Rusty67
LA, CA
The only thing about that kit is it requires a pressurized water source where as the Kobalt fan will just pump it out of a 5 gallon bucket. A M18 to Kobalt tool adapter is like 20 bux. I haven't tried it with a fan but I feel like this might be the easier route? The misting kit is cool though.
Ohio Andy
Columbus, Ohio
I don't remember if you guys have talked about this yet, but...
2131-20
M18™ ROCKET™ Dual Power Tower Light
This thing puts out an insane amount of light. I dropped in one of my 12 amp hour batteries and I had this light on high while working in a tight confined area with little light for over an hour.
Lost power at the house this evening so I grabbed that light and I put it on its lowest setting and literally my wife hot power had come back on cuz I had this at the bottom of the stairs and it was illuminating a lot of area that you could see including upstairs and downstairs.
about an hour later power came on, and only one bar on the battery had been used.
All dealing with the power loss. I just raised it a bit so it was just above my eye level and put it on the low setting and it still kicked out a bunch of light.
All I was doing my work, I was replacing a grounding ******** a water line in a tight area so I had the light directed exactly where I wanted it.
When I bought it honestly I was thinking about illuminating entire ceilings or entire walls, I wasn't thinking about doing plumbing in a tight area. Okay it was a tight area for me to get into but there was enough room for the light to stand up, man. I'm really liking it. Highly recommend it.
Odd-job
2131-20
Have two of the v1 rocket lights still going strong. These things saved my **** during a couple of long duration power outages we had out here in CA. I tend to haul around other lights for working on stuff unless its an extended amount of time. The rocket lights take like a few extra minutes to setup...
Rusty67
LA, CA
I love mine but they **** with the larger amp hour batteries. The low battery warning is at a percentage or something so it starts flashing with the 12.0 WAY sooner than it needs to. The 5.0 battery is what that light seems to be calibrated for. When it flashes using a 5.0 battery, it really is time for a new one. With the 12.0 it starts flashing and there is SO much juice left in the battery. Very annoying. Overall a great light and I love mine though.
Rusty67
LA, CA
Got my original M18 12.0 battery back from RMA last weekend and it magically became a M18 12.0 Forge battery. Now I've got 2x12.0 and 2x12.0 forge batteries. Shipping it out was a pain but the warranty upgrade was really nice. I wonder if I'll be able to mow most of my property on a pair of fully charged batteries now that I don't have a bad one in rotation. This was most def screwing me over.
Odd-job
Glad to hear they upgraded you. I think my one semi lame 12.0 might be going on 8 years? Pretty sure I got it with the first m18 chainsaw that came out. Doubtful I am in the 3 year warranty period though :)
Rusty67
LA, CA
I have several M12 6.0 batteries that won't even take a charge, all out of warranty. I bought a battery spot welder and was going to open them up and fix them... eventually. Has anyone ever swapped bad cells out in their batteries?
assassin10000
I've rebuilt one m12 3.0 with newer samsung cells that died. The same ones used in the HO2.5.
Not completely terrible if you can desolder and pop the spot welded tabs off.
Here's the innards before iirc
assassin10000
That doesn't effectively turn them into 2.5s though right? The board is gonna control things the same either way?
It does.
The 2.5ah batteries have a higher amp output but supposedly less capacity. The higher capacity is why there are higher failure rates of the m12 3.0 and 6.0 batteries, as they are a higher stressed chemistry iirc. In real world use I think the 2.5 & 5.0 basically match longevity in use, while still having more oomph available.
Rusty67
LA, CA
It does.
Maybe we should request TTC do an episode on that? would be cool to see if the different boards in the batteries perform different with the same cells.
Getting their cordless air hammer, the videos of the tests done on it are amazing. Uses my regular air hammer bits
Looking forward to your review of it.
