Try square opinions?
dwasifar
I make these Soma puzzles:
Obviously, precision is important to make the puzzles fit together well. I use a try square to check square on the pieces as I'm working. Currently I'm using this:
Interested in opinions. Amazon has the Kapro 353:
And also Starrett K53-8N:
Is it worthwhile to upgrade? Or is this an "if it ain't broke" situation?
whateg01
doo dah, kansas, usa
What are you trying to fix? Is the current square not square?
D
dwasifar
It seems fine. Basically I'm just wondering what makes the Starrett and Kapro worth their money. Nicer to use, maybe. The ledge flip-out and 60 degree line on the Kapro look interesting.
Just curious really.
whateg01
We have a bunch of starrett measuring tools at the makerspace. Just like any tools, you have to take care of them or they end up damaged. The two starrett try squares in the metal shop both are loose.
D
dwasifar
I had an original red plastic SOMA puzzle and loved to make all the prescribed shapes. 🟥🟥🟥🟥🟥
Yeah, I had one red and one blue. Really wanted the rosewood one they mentioned in the back of the booklet, but that was out of reach for a child in the late 60s. But that's why I make wood sets now.
D
dwasifar
Yeah. If I drop a square or knock it off the bench, I always check it before using it again.
Firebrick43
West central Indiana
I cant hardly stand a try square any more without a ledge. I don't think the KPro one would do it for me but it would be better than none.
You would probably balk at the cost of a 642SS woodpeckers
Nobody-named-Olli
If my perception of size is correct, you might find the Woodpeckers Mini Square interesting/ worthwhile for your work. I imagine it would feel like the perfect size and cover a lot of surface on those puzzle pieces.
https://woodpeck.com/products/woodpeckers-mini-square
I have this in my box of tricks and have found quite a few uses besides squaring up/ checking chisels.
But other than for the feel/handling, I think it’s a “if it ain’t broke” situation - if your current square works for you.
Kind regards,
Olli
I personally use a 3" machinist square, or a 4" double square for small stuff. No idea how big your individual blocks are, but I try to use a tool as small as possible to cover the work piece.
With your squares being 8", I would want to be on the 6-8" size workpiece.
Just easier handling IMO
scooterbum46
South Central Michigan / ex Gulf Coast Florida
I prefer Starrett machinists combination squares - I trust them more than any try square due to the try square's 2 piece construction that can be knocked out of square. The combination style with the rule drawn into square by the thumbscrew/bolt between two supports make it pretty hard to damage in any way that affects it's "squareness".
neophyte
Pennsylvannia
The advantage to a combination square or the “double square” version of the combination square, is that the blade is removable, and it’s possible to tweak the slot if the slot gets out of square to correct the issues.
Epstein has decent prices on the PEC squares, and better prices on blemished PEC squares.
PEC doesn’t make as wide a variety of sizes as Starrett, but combination square can be bought in sizes from 4” to 24” , with different length rulers.
There are also similar die makers square in 2-1/2” sizes.
For traditional fixed machinist square I prefer the European unibody type made from a single piece of steel.
AEAdam
SE PA
Carpenters use speed squares. Shop based woodworkers using power tools typically are getting things square by using machines that produce square. So I get it, they use solid steel engineer's squares to set up their machines. These excel due to their accuracy and the fact that every surface is square to every other.
Traditional try squares (the wooden ones with the steel blades) were really only ever designed to be square inside edge of the wood "stock" (where the brass was) to the TOP edge of the blade. The Stanley made ones were pretty good on the lower edge of the blade. But the top edge could be corrected (by filing, honing). But generally that's how try squares are.
Many woodworkers find machinists' "layout" squares convenient. The double squares at right are almost as square as the solid engineers' squares. The combination square at center was invented by Starrett in the mid 19th century as an all in one tool.
People choose Starrett because, unlike PEC, the accuracy of their tools is unquestioned. The venerable Starrett #20 engineers' square is truly a "master square" ground to .0002"/6". I forget what PEC claims, but others claim .0002"/1" which isn't really all that great if we trust it at all.
But beware, the #20 offered on Amazon are the China made ones and they are an order of magnitude less accurate. The Athol Mass made squares are many hundreds of dollars (larger ones could be $600, $800). Starrett doesn't state the accuracy of their double squares or combination squares, but those of us with master squares who have bothered to check find them to be dead on. Even used, eBay doubles and combinations are typically VERY square, which has sadly led to Starrett's decline. Their tools are made so well they will last many generations. I have no found wear to be an issue. I don't even really find debris in the slides to have much effect.
Why Starrett?
Starretts' blades are generally thicker than their competitors', which generally means you can't buy Starrett blades on eBay and use them in Mitutoyo or PEC heads. In use they have a little more heft and better balance. I find Starretts' blades desirable because the markings are so easy to read. There's just something about a Starrett ruler. The size of the marks, their depth and "brightness". Cheaper rulers are laser marked and just not that great. Last, you always need to check the ends of less expensive rules. Ends need to be ground perfectly square to the long edge and exactly at the zero point. Beware of rough, filed, or damaged ends.
Use of Adjustable Squares in the Woodshop:
  1. The adjustable squares can be set and used like gauges. This is really their chief advantage. So you can get a square line or a exact dimension at a known distance, and repeat that.
  2. With the blade not in its fully extended position, you get a bit better balance in use. If I dropped these tools on your bench, you'd do that without thinking as we all do.
  3. These are fairly delicate tools compared to the try squares in the OP. Sorry about the glare, the Die Maker's square (center) is only 2-1/2" long or so. Its an attractive piece for small work, but to be honest I don't use it that often. I bought it specifically for use on work in the milling machine and it excels at that because it is so compact.
    Personally, I use the 6" combination square (with the 45 degree face, center) the most in the woodshop, followed by the 4" double square.
    The original 12" combination square is a fixture in so many wood shops I've been in or seen, but my personal opinion is, it's too big, too blade heavy. The stock isn't long enough to get an accurate reference surface on wood and the balance of the tool is off. Ironically the smaller 6" version is better proportioned, in my opinion.
Summary, I'd go looking for a 6" Starrett combination square on eBay. You can find them cheap enough. All of mine came from eBay, and may need a good clean and a little touch up paint.
For the Starrett connoisseurs, the combination square in the pic is not the typical 6" combo. It was called the "junior" combo and is unique in that it has the hardened heads and uniquely uses the same blades as the 4" double square. The normal 6" combination square uses a unique blade that fits in nothing else I know about. That's the one I use in the woodshop, and this one stays in this drawer. The junior head is a little smaller than the normal 6" combo head.
KnurledNut
n/a
I am wondering about the size of these SOMA puzzles too.
A standard try or combination square seems like it would be awkward and overkill in size.
Second, I don’t see much room for adjustment anyway.
I’d make sure my mitre and table saws are dead on, use a jig for exact repetitive cuts and possibly use a straight edge during glue up to make sure they are exactly flush. Not really seeing where I would even use a square.
But if I felt the need, I would want it small and precise like my baby machinist try square:
MovingAlong
What is the perceived upgrade? More specifically, what would the other squares do for you that your current one does not?
If your current one is accurate - well, that's kind of what it's all about. :thumbup:
Old tool guy
Have you checked your square to see if it is accurate? It’s easy to do. Yours might not be adjustable, but at least you could see if it is good, might not need to get a new one.
D
dwasifar
For those interested in the scale of the Soma cube, here are some pieces I'm cutting for the next one, with the Empire square for scale:
Yeah I definitely be down in the 2 to 4-in range for my square for that kind of work. Use the bigger size for setting up your table or miter Saw, the smaller size for checking your finished work
D
dwasifar
The process is: I true up the table saw and cut the blanks, long bars with square cross section that will eventually be chopped into cubes on the miter saw. Usually my table saw cuts are true, but I check the pieces for square at that point just the same. Next step is the planer to smooth them out, and it's there that error can creep in. The other day I cut and planed four of the blanks, checking them for square between passes, and one of the four got a bit out of kilter, so I took it back to the table saw to true it back up before continuing, and now they all check 100% square in profile. At least, so says the Empire try square.
On the advice given here, I ordered a 2" PEC machinist square.
KnurledNut
n/a
I could understand sanding but why are you running them through the planer?
D
dwasifar
To remove the cut marks from the saw.
The blanks come out of the planer flat, square, and level. There's no way you could sand these blanks that flat and level, either by hand or with a handheld orbital. It would inevitably introduce minute variations in flatness, thickness and square, and affect the final fit of the puzzle. A drum sander or an industrial wide-belt sander might be a better choice, but every time I go down to my workshop, those aren't in it.
I do hand-sand the blocks before assembly, but usually only a stroke or two on the corners and end grain. The planer usually leaves a smooth enough surface to not require it.
strutaeng
Dallas, TX
I've got that Empire try square and have found it pretty accurate for my furniture building projects.
Are you using the square for layout or checking cuts? Or both?
I've been getting away with a cheap 2, 4, and 6" machinist try square set i bought maybe from Woodcraft many years ago.
I've been getting into engine rebuilding/building for the last few years and been investing into micrometers, dial bore guages and more precision measuring tools and learning metrology. It's a completely different ballgame measuring to 0.0001" for things like rod/main journal clearances and stuff on an engine.
I would say for woodworking, anything that's within a 1/64" is good enough (1/128" if you want to be snooty). Sand it flush, stain it and put a poly finish, and nobody knows or cares. Probably gonna move with changes in humidity throughout the year, if you are being honest.
D
dwasifar
For the Soma sets specifically, I only use the square for checking if my workpiece is cut square.
For other work, I will occasionally use one for layout, or a 7" rafter square, depending on what I'm doing and what's at hand. For making a bird feeder, say, or cutting bench slats, the rafter square is good enough. Yesterday I was making a cutting jig for Soma cubes out of MDF, and I used the Empire square for that, for better precision.
strutaeng
Dallas, TX
The photos looked good on your original post photos and you did not mention anything about stuff being off...
It's woodworking...don't overthink it.
Remember there's all those furniture pieces sitting in museums and antique furniture stores, built before micrometers and dial calipers capable of measuring to 0.001"+ were even available....
And honestly, even if those woodworking joints were off by even 0.01" or so, nobody would even know or care. The birds wouldn't care for sure, they have larger eggs to fry...pun intended...
The Bean
Delaware Valley (SE PA)
If I remember correctly, the original plastic SOMA puzzle was made from six very thin square slices, mitred on all sides and glued together. The fit was high precision and the puzzle was perfect in every configuration. I'm guessing it was Made in Japan.
D
dwasifar
Yours may have been, but mine weren't. They were both a tiny bit out of true on a couple of pieces. You got lucky. But my frustration with that imprecision is what drove me to try to make mine better.
Here's one still in its original packaging:
Hard to be 100% sure, but it looks like Made in U.S.A. down at the lower right.
Firebrick43
Sounds like you have a tablesaw issue more than anything?
A tuned tablesaw with a good blade should produce flat and square cuts wit glue up ready surface finish. For presentation surfaces no more than a few strokes on 220 paper on a long sanding block or the paper glued to a marble or glass tile with 3m 77 or something similar.
For pieces in the size your making one should only need to joint two faces 90 degrees to each other with a jointer (or track saw) for registration against the table saws fence. To make the other cuts. . Running such small pieces thru a planer is very dangerous
  • Like
Reactions: RTM
D
dwasifar
How is it dangerous? Those blanks are about 18" long. The planer manual says minimum length of stock is 10". I'm well within the machine's operating specifications.
Firebrick43
I am sorry. I missed last nights 11 am post that actually has a piece next to a ruler that shows it’s a little over an inch wide.
Most planers have a width minimum of 3/4” as well as a length.
I was going off the initial picture and thought the pieces were much more narrow without a reference. My bad
It’s still seems completely unnecessary to plane after running through the table saw if it’s set up correctly
