TX4runner
Spark plugs are generally straight forward DIY as long as it's not a boxer engine with limited clearance. VW with cylinder holes pointing up should be easy (ish).
Hopefully it will be your last water pump.
Glad to hear she is back and mended up. A few more things to finish and I am sure she will provide you with many more miles of enjoyment as already has happened. Still a fantastic looking car.
Good to have the Golf up and running again. It’s similar to my wife’s 2018 Mk7.5 GTD, which she has had from new and now has roughly 55k miles. I don’t know if you have mentioned in your thread, but have you removed the silica bag from the coolant header yet? If not, that’s something you should do asap before your heater packs up in the middle of a MN winter.
Glad to hear that T & team got you sorted!
I will certainly hit you up next time I will be in the area
We are a VW/Audi household and learned the hard way. It's a question of when, not if, it will burst and clog the heater matrix. Then it's a dash out, replace the matrix, flush the system job. Unfortunately, you will still be plagued with the new matrix repeatedly blocking. Simple to avoid by eliminating the silica in the first instance.Wow, ok, somehow I did not know about that. Thanks. It seems like the easiest / safest option might be to replace the reservoir with a new one that doesn't use the silica pouch? My car came with G13 coolant, and looking at the service record I got it seems they replaced with G12evo for the water pump job. So I think that should be good without the silica?
If you can get a new reservoir without the silica pouch go for it. If not, the least risky method is to remove the pouch from a new reservoir before you fit it. However, I removed the pouch from our GTD and daughter's Touran without too much trouble.
Use something smooth and rounded, for example the handle of a spoon, to gently lever the pouch out of its clip and then you should be able to pull it out by your fingers. You may need the spoon to assist as it's slightly too wide for the opening.
I suppose that a complete drain down and refill with G12evo would be the recommended action but I don’t know how critical it is.
Our younger daughter’s Mk7 Golf now needs its third flush of the new heater matrix fitted about 18 months ago, so this is how I know that it’s virtually impossible to get rid of the residual crystals out of the system once the pouch ruptures.
Enjoy your GTI - it looks great. Wife's is Atlantic Blue which is another great colour.
I think I need one of those projectors in my room…ha.Thank you! Had to Google Atlantic Blue, we didn't get that in the states on the Mk7... yeah that is a nice color!
Small Smart Home Updates
Front Door
I mentioned this all the way back in May, but never actually installed the sensor...
I added a contact sensor to our front door to help cut down on Doorbell Notifications.
I had to 3d print a 'riser' for it to line up properly.
Basically I have a TTS (Text-To-Speech) announcement whenever a person is detected at the front door video doorbell that plays through the Sonos speakers in our house, and also my phone receives a push notification with a visual snapshot.
This is great when there is a visitor. But it's annoying when I'm just reaching outside the door to retrieve the mail. Or when we're unloading or loading the car and making multiple trips in and out and get a bunch of notifications. And slightly awkward if my kids open the door if they see someone they know coming, and then the guest hears my Sonos say "someone has been detected at the front door!!!". It always confuses people.
So... I added a simple condition to my front door automation that will only announce / send notification if the door has been closed for more than 1 min. To put it another way, if the door has opened within the last minute, it won't announce.
This is so if I open the door to leave the house or get the mail, the contact sensor will open first, and cancel the announcement. But if the door has been closed for awhile and a visitor approaches (mail man, guest, solicitor), it will alert us.
I used to install recessed sensors and care about aesthetics, but I don't mind so much anymore. I think it looks fairly clean on the white door, and not getting useless notifications is a huge win.
Kids Rooms
I've held off doing much automation or having smart devices in the kids rooms, but awhile back I added smart relays for the overhead light fixtures. And their night lights are on smart plugs so they can be scheduled.
They also listen to Yoto Players every night as they fall asleep, either music or podcasts. I recently discovered Yoto Player has a Home Assistant integration. Because of course it does...
So, I decided to add a 'Kids Rooms' page on my mobile app dashboard, that gives me quick control of their overhead light, night light, and Yoto.
My son also got this cool planet / space projector for his birthday that he likes to fall asleep to, but I don't want it on all night long:
So I added a smart plug to that, too.
Since I've come this far, I plan to add some relays to their lamps (they each have a floor lamp and a table lamp) that have inline switches. That will require some cutting and wiring and 3d printing.
But the full plan is to have scheduled scenes for bedtime and wakeup that automate all their lights and Yoto's. And make sure their lights turn off when we leave the house.
They have to wake up at 6am for school days which is completely dark in the winter, so I'm hoping a gentle 'light alarm' will help the wake up process.
We have Govee projectors in the kids' rooms that they fall asleep to. It projects and does various white noise. I want one for me now too and many of our guests that happen to see them in action also find them very relaxing.I think I need one of those projectors in my room…ha.
On the coolant. Regardless of what manufacturer’s say, I think the 4 year drain and fill is a good idea as the additive package in the coolant is refreshed when you do it. I’d also suggest that a drain/fill is all you need. I’ve done this on both EVs and our Highlander as well. Same on my A3 TDI when I had it. Every car these days tends to have a specific routine for filling and dealing with air, so these details have become important. The Highlander for example has a bleed valve at the rear of the V6 engine and needs to be run up to temp, at a fixed rpm, until solid flow is observed from that valve into an overflow funnel.
Many EVs (like Ioniq5) have non conductive coolant for the battery that needs to drained/filled every 3-4 years, or 40K miles. CH-R calls for the battery coolant and brake fluid to be replaced every 30K miles.
