Above 1200 Sq/FT LilScorpion’s Fab Space
L
lilscorpion
Colorado
Seems a little undercooked ? (yeh yeh too obvious a joke) :sigh:
We have these ads that frequently appear on Australian TV for Duracell Energiser Batteries. They usually have some battery powered Bunny operating past all other batteries etc etc ( do you guys have similar ?)
I have written a letter to your Duracell corporate office in USA (well, not really , can't trust us Aussies LOL) recommending you as the next Energiser Bunny, to feature state wide- no - country wide- heck no...
worldwide-
(You're welcome)
yeh, done joking:
VERY MUCH Enjoying your posts little scorpion ! (can I still call you bunny?)
Yes, we have the energizer bunny, we’ll have in years past. Haven’t seen those commercials for a while. I suppose I’m like that in some regards. If it keeps the blood flowing anyway!
L
lilscorpion
Colorado
After work i decided it was time to install a few upgrades to my fireball dragon wagon welding table. Most ends of projects start with a delivery from McMaster. Seems like I get one weekly now.
This is a storage rack that is designed to keep the welding table accessories readily available but also Tucker out of the way. Winch purchase I’ve found that keeping the clamps in a drawer is inconvenient and as a result I tend to leave them on the table which takes up a lot of space. Designed the rack in cad and cut it out of 3/16.
The concept was vetted last week so this post is purely install. All cutting, fab, and powder coating has already been done.
The grey things are inserts that allow me to customize the storage options in the future. The hole spacing of this setup matches the table - 3/4” holes in a 2x2-inch pattern. The clamps need more than 3/16” of depth to stand up correctly so two inserts sandwich the rack creating almost .600 of thickness when including the rivnut head.
The clamps sit in the rack very well amd will be very easy to grab.
The rack is tucked out of the way enough so that I’ll be able to use the end of the table without kneeing the clamps as I do
Upgrade 2 - I use a lot of pneumatic fab tools. Most are now kept on my tooling wall. Even tho the wad is almost within reach of the table I tend to not put the tools back between fab tasks, I set the on the table or stand them up in one of the dog holes. It works but inevitably I’m having to move them around as I fixture, unfixture, or weld. Decided I’d try make a tool caddy to help keep things organized.
It clamps to the table thru 3/4” dog holes on the side skirt. With the heads of the rivnuts, the surfaces sits about .065 below the table surface so long parts can still overhang the end of the table (and caddy if/when emptied) easily.
Grommets fit into .800 holes cut into the top which allow air tools to stand up nicely but are easily accessible and removable.
Voila! Tool caddy. All the extra holds and rivenuts enable future upgrades to hold custom tool racks and adapters for things like clamps and such. I’ll add as I go and see need. For now my tools will stay off the table surface.
signcrafter
Any chance you have a link to the grommets you are using? I threw together this air tool storage years ago using a 2x10 and it works pretty decent. I just drilled some holes for the air couplers to sit in but would be nice to have a little snugger fit. Need to make a new organizer for the new shop and the grommets are a great idea. Thanks for sharing.
L
lilscorpion
Colorado
Sure, don’t mind at all. 1/2” ID is key, there’s many different OD’s which may help make retrofitting your setup easier.
Buna-N Rubber Grommet for 13/16" Hole Diameter and 1/8" Material Thickness, 1/2" ID
https://www.mcmaster.com/product/9307K27
L
lilscorpion
Colorado
Another project in the pile to share - for all of my build cycles the most common challenge is managing the parts as they move between sub-processes.
I have an extreme duty shop cart which was one of six I built about 20-some years ago for my business which I use frequently. You’d be surprised to know I never coated it and it’s still bare metal. The dryness of Colorado weather is the only reason this is possible. I originally designed the powder coating oven specifically to be able to coat this beast but now that it’s done I’m not sure it will fit. Oh well.
The cart is a beast but with all “shelves” being configured as trays (concave), it’s not really ideal for sheet goods (cabinetry) or stacks of plasma cut parts that are wider or longer than the trays. I figured I need to have a plan I can use to build more easily if and when I need them in the future. This is the first of its kind but not to dissimilar to many you could find/buy. Since it’s about transporting components, I decided to make it with 4 layers and enable the shelves to be flipped into trays should I deem that a better configuration. The first go at it was close. Needed to make a few adjustments so the next one (or more) will fly together. Micro adjustments really.
After coating I tried to assembly and share it but ran out of hardware in the process ending the week stuck waiting for a McMaster re-stock.
After walking past it all week I was finally able to wrap it up this morning with only one thing left to design- the handle. I’ll do that this weekend.
As I snapped this pic I realized that my color preferences for the shop aren’t too dissimilar to Ironman. At some point I’ll want this same design in a slight smaller and lower format to use when working on cars. Maybe even half size would be cool. Another day tho
L
lilscorpion
Colorado
Got the weekend started with loading up the cart. Most of the pieces are doors for the kitchen. The top has some white maple (scraps) I’ll use for face frames as I get back into the cabinet build.
Organized disorganization but got my wood working fab table cleaned off and for that I’m grateful. And immediately Amazon delvered a kit I plan to use to seal the gaps on the barn doors.
Next I cleaned up the bench behind the lathe. I call it the tapping station at the moment. It’s the very last section of wall that does not yet have the rivnut organization panels.
I had made a ReadySaw stand that had been waiting to be coated and installed. Finally got to that.
I made two different versions - one that mounts to a 3/4” table like the Fireball Tools Dragon Wagon and one that mounts where my vises are. Idea was to be able ti use it inthenshopnor in the garage. In the shop if want to use it on the bench, the counter, or the Dragon Wagon.
Then I got back into the biggest last project needed to have the shop fully up and running - the powder coating booth. I built the base for the filter and blower motor box first.
Needed to cut spreaders next, got out the saw.
Here’s a hack - for repeatable cuts, don’t try to mess with measuring from the face of a tooth on the saw blade, instead figure out the offset once and measure from the end of the fence instead. I then write it on the first part and measure from the end instead for all subsequent parts. They end up perfectly the same with way less effort.
With the three spreaders, I fixtured and welded up the base.
Once cool, I turned it on end and cleaned off all the oil and grease.
Now to pull it all together. Brackets and lots of them make this like a bib boys erector set.
Each bracket has it location. Lots of drilling and more rivnuts.
L
lilscorpion
Colorado
Believing or not it took me a day to make and install half of them.
The 4-way intersections are probably the coolest looking. The lower tabs create a shelf so each of the shelves can be lifted one at a time and set in place.
And finally time to put this thing together
To conserve precious shop space a last minute design change was to use the shop wall as one of the booths walls. This makes the booth itself impossible to move now but I’m not sure I’ll want to. If it’s really important it could be disassembled.
The lower plenum box in place.
While building things, I always find opportunities for improvements. Building the plenum box I decided that adding a tab to the vertical on this bracket would add significantly more strength.
It does make it quite a bit more difficult to install as I have to use 1/16” shims to account for three directions of rivnut heads.
All of the holes in these brackets are .190 holes cut on the plasma table. The work hardening of the material does make it a little hard on drillbits however, the precision is amazing. Every bolt hand threads in easily.
Two full long days of progress in the shop with temps nearing 100°. Toasty.
L
lilscorpion
Colorado
Tool caddy and clamp rack are working well. For the first time in months the fab table was clean when I was starting.
The grommets work semi-ok. For smaller tools it’s perfect. For larger ones that have some weight , like the belt sander in the pic, they lay over. I’ll make some tool holders that attach to the caddy for the bigger stuff someday.
I had aspirations to work on the booth again tonight but just as I was getting started I noticed that the old tubing bender sand was rusting on the epoxy floor (which can ruin it). So I had to move everything in the corner and clean the floors. Gave them a good scrub too. First time ever.
Ill get back after the booth tomorrow night.
L
lilscorpion
Colorado
Feels like I’ve been drilling forever.
Each panel will be gasket or silicon sealed. Center panel will be rivnutted and the rest (likely) riveted. Center panel will serve as an access panel just in case I need to get inside.
All read and side panels are mounted from the inside out for a variety of reasons - easier to clean from the front, less complicated to seal, and athletics.
1 1/4 angle iron was de-scaled and welded to create lips for the panels where necessary. The bottom sheeting will ultimately be for the filter to mount.
I’ve been using a drill dr to sharpen drill bits but it’s one of the gen1’s and getting the indexing right has always been hit or miss. Feel like I’ll sharpen a bit three or for times before it’ll cut right. Too much screwing around so I stopped using it and began throwing away bits instead…but I’m only getting half a dozen holes before a bit is spent and it’s getting costly. Decided to give the Vebor drill bit sharpener a shot.
Simple little unit, ~$300. Damn thing works GREAT!! Split point 135* no problem and perfect every time.
Half a hour and all of my most used bits are better than new.
L
lilscorpion
Colorado
A belt grinder makes sharpening drill bits much easier with it's flat plane to work with, vs a wheel. Everyone should have one or more.
Agreed. That’s how did them for a while but getting smaller bits to turn out was difficult. Probably due to my eye sight starting to deteriorate more than my ability or skill (tho some days I wonder 😂). This little until allows me to drill half a dozen holes and quickly touch up the bit to Jew and keep going. Saves my hands a bit too. Duller bits create more effort than necessary and in 100* heat, I’m soaked quickly too
loganb
Omaha, NE
Another fan of that Vevor bit sharpener, I've got the same one and it's very good. Quiet, nice range of sizes though wouldn't mind if the next one went larger but I don't need it to. Especially if you're doing a number of bits of the same size so not swapping collets back and forth every time you can work thru a pile of bits quickly! Even if you're doing a collet change every couple of bits as you sharpen up a full set it doesn't take long and follow up touch up's after the point's been split are even faster as you're not removing as much material
Cruzan80
Denver, CO
I do think that is why most "higher end" sharpeners tend to run a wheel that you can sharpen with the side, rather than the "outside" edge. While the surface speed changes with the diameter of the wheel at the contact point, it doesnt have a curve to deal with.
I know there is a name for that kind of wheel, but it is late and brain is fried for the evening (I know you dont want to side-load "normal" grinding wheels).
L
lilscorpion
Colorado
Right. Once you figure out that all of it’s based on millimeters you can quickly measure the drillbit. Pick the right call it set the tip offset and you’re grinding. In some regards sharpening a full set is extremely easy for that reason. The way I’ve been doing it is organizing the bits by millimeter and then I can slam through them fairly quickly.
Grant Gunderson
Bellingham, WA
I’ve had the exact same unit in grizzly paint for 5+ years now. Damn thing works amazingly well.
I also have the end mill sharpener too.
It is equally as amazing. Somewhere I ended up picking up A bunch more collets beyond the ones that came with them that have been nice to have as well. IMG_9548.jpeg
Between those two units and this bank of cabinets being full of tooling I’m pretty sure I’m not only set for life when it comes to drill bits and end mills but my son will inherit a lifetime supply as well.
L
lilscorpion
Colorado
Nice setup! The end mill sharpener…gonna check it out now.
