Why does carflex come in big rolls?
sparky 1971
Central Iowa
I didn't go through the roof, but about three weeks ago I ran about 75' of sealtite across a commercial roof for a kitchen exhaust fan. It's supposed to be temporary while the roof gets replaced but if the roofers don't get it together and get finished pretty soon, I might forget about it and my temporary fix might become permanent.
Mike007
That actually crossed my mind. Maybe it was supposed to be temporary for some reason and was never addressed? But the tar or whatever it is used to seal it? That's just terrible on a rubber roof. Makes me think it wasn't temporary or done by someone with a clue.
Mike007
wouldve been cheaper to have a roofer put a penetration near the line set penetration
The carflex comes through the roof right above the electrical room. The AC unit is over a server room. Here's the kicker. There's no drop ceiling inside. It's fairly high, but everything is open to have run the electric inside.
matt_i
SE Michigan
If a person or entity is leasing a building, the building will likely have a "restored to original" clause at the end of the lease. In that case, reusing an existing penetration could be better long-run. Plus only need 1 trade instead of 2 or 2 instead of 3 depending on who does what.
toplessHO
central florida
That had to be horrible to pull wire through.
Carflex is difficult even when it's only 6' and gets a curl in it.
You think thats bad try smurf.
A well known national contractor did a hotel complex in smurf.
walls,slabs etc.1000' spools.
Jetline vacuum had no suction left at the end of home runs,
the convoluted shape created so much resistance it killed it.
Anything with a U bend wouldnt cooperate either.
