TX4runner
Spark plugs are generally straight forward DIY as long as it's not a boxer engine with limited clearance. VW with cylinder holes pointing up should be easy (ish).
Hopefully it will be your last water pump.
Glad to hear she is back and mended up. A few more things to finish and I am sure she will provide you with many more miles of enjoyment as already has happened. Still a fantastic looking car.
Good to have the Golf up and running again. It’s similar to my wife’s 2018 Mk7.5 GTD, which she has had from new and now has roughly 55k miles. I don’t know if you have mentioned in your thread, but have you removed the silica bag from the coolant header yet? If not, that’s something you should do asap before your heater packs up in the middle of a MN winter.
Glad to hear that T & team got you sorted!
I will certainly hit you up next time I will be in the area
We are a VW/Audi household and learned the hard way. It's a question of when, not if, it will burst and clog the heater matrix. Then it's a dash out, replace the matrix, flush the system job. Unfortunately, you will still be plagued with the new matrix repeatedly blocking. Simple to avoid by eliminating the silica in the first instance.Wow, ok, somehow I did not know about that. Thanks. It seems like the easiest / safest option might be to replace the reservoir with a new one that doesn't use the silica pouch? My car came with G13 coolant, and looking at the service record I got it seems they replaced with G12evo for the water pump job. So I think that should be good without the silica?
If you can get a new reservoir without the silica pouch go for it. If not, the least risky method is to remove the pouch from a new reservoir before you fit it. However, I removed the pouch from our GTD and daughter's Touran without too much trouble.
Use something smooth and rounded, for example the handle of a spoon, to gently lever the pouch out of its clip and then you should be able to pull it out by your fingers. You may need the spoon to assist as it's slightly too wide for the opening.
I suppose that a complete drain down and refill with G12evo would be the recommended action but I don’t know how critical it is.
Our younger daughter’s Mk7 Golf now needs its third flush of the new heater matrix fitted about 18 months ago, so this is how I know that it’s virtually impossible to get rid of the residual crystals out of the system once the pouch ruptures.
