO, it is a “wall wart” power supply. I have several that feed sprinkler timers, alarm systems and the relay that allows a low voltage thermostat that controls the 240 volt power for my shop heater.
kbuhagiar
Escondido, CA
No question it is a 'wall wart', question is what does/what did it provide power to?
Maybe get a closer look at any inscriptions that may be on the cover, as that my possibly provide a clue.
gleman
Michigan And Florida too!
I had a 12v transformer right there.
You hook up a car battery if you leave in the summer like I do.
Do you have a pair of wires with spade connecters/clamps nearby?
snapmom
Florida
I followed the wire as far as i could, it goes in the direction of the alarm, and doorbell, so its probably a transformer for one of them Am just going to leave it alone, as it is screwed into the receptacle, and I am old and don't want to get on a 8 ft ladder to unscrew it. Thanks for your help.
rlitman
Long Island
...They usually look like they're overheating but it's just cheap plastic discoloring due to normal heat and age.
The plastic has fire retardant chemicals (usually bromine based, because they're cheap) in it that will eventually stain it if it isn't black to begin with, particularly in places that are warm (around the transformer core). It's not necessarily overheating, but it is a "phantom" power waster if you don't need it.
driftpin
I am surprised that OMR didn't claim, "It's a power supply for an electric saw set & sharpener."
We had a transformer similar to that in the dining room of a mid-'50's ranch-style 1-story home, for the doorbell. It was removed during a whole-home re-model preparing for retirement; we're into our ninth year now. A Ring doorbell took its place. A blank-off plate covers where the transformer box was, and the stamped-steel electrical ceiling box which is now abandoned in-place.
