Between 485 & 705 SQ/FT Jar944's 3car cabinet shop.
J
jar944
Northern VA
I wonder as well.
Did you just have those stones laying around the yard? What was the plastic that you are using for the weed barrier?
I am interested as well.
I stacked 3 pallets worth of stone as a border in early 2021 as berry (raspberry, blackberry, blueberry and rhubarb bed) the neighbors trees are too large now so we are pulling that bed out and reusing the stone
2021 beds
The black plastic is just 7 mil plastic.
J
jar944
Northern VA
Yard work looks awesome. Care to share any more on how you approached the rock border? Was it simply “I stacked some rocks”?
Plenty of single child behavior here and I applaud it. I watched my 2y/o fall 4 ft from the playset this week. As you are likely aware, that fence prevents accidental falls and encourages courageous leaps
I paid a bit more attention to stone placement and bedding a few years ago on the taller retaining walls.
larry4406
Northern Virginia
Was your ridge vent blocked solid (closed off) or just the end 2' as normal?
At the day job, our framers block between the trusses adjacent the ridge so the vent can be nailed continuously instead of just every 24" at the trusses.
Also at the day job, we use GAF Cobra vent for the ridge, but it requires a matching cap shingle.
J
jar944
Northern VA
They blocked the last two trusses. As for the vent I just matched the cheap pop can material that was there. The south side shingles were getting gritty as I walked, so it has a limited life left (19 years currently)
