Larry, I have done rebar rails before, probably will do 1-1/4" pipe this time around. (1.66"OD) with either **** welded elbows or Kee fittings.So are the stair graspable handrails gonna be rebar?
Code indicates #10 (1.25" diameter) thru #16 (2" diameter) would suffice...
I built that big antler lamp 20+ years ago out of elk and mule deer sheds I picked up on the ranch in Wyoming and whitetail sheds from Washington, Idaho and Missouri. The wiring is completely hidden, it runs inside the antlers. Used a tomato cage for the form, cut it out after all the antlers were screwed together.Ya-Ya-Yaaaaaa, looks good Scott.........but once again where's the damn rebar??
You know a real man of your creativity would $hitcan the deer antler lamp and create a faux deer antler lamp out of rebar.....that way you stay compliant with the Basis of Design.
Look, I’m not trying to discount your younger hornier years by any means.I built that big antler lamp 20+ years ago out of elk and mule deer sheds I picked up on the ranch in Wyoming and whitetail sheds from Washington, Idaho and Missouri. The wiring is completely hidden, it runs inside the antlers. Used a tomato cage for the form, cut it out after all the antlers were screwed together.
Rebar probably would have been easier.
I sure hope you're right. We elected to go-ahead and replace the gas furnace section as well as the AC condensor/ air handler, since it was also 17 years old- and is located in the crawl space at the opposite end of the house from the access door. 70'+ of bent over crab walk for access. Not a pleasant service call.Well, that's something you shouldn't have to worry about for some time. And I'm sure it's going to work a whole helluva lot better than the previous set-up.
