Show your new tool arrivals
zendriver
Indiana
Since I now have trash service with the small bins. I try to keep it full with tiny branches that fall in the yard, that I chopped into small pieces Some are a little too big for the pruners, and I don’t feel like getting out of power tool to saw through
Have an olderhand saw but the teeth aren’t all for somewhat Greenwoodthat thought I’d give this a try for $5.50
Pretty sweet and well built. Blade is thin but then pruner blades usually are and has a locking mechanism blade is 9 1/2 inches
L.Cheapo
My first pair of good scissors. Handmade in Sheffield, England by a company that's been doing it since 1760. This is their "DIY" model, designed for cutting cardboard, leather, fabric, rope, string, cable ties, plastic, rubber, etc, so I'm calling it a tool.
New tool fetish unlocked!
Semi-hole mechanic
I'll give you $20 if you lick the coil wire off off a MSD box.
I was setting the timing on my ‘78 Grand Prix in HS and the timing light had somehow come unclipped from the plug wire and I reached to grab the clip and grabbed the plug wire instead and apparently there was a crack in the insulation that was causing the misfire not the timing. My right arm hurt for a couple of days.
Skyman
Central Maryland
Anything that allows (or helps) you to do something that you cannot do with your bare hands or your teeth is a tool. (y)
Fine looking scissors there.
Squankum
Southeast
I'm always a sucker for a new vacuum attachment. Learned about this from a man whose entire YouTube channel is him, professionally cleaning out people's clogged dryers and their ductwork. This is not fully rigid and can fit into narrow spots like a normal person might encounter between car seats. (I'll assume here that normal people don't need these for their dryers because normal people don't keep mashing the button and running it for three or four hours to try to get one load dry, like he reports.)
The black bit is just U-channel used for shipping. The big brush was a freebie that came with it.
One of the features of the design is that soft, flexible silicone-like base that fits over a variety of shop vac hose diameters.
$8. Really.
Squankum
Southeast
Bought this magnetic belt clip to hold stuff at work. Smaller than anticipated!
I’m a little disappointed because I don’t think this will be able to hold more than 1 tool or a couple fasteners at a time …. But it has been fun seeing how large of a tool the magnet will holdIMG_0495.jpeg
Like the time I caught the ferry to Shelbyville. I needed a new handle for my Snap On ratchet. So, I decided to go to Morganville, which is what they called Shelbyville in those days. So I'd hang a giant Swedish pipe wrench from a magnet on my belt, which was the style at the time!
Jarhead0408
Who knows?
Lesserstore
Texas
Got this 40 piece Century metric tap and die set off eBay. Made in Japan. I was surprised that the tap wrench and screwdriver also had Japan on them, as I thought just the taps and dies were Japanese made.4fa610e9-e0a8-4727-8ae7-f300c4979458-1_all_10774.jpg
This die has a bit of a typo:
It also seems like Century is changing to an Indian supplier. The first one I got from another seller arrived Monday; the coo on the box had India and Japan on it. I figured that meant the accessories were made India; nope, all but 3 dies were made in India. I sent that one back since it cost the same.
Jgaz
Wow, do those two trays look like my 70’s vintage Craftsman Tap snd Die set.
I wonder if Century was the OEM manufacture?
I had to make a new box for my set after the original black plastic box self destructed.
Not sure what the COO on my set is
Lesserstore
Texas
I have one as well, in SAE. Made in the US by Vermont American from 1959 up until the early 2010s.
Hakeem
Chicago
Can confirm, I recently bought a few single larger sizes from Century tool and they were all made in India. They’ve been adequate for my purposes but still, a disappointment since I was hoping for Japanese origin,
lund
Yes, I think Craftsman tap and dies were made by Vermont American with domestic production up through the early 2000s. They were a strong value for light DIY level use: much better than you could get at Harbor Freight type places but not industrial quality. They were reasonably priced and would perform well in light work. Good quality tap and dies with domestic production are still available today in machinist supply places. But they are expensive. It can be best for DIY use to have a USA Vermont American quality level set covering most occasional needs and eventualities and replace specific sizes in that set that you use a lot with higher quality ones. Then you do not break the bank to cover stuff you only use a little, have good coverage for what might come up from time to time, and also have good ones for the sizes that you use a lot.
Older 60s Japanese stuff could be pretty bad ... similar to modern low end Harbor Freight stuff. But some Japanese stuff through the 70s and 80s became decent (maybe similar to Vermont American stuff through the early 2000s before it all got offshored). Unfortunately, I am not sure if any domestic production sets at the level of Vermont American/Craftsman still exist for low $.
By the way, some of the people showing tap and die pics should oil + clean them more before storage. When they rust, it degrades the cutting edges. I try to wipe mine down with something like WD-40 after use and then store them somewhere dry. Surface rust will mess up a good quality top or die and it is much easier to prevent than to try and address it or resharpen after it starts rusting. It is also not a good idea to let cutting oil and grime harden into a sludge on them. They usually clean up pretty easily if done right after use.
willf650
I finally decided to replace my small shop vac for home to see if these new DeWalt vacs live up to the hype.
Short answer is yes they do.
It‘s slightly more powerful than the vac it replaces but seems half the apparent noise. This is the smallest version and supposedly the larger ones are quieter.
The only down side is you can’t use it as a blower. The air diffuses out the whole backside of the motor assembly. This is probably how it achieves the low noticable volume levels.
Etchase
Hawaii
Some Epstein’s goodness. The vessel ratcheting set includes 11 made in Japan low profile bits, with storage in the handle for two for $13.50. The book is great for people like me who just get a new panel. Those Epstein’s videos are going to cost money, and I couldn’t pass up the beautiful wood handle screwdrivers with over size grips that fit great in my hand. Renting new release movies would be cheaper content.
rharman
SoCal
That set looks really familiar. :cool: I have the SAE & Metric versions. Yes, from the 1970's. Grey case for one, black for the other.
"HIGHLIGHT YOUR BRICKS"
Not sure what that was about, but "Hub Technology Co. Ltd." shows up as a Chinese business, founded Jun 6 2014.
The URL printed on the box is a dead link.
https://www.cnverify.com/company/Hub-Technology-Co-Ltd says "China", not Taiwan.
I'm a bit confused. Do you have any sort of information on the company?
Those look very interesting. Please let us know how they work out for you.
Wood handle? Full through-shank? Bolstered end?
