Chemical storage shelf ideas
free07110
Edmond ok
Been using this cheap metal shelf for years to put my chemicals in the shop. I’m tired of looking at this mess. What are you guys doing for chemical in your garage?
TurnipTruck
Southcentral Alaska
I also bought a real fire cabinet, but it wasn’t a deal. I got tired of waiting for a used one and finally bought new after five years of needing one.
gahrajmahal
Cincinnati, Ohio
something very similar :lol_hitti
Mine is way classier. I have a milk crate and a cardboard box I use for non-combustible on the same industrial shelves. I do have a repurposed metal cabinet for my paint stuff.
I’d love to see some good options for this. My challenge, NO WALL SPACE
Steve W.
Southwest oHIo
Currently using a shelf very similar to yours, just a bit less-populated, which allows it to be a bit more organized.
i84x
Earth
Personally use the same except sorted by small trays / boxes.
If you want to hide them a cabinet would obviously be better. Could even get a fire / chemical storage style one, though they tend to be pretty pricey new.
drokihazan
Eagle Mfg 60gal Corrosive Storage Cabinet. Fire safe + corrosive containment. 30"x30"x60". I have an older one, the new model (identical) is CRA62X
CGT80
IE, SoCal, USA
My garage isn't that big, so a cabinet outside has all of that. It used to sit on a shelf inside and it was oily and dirty. The cabinet is a steel 2 door office cabinet with adjustable shelves.
I have no problem with having flammable product containers in my garage or even near my welding are. A few products do stay inside, including acetone for cleaning before tig welding aluminum. Isopropyl alcohol, brake cleaner, tapping fluid, penetrating spray, etc are all out in the open. As long as they don't leak, all is fine. There isn't much flammable material in my garage.
OccupantRJ
Eastern North Carolina
Paint in quarts and gallons and gasoline are in a 6 foot tall metal cabinet in the detached storage building With an extinguisher near it. Garden and yard chemicals are on a shelf in the building. Oils and greases are in a metal shop cabinet for easy access. Extinguisher near. Spray can containers are on a 4” deep shelf in the power tool room for easy access and label reads. Same extinguisher near. Spray Dychem and tapping fluids are in the machine shop area for point of use. The lid of the parts washer stays closed unless in actual use and has a flammable sign posted. Waste oil is in a marked container underneath the parts washer. The farther away from each other these groups of chemicals live the better. The oil cabinet and parts washer are to the right in this picture.IMG_1700.jpeg
gahrajmahal
Cincinnati, Ohio
To start out I needed to get the bulk of my products off the shelves and onto my folding table. I found some shallow plastic containers and I thought I’d cut the tops and fit the bottles and containers into separate slots! What a genius idea!
gahrajmahal
Cincinnati, Ohio
Then I ran out of time and slept on it. After thinking about it, the larger grouping of products didn’t make sense. Most of this stuff is car wash and detailing stuff. I have many products for cleaning and shining wheels and tires. I have a bunch of buffing pads of several sizes and “ grits”. I have products for polishing and waxing of paint and metals. I have several solvents I regularly use. Lacquer thinner, mineral spirits, paint reducer, acetone etc. I also group windex and glass cleaner with interior cleaners. So, by using a big table it is easy to group all these products into groups of similar items. It made more sense to store these items together. I went to Menards, where they have four big isles of totes and storage boxes. I had some measurements, but once I had a few choices I ran them over to their automotive cleaner and product section. Then I ended up with two different sizes. One with lids and another as open basket type. We have at home loads of clear plastic sho storage boxes and I used a few of those too. Here is the final reorganized shelves and new labels too. Plus I threw away a good amount too.
gahrajmahal
Cincinnati, Ohio
My project was inspiring to someone else in the house. Mrs. Gahrajmahal decided to clean the laundry room and downstairs bathroom where she edited all the household and laundry products and reorganized it too using the “like with like” method. Plus I found that almost empty gallon of trim paint with the good paint code on it. I need to buy another gallon and finish the trim on the exterior of the house before winter sets in.
