Welding helmet storage
BigMike782
Yes, I admit I have a sickness or fetish for welding helmets. I have about 12 different welding helmets, some I use all the time, some I use seldom, some I have because they’re cool(Huntsman 411P with a vintage Harris gold lens).
I need a way to store these helmets without hanging them over a cylinder or some such. I do not want to put them in drawers or cabinets.
Any ideas?
JuncleJohn
Omaha, Nebraska
I only have one helmet, but I keep it in an antique barrister book case with glass doors. I got it for free on CL and it does a good job of keeping it clean when not being used.
John
rooster59
Land of the Pines
1 old t-shirt, 1 boot lace. Drawstring bag for helmet.
Sew each arm shut, sew neck shut. Fold the bottom about 1 inch over the bootlace, making a tunnel for the boot lace.
Sew around the bottom, make the tunnel but don't sew the boot lace. Leave about 1/2" unsewn, ends stick out, tie ends of boot lace together. Takes me about 5 min tops. Hang lace over the tank valve.
Signing off
I've been in a machine shop that has a plexiglass box to store each helmet.
A different idea just popped in my head. A wall of milk crates and a tie died blanket over them. ???? WTH
MJD1
Always kept them on cylinder or lens side up on the table when in use. When done with the job I put them over the brow tines on random antler mounts on the wall.
BigMike782
Screw a five gallon bucket to the wall through the bottom of it. Use a lid to keep it clean inside.
This is why I asked here. This might work well. In my case It might work better hanging from the ceiling out of the way.
BigMike782
Mine stays hung on my 75/25 tank which is chained to the MiG
Done that before and the ones I don't use often end up with fuched up headgear from hanging off the headgear.
My most often used helmet sits on my gloves on my mig welder and a fender cover goes over it all.
shanker
Portland, TX
I bought one of these and my wife used it as a pattern to make a denim drawstring bag with extra pockets for our teenagers welding helmet.
goldtang
Western Australia
12 you win only have 2, the old one is in a draw string bag , for my newest one was lucky to scored a Hitachi storage box for free it was getting thrown out
mate has welding helmets and safety stuff stored 4 high gym lockers
BigMike782
This is why a shelf isn’t the solution. It’s not the hoard it looks like, I do many different things in the shop and it works(for the most part) for me.
Oregon rock crusher
West of Salem
The area around my welder wall is very busy too. This layered approach has worked for me. I cooked up a thin steel door with four hooks either side secured to a pole by self closing hinges. Sometimes when the boys come over for a project I get their helmets hanging for a while but eight hooks is usually plenty for me and I ran out of room to make it longer.
I do most of the dirty work outside the main shop through an adjacent door which allows for open hood storage. Before I added more open air fab space I still kept the welding stuff around a corner from the heavy grit producing action. Ed.
whateg01
doo dah, kansas, usa
I like the box idea. We have coat hooks at the top of an old wall mounted chalk board at the makerspace. Each hood is stuffed in a plastic bag then hung on a hook. Is a pain to deal with.
JReyn
Mine just hangs on a bench above my table but amazon has cheap helmet bags with pockets on the side. I have one and I keep my spare lenses, batteries along with a fiber cloth rag in it. After the new wore off I quit placing it in the bag though.
nadogail
Coronado, CA
My only welding helmet sits on my Welder when not in use. The Gloves and Leathers are in a toolbox under the Welding Helmet.
BigMike782
A big chunk of ceiling is still unoccupied. You have a unique opportunity to correct it.
You haven't been in my shop. There might be a small amount of ceiling showing but believe me a lot of it is occupied.
I keep the ceiling of the center of the main bay clear so that the trolley rail doesn't cause issues.
