1000Sq Ft Home- Bathrm
karoc
Hemphill Tx
Well I been making some progress on bathrm itself. I was thinking about knee wall but decided to just go up 8’ and about 30” out. I’m hoping this will keep water inside shower so won’t need glass door. Using all GRK screws and some Timber screws to help keep this wall level, plum and where won’t flex much if any. I believe once get Durock on both sides using panel adhesive and screws will make it stronger. I went ahead and use 3/8 anchors on bottom plate which I already had, no Tapcons this time. After that I started on Schluter drain flange which I’m now at 3/4-1” mark above slab. And I be able to level it once I get ready to do that. Ive decided to tackle the drain myself building bed just around flange with help of latex admix. (guys special thanks to yall for putting up will all my questions, providing pics, I now have good game plan)
I also started painting oil base primer on T1-11 siding doing grooves first. Dang it absorbs paint. Bathrm has 10’ ceilings which means I had to add about 12” pieces at top. As suggested by GJ I put 1x4 blocking between studs to help hold seams together instead of using Z flashing.Can’t tell there’s a seam unless you look hard at it. On each edge of siding I put thick coat paint to help hold edges together kinda like glue. Next trip going try float out edges on ceiling so that get it as flat as possible. Maybe just be able prime/paint without any texture.
I confess, I never realize that bathrooms can be so expensive😳Good grief it’s only about 5’x11’
Tks so much for y’all’s input
dcg9381
Austin, TX
Looks like you're doing a good job and saving yourself some money. Two suggestions:
1) You need to slope that plate, I assume it's going to get tile or some other surface on it eventually, you want 2 degrees or so of slope to make sure that any water splashed on it is routed back to the pan area. I see what appears to be shims, so you might already be doing that.
Not a lot of room to do insets that hold soap and bottles, etc. I handed this by building shelves in the corner. Same deal, slope them 2 degrees, I glassed them in... My shower builds are with a fiberglass hand-laid pan, then I leak test it for a few days.
K
karoc
Hemphill Tx
Not sure I would put T1-11 in a bathroom...
It’s what I wanted, but no one else thinks like me🤔 If I had do over I should have went with smooth texture👍
Like your thinking, thanks for reminder dcg9381. Love that tile and size, looking good.
dcg9381
Austin, TX
To each his or her own, but sure looks like you can make it work to me... If it's a moisture thing, drywall seems to survive in baths...
If you think I'm capable of picking out the aesthetics, you're sorely mistaken.. The wall tile was actually pretty inexpensive.
One thing I did right: Epoxy grout. Do it once and be done...
What floor pan / membrane system are you going to use?
duneslider
Riverton, Utah
I'm not saying there is anything wrong with epoxy grout but if the grout in your shower is getting stained you have bigger problems...
Epoxy grout won't last any longer than any other grout.
T1-11 is exterior rated, should last fine, the rough surface isn't easy to clean.
You will be fine not sloping the wood under your curb. I assume you are doing the whole kerdi install. It will all be waterproof and just have a slight slope on the tile when you install that and you will be fine. You could shim the drywall when you install that on top of the curb.
Unless you have very poor water pressure you will get water spray going out that door. May or may not be enough to be an issue but maybe plan on a rug or towel out there to catch it then hang it to dry when you are done. I also find open showers to be significantly colder, I like that but my wife very much doesn't like that. I could shower outside in the winter.
dcg9381
Austin, TX
Epoxy grout is completely non-porous, so pretty hard to stain out of the gate. Nothing wrong with regular grout, but I prefer "maintenance free" and not having to reseal....ever.... Seems to hold it's color much better than standard grouts I've used.. But YMMV...
K
karoc
Hemphill Tx
It be mud bed with slop,then Schluter membrane on top mud bed using Schluer’s All Set thin set. Next Schluter membrane on walls 5’ up. From 5’ up to 8’ will be Regard applying 3 coats.
Most of this info comes from Schluter video except the Regard.
duneslider
Riverton, Utah
What's your reasoning for not just doing kerdi all the way? I do a fair bit of frankenstein installs but if you are going to the trouble of installing kerdi just do it all kerdi. I personally like kerdi drains with laticrete hydroban but don't tell anyone.
The new version of schluter All Set is very nice stuff, I like it a whole lot.
75gmck25
Alexandria, VA
For our shower threshold we used one pressure-treated 2x4 flat on the floor, and then faced it with Schluter board all the way around. The bottom of the shower was a pre-sloped Shluter pan with a drain in the center. For the finished top of the threshold I purchased a piece of polished stone and had it cut to the right length. It was a standard off-the-shelf item from the stone store. We sloped the threshold when it was installed so that water runs into the shower.
We have a much wider opening, and decided to just hang a long shower curtain. You can use it to seal off the opening (keep heat in), but it is also very easy to slide out of the way.
I added 2x10 blocking in places where I thought we might need grab bars. However, I later saw a home show where they just inset 3/4" plywood for almost the entire wall, so they had wood backing everywhere.
dcg9381
Austin, TX
Did they inset that between the framing or frame over it? I took pictures of the blocking I installed with details on height above the floor...
K
karoc
Hemphill Tx
I just can’t except that foam floor pan nor walls will last. I know weight is distributed when standing on tile, but I just don’t see it lasting. Purpose of all Schluter system is more for installer who want get done faster, maybe be able set tile in afternoon.
I am using Schluter membrane on bed and 5’ up walls. Then Redgard up from there.
But mainly my drain was off center in both direction, but I was able correct in width but not in length.
Thanks for responding
duneslider
Riverton, Utah
No, I wouldn't use the foam either, I would just kerdi all the way up and not use the redgard.
The foam is totally fine if it works for the space but there is nothing wrong with a drypack floor with the kerdi over it. I rarely every use the foam, too expensive, but I have driven a forklift on the foam ramp with 2x2 tiles and it held up. That's besides the point, you don't need to use the foam but I would just kerdi all the way up and not add redgard into the equation.
duneslider
Riverton, Utah
I have inset 3/4 ply between studs and I screwed it in with pocket screws. When I did it I just did a 4' belly band around the shower to give me flexibility later.
