Canada Only Deals!
J
JradM
Alberta
I had no idea MAPP was discontinued. I've never used or needed it, even on my rust belt Subaru ball joints. But I keep hearing people referring to MAPP for high heat, so what are they referring to if it's discontinued and not this?
It's a mix of MAPP and Propane (MAPP - Pro). Propane burns at a temperature a little below 2000 C, Mapp-Pro bumps it up a little (to like 2050). The old map was more like 2500 or higher if mixed with oxygen.
I've heard discussion that maybe Mapp-Pro is better than it sounds because of some heat-transfer quality, but I'm not qualified to speak about that. You can also mix oxygen with propane to increase it's temperature, so I suppose it all depends on what you're aiming to do.
I still use MAPP Pro occasionally, when I get a good price, but it also depends on whether you have a high-heat torch or a pencil flame.
matthew
For speed? Or for a particular application?
I have managed to stick with propane for now. But I haven’t had to solder anything bigger than 1/2”, and no massive brass fittings. I’ll admit that there was one pipe where I struggled because of a small leak dripping water into the heat zone. I’ve wondered about getting a MAPP torch… not sure if I’m being stubborn or restrained…
J
JradM
Alberta
Maybe I'm fooling myself, but I feel like the yellow bottles get things hotter just a little bit faster. I understand the peak temperatures aren't terribly far apart, but Mapp Pro is still a bit higher. If I'm heating a rusted fastener, I don't have to do it as long.
It's not a dramatic difference, but I still pick up the gas when I get it for a decent price. If I'm paying $14+/bottle, I just make do with propane.
J
JradM
Alberta
Busy Bee tools is having a clearance event. Discounts on clearance and a stacking 15% off code.
Looks like there are some deals to me - I didn't bother curating a list since it depends on what you're looking for. There are power tools, accessories, consumables, machines, etc.
Need a tiny arbor press? This would be like $34:
coldh2o
Ontario, Canada
My order arrived. Regretfully, it is not a shop crane.
I did not even open the box. I could tell right away it was much too small to be correct. It says "Engine Support" on the box.
Wayfair's customer support leaves much to be desired... First I tried logging into my account and choosing "Problem with order". That askes a series of questions, but then dead-ends with a broken link to contact customer support.
Then I tried the live chat option - which obviously isn't "live" at all, it's just a chat bot. I went through all the same steps only to have it tell me I could keep the item and it would give me 20% off. Ah, no thanks. When I asked for a refund it said basically: "sorry, I can't do that".
I explained that purchase agreements don't work that way. A company cannot offer a product for sale, accept my money, deliver something different and then require me to accept it. Also, that sort of activity is defined as a "unfair practice" under Alberta's Consumer Protection Act, exposing the company to legal liability beyond a simple civil action.
That's probably unnecessary, but I was getting annoyed. At that point the bot gave me an option to communicated with Customer Service via text.
The first agent again offered me a 20% discount to keep the item, which I declined.
By then it was bedtime, but when I reprised the conversation in the morning I spoke to a new agent - who was actually surprisingly helpful and agreed to a refund and a FedEx pickup.
Assuming you get the wrong item too, perhaps this tale will help you skip to the part where you get to speak to customer service. I think you could probably just ask the bot for that and skip all the nonsense in-between.
Same here.
Delivered today, went straight to customer service and got 100% refund and free return pickup.
Relax
GTA, Ontario
Apologies to everyone who ordered one. I saw it posted by a reputable member of a local motorcycle forum (GTAM), and if it's any consolation he and everyone there that ordered one also got the engine support bar. Hopefully everyone gets their refund without too much hassle.
J
JradM
Alberta
Certainly not your fault! That looked like the hoist-deal-of-a-lifetime!
Two Speed
Ontario Canada
I wouldn't call it a hot deal, or a good hefty piece of rail at 44lbs for 24 inches (real light duty at 66lbs/yd), but one of those 'I never knew they carried this'. Railroad "anvil" at PA;
I did pick one of these up, also on clearance, little hand vice;
J
JradM
Alberta
Princess Auto put the "other" Osca ball peins on sale. The 32 oz has often been on sale, but this is the first I've seen the others.
matthew
There must be a complete refresh of the hammer offering coming. Even the Powerfist stuff has cleared out a lot recently.
Two Speed
Ontario Canada
I got a feeling they have a new supplier. They clearanced pro-point locking pliers a couple months back, and a few weeks ago a new pro-point locking pliers showed up. No visible difference between the working bits. Looks like they've revamped the logo and rubber grips on whatever has them.
Also noticed the sweedish pattern wrench has a new curved jaw design.
matthew
I hope not, but maybe. I like Osca.
I am a huge fan of Osca, too. The nylon handle machinist hammers especially. I can understand that people probably differentiate on quality less with hammers than other items.
In an ideal world, they’d have Osca private labelled as ProPoint. And do one or two annual limited run ‘special buy’ deals on a rotation of less common items. I can dream…
That said, I have I think 7 Osca hammers. And I’ve bought several more to give to my brother. There’s a limit to how many more I can use. That is the nature of selling non-disposable things.
Two Speed
Ontario Canada
I'd be curious to know the sell rate on the Osca hammers, you'll have folks like us who look at quality first, price second. Then you got everybody else just buying on price.
Yes, I realize the hypocracy of that considering we're all going to PA to get a deal on something. =-)
matthew
That is a good question. I can say it wasn’t dead stock. The production date on the 1000g hammer I bought was fairly new. And same when I’ve looked at other items. But that doesn’t tell what the margin on those were.
I’d like to claim I look for quality first. I have never been willing to have bad tools. But while I have reached a point where I can afford good ones, I still only buy great tools if they are a good price, - not just buy them regardless.
Selling something to me at a 50% to 75% premium over commodity is possible. What products can they find where the cost of the product allows that? Osca was one. Bondhus is pushing that limit. Wera, selected items yes, some no. Bahco files at Lee Valley. There’s others, but can be a thin field.
J
JradM
Alberta
A good deal on a quality tool though. Princess Auto is just arguably the most consistent place where you can find that magic recipe.
I don't think that's hypocritical. My concern is just that it won't last - that maybe PA will "learn" their customers want lower prices and phase out of the random high-end items scattered amongst the rest. I don't think that's a risk, provided enough of their customers go there for the good stuff, but you never know.
P.S. there's a Proto Duratek extra-long slotted screwdriver on sale for ~$8 right now. They also have a slotted Proto screwdriver socket bit. That's really the only Proto in the surplus section from my visit the other day - except for some tether accessories.
matthew
I think part of the trick in selling ‘forever tools’, at least for a place that doesn’t solely specialize in it, is doing so as a special buy. A rotating selection keeps people who bought the last item coming back, and gives a sense of urgency to not wait forever. Arguably the surplus section does a great job of that.
I don’t totally love that idea, because accessibility of something decent becomes an issue.
Speaking of which, I notice the NWS stuff is not at Lee Valley anymore. A shame.
J
JradM
Alberta
Oh no! Their prices were reasonable for NWS too. That brand should be more well known than it is.
I have only a couple genuine NWS pliers, but I picked up a big set of the NWS-made Irwin pliers (remember that weird collaboration?) from Cardon tools.
matthew
My favourite long nose pliers are my NWS set. If I had known they were being discontinued by LV, I’d have gotten another set, but they weren’t urgent since I had a pair…. If they had sold the duckbills of the same, I’d absolutely have bought them.
If anyone comes across a good Canadian source for NWS, I’d like to hear.
Relax
GTA, Ontario
20-gallon steel oil drain for $110 at Princess Auto. Way cheaper than the similar one from Harbor Freight even when on sale. Ball valve location seems strange, though.
jollygreengiant
Ontario, Canada
Millbank Hardware has pretty well all their Gray Tools, Gearwrench, and Crescent stuff at 25% off right now as part of their September sale.
Their website is also up and running now for online ordering.
Relax
GTA, Ontario
Mine arrived today pre-assembled with a price tag on it, in a pair of large Princess Auto cardboard boxes taped together with no protection other than a few strips of air bags. No damage to the boxes, but when I pulled it out the casters were wonky. One of the nuts were installed upside down and both were loose, but even when reinstalled and tightened, it made no difference. Was hoping to replace the plastic one I got earlier and use it this weekend for my brother's oil change. Need to take a closer look to see if the casters themselves are damaged, or if the mounting points are just bent.
I aired it up to check for leaks and it does build pressure, so functionally it seems to work. Need to re-seal some of the connections before use but they supplied a roll of Teflon tape, which is nice since I'm running low. I wasn't paying attention to the pressure while I was checking around for leaks, and it got high enough to push the funnel tube all the way up, but not out (sounded like there was a stopper) because I forgot to tighten the height adjustment set screw. I guess that's the big difference between this and the Harbor Freight which has the ball valve on the neck of the tank and requires the end of the funnel tube to be raised above it to close.
