CAT Round Head Ratchet
Winterborne
Discovered something interesting when ran across a listing for CAT ratchets
> The 1/2 Drive Round-head ratchet looks to have a polished handle unlike the knurled on the Williams
> The warranty is only six-months versus a lifetime on the Pear-heads
Does CAT consider this ratchet so much weaker, hence the short warranty period?
Steve_P
The warranty issue with the round heads is that you may have to replace the entire ratchet, or at least the entire mechanism, which is a substantial cost, as opposed to a $3 mfr cost kit for a pear head. I have some round head williams that are 50 years old and haven't been rebuilt. If you are concerned about warranty, then Snap On is your brand. Industrial brands, and most European brands, are "if it's good out of the box, it's good" with the defects in materials and workmanship statement- which I agree with . The round head Williams are nice ratchets, but the head is doubly thick by today's standards.
W
Winterborne
I agree as well. The only tools I have warrantied have been manufacturing defects found upon delivery.
dnschmidt
Phoenix, AZ
I have several of the Williams B52, B54 and 1/2" round head ratchets and they are as close to bullet-proof as any ratchet possibly could be. I bought several replacement kits for these ratchets and I still have all of them unused. Once upon a time Mercedes-Benz did not have a warrantee. Their view was "Our cars don't break." That's the best warrantee available.
lardy1
In many cases the advertised warranty is just sales promotion. They know the product well enough to know it's going to perform but saying "Lifetime Warranty" to a potential buyer boosts sales. If a high percentage of their product was failing they wouldn't be saying it. You're paying for that warranty whether you know it or not.
KnurledNut
n/a
I have the Snap-on made Williams sibling. Mine is the S-53A, a longer 15" version. It's unfortunate CAT only offers the 11".
Mine uses the same 72t mechanism as the CAT which is totally different than the old Superratchet dual pawl design of its predecessors. This uses a single dynamic block pawl with the post and heart spring design common in Facom and several other brands. It also has rubber seals to protect against ingress and uses oil instead of grease.
I also have an older dual pawl version from the time period when Snap-on had acquired Williams but before they changed to the modern design. These tools dropped the "J.H." from the Williams name and the font changed to a very basic typeset.
The newer version looks similar from a distance, but has been completely redesigned in all but general shape. While the classic has an impressive timeless design, I do prefer the new less rounded I beam shame of the body and the full bright polish finish.
I don't think I would like the smooth, straight, round handle of the CAT. It's BEGGING for a black hard handle like the screwdrivers. :rocker:
I'm okay with the coke bottle shape of Cornwell and Wright and the smooth handles of Snap-on because they are contoured and the swells provide some hand placement, grip and control.
My Williams S-53A has a knurled handle, but it is much less pronounced than the older versions. I prefer the more aggressive old knurling. The vintage Williams actually offered a hard acetate handle option but its very rare to come across. A friend of mine had one.
So which one is better and why the warranty?
If I could only have one, I would keep the old version.
First, they are obsolete and I could always buy the new version.
Second, the dual pawl mechanism is tried-and-true. Its proven to be extremely reliable, has a very smooth and user friendly action and is mostly bulletproof. The new heart spring design is much more finicky, has some minor known issues, and may not stand up to abuse as well.
Third, the sound. Let's just say if the modern 72t version sounds like a 5.0 Coyote engine, the old dual pawls sound like a Formula One engine. Even if you aren't a good mechanic, your ratchet will sound badass and you'll pass with flying colors. :lol:
The CAT warranty? What to say.... That's a hard one to analyze.
But honestly, they offer a repair kit and its probably not expensive. Better yet, the Williams repair kit is probably more common at distributors and easier to acquire. IMO, the issue with all of these Williams roundhead ratchets is the handles bending. I have a theory they were originally designed to yield in the narrow body portion before the mechanism broke. I have seen dozens of them bent, probably by cheaters.
As a matter of fact, my S-53A is bent. The mechanism still works fine. But I know nothing about how that happened. :cool:
I like all these roundheads and wouldn't consider any of them a bad choice.
If you really want to up your mechanical game and improve your patience at the same time, go get a handful of the old ones and tackle the spanner nuts. It's a real good time!
:beer:
Scottie S.
:beer:
I like your spanner wrench. But I've never seen a Williams one in the wild so I had to make my own "spanner socket".....All of $.50 cents and an hours time of grinding and voila.....Works like it should.
KnurledNut
n/a
That's probably a better tool. If you look close in the picture, I broke one of the pins clean off of the factory spanner wrench. :beer:
Scottie S.
Yes it probably is as I made 4 lugs to fit all 4 of the indentations in the ring......If 1 or 2 of the lugs would break 2 would still be left to use.....But that factory Williams spanner is still cool to have.👍
