Recommend scan tool for Toyota Rav4 Hybrid
A&P mechanic
FL
Hi GarageJournal,
  • What do you recommend to read the check engine light code on a 2024 Rav4 hybrid with 40,000 miles?
    • “Maintenance Required - A malfunction in the electronic control of the engine throttle or automatic transmission has been detected. Contact your Toyota dealer to have your vehicle inspected.”
    • I do not see any lights on the dashboard and only see the message on the big screen.
I have a Veepeak Bluetooth adapter that connects to the OBD Fusion app on my iPad and it says there are no diagnostic trouble codes pending or saved.
An internet search shows the below code is Toyota specific, so an OBD scan tool is not good enough to read the code.
This scan tool will only be used periodically at home.
It would be great if I could connect to my Ipad, have no subscription or use a scan tool that uses normal batteries like AA etc, so the tool does not go bad in several years.
I have an iphone and an ipad. (I do not have an android phone)
What do you all recommend for home use?
Thank you in advance!
A
A&P mechanic
FL
Thank you for the recommendation wizard!
I am reading their website now. I like that it can connect to an Ipad and it can read more than what an OBD tool can (y)
JDtime
Forget the topdons you have to pay yearly or you have a paperweight. Id do the mucar BT200 MAX. Lifetime updates free. Pay once thats it. Also I had an issue with one of topdons battery testers and got the run around.
A
A&P mechanic
FL
That is good to know that this has lifetime updates.
I am reading about it now, my initial impression is this may not read the specific Toyota alert as my current OBD tool does not.
(I am still learning about all this stuff)
I do see that it is a much better OBD2 scan tool though.
Buckaroo5
Central Ohio
JDtime
Id even look at XTOOL A30M V2.0 free lifetime updates (who gearwrench uses for their odb) but make sure you keep the box as activation you need a number off it. Can be a pain. Or Ediag Elite KINGBOLEN Bluetooth OBD2 again free lifetime updates. All of the ones I mentioned are bidirectional btw not just simple obd code readers. Just have to see for your specific car which would be the better fit.
A
A&P mechanic
FL
Check Pine Hollow Auto Diagnostics on YouTube for reviews.
Another place to check on YouTube is South Main Auto. He owns multiple brands.
Good idea on the videos Wizard, I will check those out.
Bluedriver should read all the system codes on your car including standard engine OBDII, Trans, SRS, ABS and HVAC codes. It does not require updates. You can confirm the coverage on their website. It does not provide bi-directional control. The Next Gen version is currently $95.
I will read about their offering too. I see a bunch of reviews. Thank you for the recommendation!
Ok, I like "free lifetime updates" and I will read about these.
Just learned "bidirectional" as in bidirectional scan tool means it can turn stuff on and off.
This is fun learning about all this stuff.
(I recently had a Tacoma from the early 2000s for 20+ years and bought a used Rav last year. Vehicle diagnostic tools have sure come a long way haha) Thank you!
Buckaroo5
Central Ohio
I started out with a basic OBDII code reader and went to the moderately priced Bluedriver when I found the need to read SRS and Trans codes. It has been sufficient so far and can also read expanded "live data". I am waiting to invest in bi-directional control until I need it. The problem is you buy a "scanner" providing bi-directional control (which is more advanced than a "code reader") and the advances in technology force you to buy the next version or purchase an update in the not to distant future. Oh, and prices keep coming down as capabilities improve. I do a fair amount of car work but I don't waste money on un-necessary tools because they have to have a pay-back. My advice is wait until you need the bi-directional control before you buy-in.
Ohio Andy
Columbus, Ohio
Everything I'm going to recommend here has lifetime free updates just so you know.
I do like my
Innova 5610 OBD2 Bidirectional Scan Tool. It has worked well for me but I've only used it on cars from 2016 and older. A friend of mine borrowed it and he was quite pleased with it. And as of right now they have new ones and a used like new. I believe up on Amazon
I also own...
KINGBOLEN K8 Pro 8-Inch Bidirectional Bluetooth OBD2 Diagnostic Scanner
I bought this so I would have something that works with newer vehicles like my 2026 traverse RS. Again, I've been very happy with this, but it is at a higher price point.
I believe this one is being replaced by the elite model, but I paid $500 for the pro and the elites are selling for more than $100 over that
None of these will give you a topology map, but if you want the apology map, you are surely not going to have lifetime free updates.
I was chatting with a mechanic friend of mine and he he said that he likes
LAUNCH CRP123X V3.0 Read & Clear 4 System Codes in Seconds, 7 Hot Resets Save Dealer Visit, Graphic Live Data, DTC LookUp, CANFD DOIP, Lifetime Upgrades, No Mechanic Needed
The price is good. Updates are lifetime. The current price point is under $200. It's not as full-featured as the kingbolen, but he tells me when he needs a more robust scanner. He just uses one where he works. He really strongly recommends this one.
A
A&P mechanic
FL
That's good advice buck not getting bidirectional control until it is needed.
I do like my
I also own...
"Everything I'm going to recommend here has lifetime free updates"
Thanks Andy! Good to know, I will read about different models above.
My main goal to use the scan portion for the Toyota specific alerts that come across the big screen ~ multi-function display.
I just searched what topology meant and it is "In a car scanner, Topology is a visual map showing all of the electronic modules in your vehicle and how they connect."
I have two Innova and they have been very solid.
That's 2 votes for Innova, thank you Rinspped!
Ohio Andy
Columbus, Ohio
I figured that the topology map would be useful, but not worth it to me for the extra cost. Understand I've never used one that will provide a topology map, but I figured that the topology map might make it easier to find a specific thing. I wanted to monitor but I can't say that with any authority. It's just a guess.
I've used the Innova to scan after very generic non-informative lights have shown up on my dash for my Toyota. I own a couple dead simple ODB2 scanners that gave me direct readings for things like tire sensors. The Innova gave me human understandable values without doing conversions.
My more expensive scanner on the other hand allowed me to do things like reassociate keys to the car... Hard part for me anyways. Is cutting the key? I have no way to do that. So I still need to involve someone else but I don't have to pay the $200 dealer association fee... At least on my 2016 Toyota Camry
A
A&P mechanic
FL
Appreciate the insight Andy and I will take that into consideration! "The Innova gave me human understandable values"
For awareness, I had a car key fob made at Costco.
There is a van that comes to the local Costco store once every 6 months and it was around $240 for a key fob if I recall.
On my old truck that had normal metal keys (not a fob), I had them cut locally at a locksmith for several dollars as I felt he did a better job versus a big box store.
Innova 7111, just do it. mine has been flawless.
3 votes for Innova, thank you IronWorker!
I checked Innova 5610 compatibility and it will not work on a 2024 Rav4 as their website shows 2024 and newer is incompatible.
Amazon reviews show that the 5610 works on the older year Ravs.
The 7111 does say it will work on a a 2024 Rav4.
Summary so far,
I think I like the BlueDriver as it has lifetime updates but it checks less Toyota specific codes compared to the Innova and may not be able to find the Toyota specific code.
An interesting note is that some reviews say it takes about 20 minutes to run a full scan, that works for me but it is something to be aware of.
I did contact BlueDriver directly with my vehicle specifics and the exact code but they are unsure if their scan tool can find that or not.
I'm still researching the others.
I do like that the Innova 5610 takes AA batteries but it won't work on a 2024, so that is a no go.
The Innova 7111 does work on the 2024 but it has a permanent battery so that battery will not last forever.
I did see the TopDon a scans a bunch of modules which is what I am looking for but it stops doing vehicle scans after a year without paying the subscription (~50 a year), so I do not want to pay a yearly subscription.
Yesterday, I went to clear the “Maintenance Required” light on the multi-function display (big screen) as I change my own oil and in the process I accidentally erased the Toyota recommended check engine alert.
Therefore, I am going to buy one of the recommended scanners but I am going to wait until that light comes back.
I noticed the alert had a date of 03/2026 when it appeared, so it might be some time if and when the light comes back on.
I have a lot of reading to do and I am going to watch the suggested videos.
I appreciate everyone’s recommendations!
DSEng
Don't know about newer Toyotas but a USB to obd2 cable, a laptop and the factory Techstream software is one of the best solutions. it's also cheaper than a universal scanner if all you need is Toyota.
The newest car I've tried it on is a 2014 Corolla, but because Toyotas are cockroaches and I drive my vehicles till they die, I don't have much new stuff around.
A
A&P mechanic
FL
This is a unique idea and thanks for pointing this out DSEng.
I checked the official Toyota Techstream pricing structure and it is
2 days for $30.00
or
$105 per month
or
$580 per the year
Out of curiosity, I also did a search to see if they make an OBD2 cable to connect to an Ipad and I learned that Techstream works the best with Windows, so a laptop (OBD2 cable to laptop) is the best choice if this route is chosen.
DSEng
2 days for $30.00
or
$105 per month
or
$580 per the year
I'd suggest reading that link I posted. A windows virtual machine will run on apple.
Here is a story about why I like the factory software. A few years ago my Hilux was down on power and consuming lots of diesel. I grabbed my Foxwell scanner and found no codes but saw my MAP sensor was about 30% off where it should be vs atmospheric pressure. Pretty cut and dry cause, as MAP effects fuel trim, so it got a new Toyota sensor. But still no change, down on power and the new sensor was also reading wrong. Checked it with a friends Autel, same reading. Went through a whole rigamarole testing the wiring, including bench testing the sensor and also using a variable power supply to test the wiring to the ecu plug. At this point I was starting to suspect a bad ECU. I friend had me try tech stream, and lo and behold the MAP signal was correct. In the end it was dirty/old injectors, which was my original suspect.
But what this taught me was the aftermarket scanners have to reverse engineer the Canbus signals, and they got the range scaling wrong for the MAP channel, and whoever did this must have shared the Canbus definitions database between Foxwell and Autel so they were both wrong. I still use the other scanners for quick checks, but anything more than basic I'll get the laptop.
Ohio Andy
Columbus, Ohio
I will admit that I don't use Apple computers, but, when I want to install Windows and run Windows in a virtual machine, I need to buy a copy of the Windows operating system. I assume that still needed....
Historically, when I've needed Windows I've always just run it in a virtual machine. I'm running off Linux usually.
A
A&P mechanic
FL
That is useful story and thank you for sharing.
I read a portion of the linked info, it is 80+ pages long.
I agree the official Toyota tech stream software is hands down the best, but only required when a nonstandard issue occurs.
For the majority of standard issues, I think a non-tech stream software will be fine as the brands I am considering do not require a subscription.
After hearing DSEng's story, I am inclined to pick up (1) scanner and (1) USB to OBD2 port in the event I need to use Tech stream someday.
My only computer is a Windows laptop.
I use a windows desktop computer at work and prefer using a Windows computer over Apple.
The only Apple products I have are an iPad as I like to surf the internet on it and my iPhone.
atikovi
Suburban Washington DC
An entry level bi-directional scan tool is going to start around $500. There is no real need to update the tool after the free updates end unless you're a shop. Not a big fan of the style that works with an app on your phone. Navigating around a 6 inch phone screen will get old real fast compared to real dedicated tool. I prefer Autel myself and use a seven year old MS906BT. Gearwrench just came out with a tablet under $500.
Buckaroo5
Central Ohio
Techstream is also my current plan when I go bi-directional as I am exclusively Toyota at this point. I was planning on investing in the pricey non-bluetooth Mongoose cable rather than a knock-off e-bay cable because, besides diagnostics, I want to be able to do flash programming. Have always been afraid a knock-off could brick the ECM.
Anybody know anything about this?
Buckaroo5
Central Ohio
As you go down the scanner investment rabbit hole, another capability that you could very well want in the future is the ability to do flash reprogramming. A lot of the fixes these days (and likely more in the future) require updating programming. Techstream provides access to those updates.
