Why don’t pullers use acme thread screws?
Hakeem
Chicago
Acme threads are stronger and tolerate debris better than V-threads. They’re used in vises, clamps, and jacks to great effect. Given the immense forces that a gear puller forcing screw sees, it seems like an acme thread would be ideal. And yet, all the ball joint presses and pullers I’ve seen use a standard 60deg V thread.
Is there a reason why these tools don’t use an acme thread?
whateg01
doo dah, kansas, usa
I've wondered that in the past too. I could see cost being a factor in low cost models.
Likely because ACME threads are too coarse. Most pullers use fine threads, providing far more force.
There are some pretty fine pitch acme threads and iirc, the efficiency of the thread is much higher.
H
Hakeem
Chicago
acme is probably too course and they also have a lower mechanical advantage than standard threads , 2 reasons why they're not suited
Can you tell me more about the lower mechanical advantage? Does this mean that an acme forcing screw subjected to 100ftlbs of torque applies a lower amount of linear force than a V-thread screw torqued to the same value?
The Cobbler
Acme threads deliver lower mechanical efficiency than standard V-threads due to higher friction from their trapezoidal geometry, but they excel at handling heavy axial loads and power transmission. [1, 2, 3]
Mechanical Advantage and Efficiency
    • Standard V-threads (60-degree angle): Provide higher linear force per unit of torque and better mechanical efficiency in standard fasteners because of a steeper helix angle and tighter fit. However, they are prone to stripping under heavy dynamic loads. [1, 2]
    • Acme threads (29-degree trapezoidal angle): Feature increased friction caused by the wedging action of their sloped flank sides. This reduces their mechanical efficiency (typically around 40–50% even when lubricated) compared to ideal square or standard tightening threads
whateg01
I'm pretty sure that's wrong.
whateg01
well I searched what has easier torque, and got this
Standard V-threads are easier to turn and require less torque than Acme threads under the same load because they have less sliding friction
60 degree threads form a bit of a wedge. This is what centers a bolt in a nut radially. That force inward or outward, depending on which perspective, is wasted as friction as it pertains to motion.
dynode
My proto puller has acme threads, from my notes
  • Proto 5/8”-12 Acme thread
  • OTC Is all 5/8-18
  • Snap-On is 5/8-18
I kind of wish I was in the 5/8-18 system so I could use snap on accessories. I've been scheming to make an adapter for a while now.
KnurledNut
n/a
Some of my newest pullers have acme threads and they have worked well.
