Why don’t pullers use acme thread screws?
Hakeem
Chicago
Acme threads are stronger and tolerate debris better than V-threads. They’re used in vises, clamps, and jacks to great effect. Given the immense forces that a gear puller forcing screw sees, it seems like an acme thread would be ideal. And yet, all the ball joint presses and pullers I’ve seen use a standard 60deg V thread.
Is there a reason why these tools don’t use an acme thread?
whateg01
doo dah, kansas, usa
I've wondered that in the past too. I could see cost being a factor in low cost models.
Likely because ACME threads are too coarse. Most pullers use fine threads, providing far more force.
There are some pretty fine pitch acme threads and iirc, the efficiency of the thread is much higher.
H
Hakeem
Chicago
acme is probably too course and they also have a lower mechanical advantage than standard threads , 2 reasons why they're not suited
Can you tell me more about the lower mechanical advantage? Does this mean that an acme forcing screw subjected to 100ftlbs of torque applies a lower amount of linear force than a V-thread screw torqued to the same value?
The Cobbler
Acme threads deliver lower mechanical efficiency than standard V-threads due to higher friction from their trapezoidal geometry, but they excel at handling heavy axial loads and power transmission. [1, 2, 3]
Mechanical Advantage and Efficiency
    • Standard V-threads (60-degree angle): Provide higher linear force per unit of torque and better mechanical efficiency in standard fasteners because of a steeper helix angle and tighter fit. However, they are prone to stripping under heavy dynamic loads. [1, 2]
    • Acme threads (29-degree trapezoidal angle): Feature increased friction caused by the wedging action of their sloped flank sides. This reduces their mechanical efficiency (typically around 40–50% even when lubricated) compared to ideal square or standard tightening threads
whateg01
I'm pretty sure that's wrong.
whateg01
well I searched what has easier torque, and got this
Standard V-threads are easier to turn and require less torque than Acme threads under the same load because they have less sliding friction
60 degree threads form a bit of a wedge. This is what centers a bolt in a nut radially. That force inward or outward, depending on which perspective, is wasted as friction as it pertains to motion.
gimpyrobb
Cincinnati
It was explained to me with an axle analogy. The finer the splines(thread) the stronger the axle. like a 35 spline vs 8 spline.
dynode
My proto puller has acme threads, from my notes
  • Proto 5/8”-12 Acme thread
  • OTC Is all 5/8-18
  • Snap-On is 5/8-18
I kind of wish I was in the 5/8-18 system so I could use snap on accessories. I've been scheming to make an adapter for a while now.
KnurledNut
n/a
Some of my newest pullers have acme threads and they have worked well.
Steve_P
Because of the thread geometry they require very coarse pitches which take more torque for given axial force. They also have significantly smaller minor diameters vs UNF which makes buckling under compressive forces a major issue. The coarse thread pitches also make them want to backdrive, especially when lubricated, (which is what you want for long life) tighten up, remove wrench and it self loosens.
H
Hakeem
Chicago
Fair enough. With regards to the back drive - why is this not an issue for a vise?
whateg01
It's not an issue because despite people thinking acme threads only come in extra coarse or multi start, they can be made very fine. Not as fine as 60 degree threads but the example above shows that it can be done. I don't recall how much more efficient they are than 60 degree threads but I think it can come close to erasing any benefit is the finer pitch
danielbuck
it's probably just easier and more economical to use regular threads. I think the only thing I have that has acme threads is a lathe lead screw.
at least from my experience, the threads are usually not the problem with pullers, normally something else breaks first.
Firebrick43
West central Indiana
The lower angle Acme threads are specifically used in manual machine tool axis, jacks, lifting devices, linear actuators, and air craft control surfaces because they are self locking and don't back drive, even if well lubricated. It would have to be very coarse, in relation to other acme threads, to actually back drive
KnurledNut
n/a
Our crew used mechanical screw jacks for structural lifting. I’ve also seen these left permanently bearing loads for decades and back-creeping was never an issue even on heavily lubricated threads. I was always amazed by this, as they seemed to deny the physics of inclined gravitational forces.
Same for screwtop hydraulic bottle jacks. Never seen those threads back off under load.
Granted, both of these were typically a very coarse square cut thread.
Modern day Simplex:
https://www.ohiopowertool.com/simplex-sj2512
LopezBart
Lopez Island, WA
It all depends on the coefficient of friction between the nut and the screw. A Delrin nut on ground and plated ACME threads is self-releasing in my experience; of course, it won't take a lot of load compared to a steel nut on a steel thread. The formula is that the thread will release if the tangent of the thread's helix angle is greater than the coefficient of friction.
Geez, now you've ruined a perfectly nice thread full of guesses, WAGs, SWAGs, and pure BS by dragging math into the story. 4 letter words like that are not nice.🤣
Dagny
Northern Wi.
134a refrigerant cans came with Acme threads when it first came out.
I don't know the math of threads but fine threads seem to work a lot better when it comes to pullers.
Steve_P
What's the finest 3/4 Acme thread pitch?
Edit: Nook Industries lists 10 TPI max.
