2002 Subaru WRX Impreza Seat bolt hole gone
ukiltmybrutha
Hi,
Was working a seat swap and one of the holes is completely blind e.g. no threads no nothing just a piece of sheet metal.
All of the other holes use M10x1.25 bolts and are threaded. I can't speak to what happened here. Maybe it rusted through and broke off?
Anyways, what is a decent remedy here? I can't get on the other side with a nut. I was thinking weld nut but that carpet and plastic here are ancient. I just have a flux core welder and it is going to spatter everywhere.
Thoughts on what to do here?
Thanks.
SMOKEYBEAR
Is through bolting it an option?
I had one on a second row captain chair in my Excursion; drilled, through bolted with a 12.9 bolt/lock nut,thick hardened fender washer and sealed it with 5200 on the underside.
U
ukiltmybrutha
I too have an Excursion. I hope that doesn't happen to me. I have never tried that technique and not completely sure I understand what it is. I would imagine that I would need the ability to hold the nut in place on the back side? If so, I can't see a spot to do that.
SMOKEYBEAR
Yea, you'd have to have access to the underside..under/ outside the car. It would all depend what is in that location. I'm not familiar with WRX's..
bwringer
Indianapolis
How rusty is that Rex? I would install a thread sert there, IIWM.
Yup, an M10 AKA "Riv-Nut" or "Rivet Nut" oughta do ya. That looks like a decently clean hole, so a rivet nut should work fine.
You can find inexpensive kits with manual mandrels on the Brazilian River that should work fine, or pay a little more for a squeeze tool.
From what I can tell, the M10 inserts are 1.5mm thread pitch, so you might need to scare up a different bolt.
You might also need to drill out that hole slightly to fit the insert.
U
ukiltmybrutha
Thanks folks it is fairly rusty but not there. Do you guys have any recommendations for an kit? I have not messed with Rivnuts or thredserts.
I am leaning towards towards a Rivnut kit because I have another spot where I would like to use one and get my money's worth...specifically the spare tire well mount.
Amazon tool kit suggestions please?
Thanks!
U
ukiltmybrutha
For pulling an M10 I'd get one of the 2 handed pullers, or one you can hook up to a drill or impact.
Alright, it will be 2 handed for sure. Just wondering about clearance. I am gonna watch some youtube so I can visualize as well.
U
ukiltmybrutha
Thanks, my son did the repair. Worked great. He tested it out in square stock first.
We decided to use a torque instead of going full uga dooga.
M10 1.5 bolt I purchased recently for Excursion starter worked a treat.
