dsimatt
I think my Ryobi has more power than my Milwaukee circular saw. The Ryobi also can use a larger blade.
It’s never failed to cut through stuff but just sounds and feels like it’s struggling way more than a saw like that should. Did a little big of research last night and apparently the trigger assembly likely is the issue. I’m not sure what I want to do at this point.
manwithtools
Lebanon, TN
Well, that saw is nearly 10 years old. Treat it to a new switch, or replace the saw...
Things have improved in that product family a lot since 2017.
Odd-job
maybe hit the trigger with compressed air and some electronics cleaner.
Rusty67
LA, CA
The problem with that circ saw is that the blade is on the wrong side. I'm right handed and HATE a blade right saw. Also that looks like the smaller 5" saw which I've never even bothered with. The 6.5" saw I have that is several years old has never failed me and is a blade left saw.
Now I'm wondering if I bought the wrong hole hawg. I'm not doing holes that big though and it has saved me when doing some electrical work in tight spaces....
LXCam
Rusty if you bought the 2807, I’d return it. I’m not sure how much better the 2809 is but..
If it wasn’t for the fact I stained this one mixing fast setting concrete mix on a 106 degree day, it’d be going back.
LXCam
You bought the wrong one. Milwaukee has 2 of these that, at first glance, look similar but aren't.
(Not including the variants with the quick lock bit holder)
The one you want:
This one is a beast. I've mixed thinset with mine.
Well ahhh ya apparently 😖😆
So I just went and looked. I bought the 2807 model. Damn pos 🤬
Ohio Andy
Columbus, Ohio
That describes things well... But mine is very new And I've only used it a couple of times.
I just know I can use my Ryobi with larger blades and when I fire it up it just feels like it's good to go and doesn't bog down. My Milwaukee sounds and feels like it's bogging down but it's still cut through things but it always slows me down because I'm afraid it's going to stall so I slow down. That said, it was cutting through treated 2x8s...
dsimatt
I won’t argue it’s almost 10 years old but it’s seen minimal usage. It sits in my basement until I need to use it so not stored improperly.
This is a premium brand and reflected in the price, some store brand one I wouldn’t be upset about.
I tried that, it’s getting power through the switch to the motor. The weird thing is it will try to turn and stops. I can’t upload a video here but playing with the trigger makes the blade very slightly move each time. Using a screwdriver to move the blade it’s a ratchet feeling, not smooth like I’d expect.
dsimatt
Grandpa was left handed and he actually had a Milwaukee right blade saw… you used the other ones and not that one. I’d prefer the left side, blade but the 7.25” saws don’t come that way.
I’ve used this saw maybe a dozen or so times so not worn out at all. This has never spun up like the old corded ones, I’ve used it to cut 2x8s also and it did it but sounded really like it was getting work hard.
danski0224
Near Naperville, IL
Motor is probably bad. Same thing happened to a relatively new but not under warranty recon SDS drill I have. Was half the cost of a new one to have it fixed.
The brushless motors can just "take a ****" (probably the controller, not the motor part), and they do not spin smoothly if there's magnets inside.
dsimatt
IMG_3915.jpegI’m calling this a write off, did a few checks and is getting power to the motor so agree with you. I’m sure I could have sent it in but not making the same mistake I did with a snap on impact.
Rusty67
LA, CA
The ratchet feeling is normal on a brushless motor I think. Check the switch with a multimeter and see what the resistance is through it. Just because you are getting power doesn't mean the switch is good. It could have very high resistance and still pass current.
They don't make one in a sidewinder but they do make one:
dsimatt
I talked to my dad today catching up and got talking about this. He has both the 6.5 and 7.25 saws and really recommended the 6.5 so I’m going to wait and hopefully snag one on a deal.
dsimatt
Milwaukee..... lunch..... warmer.....
Something I'd expect to see on April 1st.
Milwaukee is pretty far behind on this, last week the guy replacing sprinkler heads was telling me about the battery powered food warmer he has. I can see some of our road techs getting this and loving it.
Dig Doug
After Having some piping hot chile for lunch
you might need a chair
ya Know take a load off
Or
drop a load off ….
lol
Steel_Rain
I know Milwaukee hand tools aren’t regarded as exactly top quality, but I don’t mind the ratchets.
Recently, Home Depot had a sale on most of the locking flex head Milwaukee ratchets, so I picked these up:
Compared to my non-flex heads:
I know it’s a crowded space and not a lot of people think of hand ratchets when they think Milwaukee, but these are nice, and I’ll be putting them to work soon.
Rusty67
LA, CA
Let us know how the locking feature works. I have always wondered how hard you can reef on one of those before the lock just gives up.
NightSky
Southwest OH
Ohio Power Tool has a lengthy blog post summarizing the Milwaukee 2026 pipeline.
Saw the heated lunchbox, but not the M18 Commode.
Bad Mojo
Thanks for sharing this. This was exactly what I was after.
mobiledynamics
Gotham City
Only 2-3 replies since PipeLine hit ?
And I thought I was the only one slacking on red.
I don't see anything that is a must have.....but am planning to buy their quicklock extension just for some fall hedge cleanup
Odd-job
Not any need to haves for a well invested Milwaukee addict like myself.
Look forward to picking up the HO 15 amp hour batteries when they finally go on sale at $10 amp hour.
Mulching vacuum might be a nice to have although between a dual battery blower and the mower I might be set on leaf clean up as blowing and then running over with the lawn mower might be the quicker way to go.
Misting fan - guess someone was listening to this thread that an m18 misting fan would make a lot of sense.
MichaelP
IL/WI border
I guess if you have a water source, there a good probability you'll have a power source too. And if the unit has to use water pump in the field (vs. faucet pressure), the battery life will be noticably affected.
But surely such portable swamp cooler would be nice to have.
