Precision Instruments TQ wrench
Bagherra
Virginia Beach, VA
Found this in a pile of trash my company was getting rid of.... Never used and comes with calibration certificate. Not sure why somebody bought it, cuz we dont have anything that would require a tw of this size. Anyway, supervisor told me i could have it... Not sure what i'm gonna do with it...
Wamsutta
Amarillo, Texas
I asked Google AI if there was anything on a Peterbilt truck that requires more than 200 foot-pounds of torque :
Yes, several critical components on a Peterbilt truck require well over 200 foot-pounds of torque. [1]
High-Torque Components
    • Wheel Lug Nuts: Standard hub-piloted wheels on heavy-duty trucks require 450 to 500 foot-pounds of torque to maintain proper clamping force. [1, 2]
    • Spindle and Hub Bearing Nuts: Steer and drive axle spindle bearing locknuts frequently call for initial torques or jam nut settings ranging from 200 to 400+ foot-pounds. [1, 2]
    • Suspension and U-Bolts: Heavy suspension components, torque rods, and spring U-bolts on Class 8 chassis often exceed 300 to 500 foot-pounds depending on the specific suspension setup.
If you are looking for the exact torque specification for a specific bolt, year, or model of your Peterbilt, please share the component name or model number.
Vinny
Simi Valley, CA
It was bought by mistake. Companies do that. Buy the wrong thing, have intention of returning it but it never happens.
Funny story, at work someone meant to order two 1/2" wrenches from the Snap On guy to bring next time he was around. Somehow that got entered as a 2 1/2" wrench. Thing was huge, and must've weighed ten pounds!
Cruzan80
Denver, CO
That is where the x helps... 2x 1/2" wrenches, though I am sure if someone tired hard enough, they could justify a 1" wrench! "But, but, the math says 2x1 divided by 2! So total is 1"!"
T444e
I always typed out material RFQs or orders as:
(2) 1/2"....
The 2x could lead to issues for me as I deal with pipe, tube and fittings.
rlitman
Long Island
Neat. I'd have been all over it too.
I've got a 3/4" drive split beam Stahlwille 730/80 that operates in the same range. Picked it up on eBay for lunch money. Still no idea what I'll do with it, but it matches my ...
... 2-3/8" wrench. I posted about that funny thing in another thread, but the 2-3/8" is 12.5 pounds, so I'd guess the 2-1/2" was more like 15 lbs. And I'm pretty sure it's the largest combination wrench Snap On has made. Mine is hanging in my garage. I've picked up nuts and bolts that fit it, and one pair has a magic marker on a string tied to it that gets used for labeling drink cups at cookouts.
(2) 1/2"....
I'll either switch to text, like:
seven 10mm sockets,
or make it clear the quantity is in the parenthesis by doing:
(qty 7) 10mm sockets.
redwrench60
East Tennessee
Hahaha yeah it might have been OK to buy just for garage art if it didn’t cost as much as I’d make in a month.
Treeman
Be careful and test it out. There might be a reason it was in the trash. Our workplace got a 1" torque wrench through a surplus outlet and ended up causing thousands of dollars of repair work to a commercial wood chipper because it failed on a critical fastener.
rlitman
Long Island
...Our workplace got a 1" torque wrench through a surplus outlet and ended up causing thousands of dollars of repair work to a commercial wood chipper...
I think we all know what first went through my head reading this. Don't put it in that end.
danielbuck
I like the PI split beam torque wrenches. have a 3/8", 1/2" and 3/4". Really only use the 3/4" when I'm working on my F250, for most things the 1/2" is within the upper range of what I need. I
got the 3/4" when I had to torque a few things to like #400 or so (I think it was the track bar and some other steering component). It's come in handy several times for other things though.
Especially if the 1" is free, I'd take it.
