Chain breakers..
cvairwerks
Within hearing distance of Texas Motor Speedway
Anyone have a decent chain breaker that will do ANSI 25 and 41 roller chains? I would prefer not to buy the PacRim rubbercheesepotmetal cheapies, but don't really want to drop a couple hundred bucks or more on a bench unit. The motorcycle and bicycle units won't do either, so they're out.
The pin heads have to be drilled rather than ground off, as any scratches on the side plates turned that section of chain into instant junk. US or European made chain stock is getting harder to find and isn't cheap.
Sumboodie
AK
Why are scratches an issue?
My chains are on logging equipment so it's not fussy.
C
cvairwerks
Scratches damage coatings, which can lead to rust or corrosion. Where these are installed, it would take from hours to days of work to simply be able to inspect them and therefore a large expense. They get lubircated well on install and some only can be seen at time of major airframe repair or rework is done.
Looks like it will probably be the Lynx 25-60. Neither model of the Smith, or the Renold will do #25, which is a .250" pitch
Sumboodie
AK
Lot of time the chain I'm using is already rusty.
Codyboy
S.E. TEXAS
Airframe?
Stop being cheap and buy the appropriate tool.
C
cvairwerks
Airframe?
Then find me a better one... The Lynx is considered a production tool, and beyond that, you get into units with specific chain size dies. The EZ Breaker manual unit runs about $600, then you have to buy each die set at about $300 each. All the other bench mounted tools I've found, won't do either size. Motorcycle shop units won't either, nor will bicycle ones. Chain saw units won't work due to pin size, without having custom ones ground.
