Question about pressure testing Mini Split
Firebrick43
West central Indiana
The factory flares on most of those chinese minisplit linesets are very poor. I installed a Senville unit for a friend, and one flare shared off before torque was achieved, and another failed months later with a leak.
I got a bundled kit with some Mitsubishi minisplits, and the linesets were actually made in the USA, and those flares were good. Been holding up like 4 years later with no issue.
FWIW: I always pressure test at 400 PSI for 24 hours.
Its been 9 years ago since I installed my Mitsubishi, without pulling the covers I am pretty sure they were mueller line sets.
They are very good and worth the extra money to buy over the Chinese ones. They bend much easier without kinking as well. They include nice flares and seem softer so making new flares when shortening are easier.
The last gree mini I bought paid 58 dollars more for the mueller line set at supply house over the ones that the gree dealer was selling
jjrbus
Florida
There is a go no go flair gauge that I seem to be the only person that uses. When I put 3 Daikins in several of the factory flairs failed. The Senville I recently put in all flairs passed. Cut 2 off anyway. I know real men don't need a flair gauge. 1785679843414.png
American Locomotive
Rhode Island
Yes, that's right. They were mueller.
bob smith1
I like to hand around a micrometer at a 'mens gathering', just to see the caveman brain at work.....lol I actually had one say, "wtf is that". Told em it was a "precision C clamp"..... Man cards were docked after that stupid question.
The most common issue in da flurs is a blem on the sealing face from the tool. These stupid things need to move to ORF with PTFE rings. We just have to keep being stupid.
aggie113
San Antonio, TX
Well... here's hoping the Tosot(Gree) unit I put in recently lasts, paid for a longer lineset, but not a better quality one :whistle:
Firebrick43
Make sure the line set is well protected. The white polyfoam that they are putting on the cheap line sets(compared to the rubberized black foam) is causing pin hole leaks for a lot of people as it breaks down.
aggie113
San Antonio, TX
Yeah, already caught it sweating in the summer heat and the vinyl wrap is crumbling. Plan to wrap it in something tougher to help protect it: https://www.amazon.com/dp/B0FCF5TKFL?tag=atomicindus08-20
I would consider trying to replace the foam but worried it would increase the chance of leaks to handle the lineset that much.
jshillin
PA
Before you pressure test anything, redo all of the flares. I'm sure one of them is likely your leak, but there's no way I'd waste time and money otherwise. I just installed mine a few months ago and I put new flares on 3 of the 4 connections because I thought the other one looked ok. I pressure tested it with nitrogen and it blew. I have a pretty long and detailed thread on here about it. g
N
newpain01
Eastern NC
Looks like I found my leak. It was definitely overtightened, as soon as I moved the line it snapped and fell off. The other flares look fine, so I need to cut this off and make a new flare. I put some Nylog on the other flares and threads and re-tightened everything. It was pretty much impossible to use a torque wrench on the bottom ones, the unit is 10" from the walls and my torque wrench is 20" long and starts at 20ft lbs.
bob smith1
I'd redo them all! No doubt all were done up the same or similar. I hate flares!
Hohn
Diesel Central, Indiana
Which end failed? The flared female end?
Hohn
It's the 45 degree angle. The JIC 37 degree flares used in hydraulics and the 30 degree flares Komatsu uses are pretty reliable and leak-free.
The most reliable setups I know of for metal-on-metal seals for high pressure using some kind of sacrificial crush washer with a bite-edge design where there's a concave undercut on the union that concentrates force at the edge. Hence "bite edge".
If you design it with the washer easy to replace, they're cheap and very effective.
Firebrick43
I think it’s more the fact that JIC is usually steel and has a back up gland that makes it more reliable. Copper can be be reliable to but most of the issues is that some cheaper products are not annealed dead soft after drawing the tubing and use of crappy flaring tools.
Hohn
You're right, it's probably more about being steel and having the backer gland.
Heck, a swagelok would be a HUGE upgrade for most of these setups. Given the expected life of these things, why not stainless tube and swageloks? Yeah, it's a higher one-time expense. But it doesn't work harden as much as copper, it's far more corrosion resistant, eliminates galvanic corrosion issues, etc.
bob smith1
Whatever you do, just make sure you put PTFE tape on the flare threads........... :ROFLMAO: :ROFLMAO:
Dude, I caught this recent and said something....... I should not have, the man standing there is who dun it.......
