Good adjustable receiver hitch?
Dutchmanaz
phoenix area
I recently up sized my truck and now will need to lower the ball on the receiver hitch for my trailer. I've seen some with "indexing notches" that appear to be easy to adjust, but am unsure if that's really the way to go? Other styles I've seen use pins or bolts to position the ball as needed.
Any insights into the best all around style?
yatg
Southern Oregon
no complaints with my Andersen Rapid Hitch. Damn they got expensive.
Rusted Nut
Northern Arizona
My truck and hitch got totaled a few months back. I bought a Rhino USA adjustable hitch for my new truck. A bit expensive but a really nice set up with two different size balls, and locks. Super easy to adjust. Really god quality. Family owned, US company.
D
Dutchmanaz
phoenix area
Thanks for this. I see it on amazon they have the drop I need, and it's a litter cheaper there than on their main website. From the Amazon reviews, it seems like a solid product, and "reasonable" compared to lots of others, so I ordered it.
kbeefy
Harington, Eastern Washington
I've had to destroy a couple of them to get them apart, make sure if you get one it's properly lubed.
I just keep a collection of different stingers I've picked up at swap meets and yard sales over the years. Only cost a couple bucks. I was even able to pick one up on a roadtrip from marketplace for $20 in a pinch.
GeoBruin
I got the rhino and it has been great, but I see a lot more of the tow and stow hitches around. That seems like the go-to.
Rc_Guy
Minnesota
That seems like a complicated fix for a problem I've never had. What do you tow and what are you towing with that's improved by using that?
I tow a food trailer with 2-500lb smokers at the front as well as a Honda eu7000is generator on the tongue and the smokers usually have meat in them also and a 34’ enclosed trailer with a truck and golf cart in it.
JeepYJ
What’s the tongue weight of the food trailer?
Rc_Guy
Minnesota
Seems safe.
With all the appliances and the refrigerator and the sinks and the water behind the axle it hardly moves my 1 ton suspension, it did move the 3/4 ton we had though when we had the trailer built, but we switched to a 1 ton
Codyboy
S.E. TEXAS
How many different height trailers do you pull regularly?
You only mention one trailer.
Buy the correct length drop hitch or two and be done with it.
I've seen a lot of fancy couplers on 100k dollar trucks that probably never get readjusted for different trailers height.
Mostly just a status thing.
macs_rock
Idaho
I bought the TowSmart from Home Depot: https://www.homedepot.com/p/TowSmar...-Trailer-Hitch-Dual-Ball-Mount-9455/330092694
It was cheaper than most I found and seemed decent enough quality. I needed it on a Sunday and couldn't wait for shipping which also factored into it.
I rent a lot of trailers, so I adjust my hitch almost every time I use it.
D
Dutchmanaz
phoenix area
B&W and be done. It's a cry once, buy once equation. Congratulations on the upsized truck. I think I missed it, what did you get?
I moved up to a GMC 2500 HD, which stands quite a bit higher than my previous 1500. Admittedly, it's overkill for my current travel trailer, but I wasn't comfortable approaching max payload with a couple of people in the cab with me. Likely overly cautious, but it's one less thing to worry about.
D
Dutchmanaz
phoenix area
Thanks! Yes, I went with the diesel and hope like heck I won't regret it. I know I'll miss the mileage of the 3.0 but this bigger Duramax is a flipping BEAST!
I think I just went over 100 miles on the odometer 😂 but have only had it since last Friday,and can tell it's burning quite a bit more fuel. Hopefully it will get better as it gets broken in, but I don't expect anything like the 3.0's mileage.
And congratulations to you as well!
D
Dutchmanaz
phoenix area
How yet another thread goes from honest questions to class envy responses is disturbing.
However to those who responded with actual ideas and recommendations, thank you.
niget2002
Josephine, TX
I don’t know what everyone calls a bro dozer but around here I don’t see a lot of 2 foot drop adjustable hitch’s
There's quite a few at my daughter's high school. Big rims, little tires, 3->6" lifted truck with a big adjustable drop hitch hanging off the back.
I went with a budget model off of Amazon. It's served me well, but I'll probably replace it at some point. The B&W ones are nice and are what I usually recommend when it comes up in conversation. The neighbor uses one and I liked how it works and fits.
Bert_
NW Iowa
Never really seen the need for an adjustable hitch. All the trailers that I pull have the coupler set to about knee height. Truck hitch is at the same height.
Different truck / different trailer, doesn't matter. Nothing to adjust because it's all the same.
JeepYJ
Trashcan sized exhaust tips, tow mirrors fully deployed at all times, lights on the wheels and in the wheel wells, lots of tire tread beyond the body of the truck, blacked out windows usually with some window stickers of some tuning shop and references to Cummins or Stroke.
thunderalley3
Daytona Beach Fl
I have a B&W, it stays in the cargo area under the rear seat. I have three trailers that I pull frequently and one setting works for two of them and then I make an adjustment to height and ball size for the other.
