Ratcheting Wrenches Recommendations (Flex Head Ratchet, Reversible Fixed-Head Ratchet, etc)
CC268
I currently have the Tekton SAE and Metric Combination Wrench Set, which covers 1/4" - 1" and 6mm - 24mm. I'm thinking I'd like to have some ratcheting wrenches for working on my F-150 and the wife's Lexus SUV. I will just get a metric set as I won't have any need for the SAE set (at least not yet). I am pretty torn between getting a Flex Head Ratchet set vs a Reversible Ratchet set. I'd like to stick to a more mid-tier price range. Not interested in Snap-on prices for a DIY'r. I do have some reward money at Tekton.
My questions:
  • What do you guys will be more capable for automotive use?
  • Is Tekton a good way to go? I know people like GearWrench, but it seems like it is super pricey.
  • 6mm - 19mm set or 6mm - 24mm set? The later ups the price significantly, obviously.
Thanks!
Ohio Andy
Columbus, Ohio
There are so many choices that will direct your decision.
Do you want something very long, or something short? As an example, I have these in both Metric and SAE. Reasonablly priced:
I have found that I like the ability to reverse direction and although I like those double end flexhead ratcheting wrenches, I like to be able to switch directions. That said, I use them with no problems, especially when I want a flex head or something long reaching. So I like the ability to change directions, but, some people complain that they bump the direction lever and it changes direction when they do not want that or the direction lever gets in the way.
I like my Protos, I have the set JSCVMT-22S, that I purchased from Zoro. I would provide a link, but Zoro bans my IP for some time when I navigate there using google, remove the google reference portion of the URL and then test the URL without the Google reference. So, here is a link NOT associated with Zoro. This set is expensive, but it is up to 36mm, and you probably do not need that, but, if you do. I bought this set because it was tested as being really good at removing tough bolts. On the other hand, it is a Spline drive, so if you do not want a Spline drive. It does have a reverse switch... They have worked well for me, but they are not flex-head. These are 6mm-19mm, 21, 22, 24, 27, 30, 32, 34, and 36mm. So missing 20, 23, 25, 26, 31, 33, and 35mm. I have not missed the missing sizes really. I have a non-racheting set with no skips from 6mm-32mm from Wright Tools with the 31mm from Tekton (Because Wright Tools does not make a 31mm, and I don't think that I have ever used the 31mm).
I have the Craftsman V-Series (Facom) versions (CMMT87375V), but they are not flex head, there are lots of skips 9, 10-14, 17, and 19mm.
I have a stubby flex head set from Olsa Tools (1358). My primary complaint is that it is not reversible. Apart from that, I like them, probably even more than my Blue Point set that is reversible (SAE), but I do not like the direction lever on the Blue Point set.
Also never heard much bad about the Harbor Freight ICON set, but I have not tried them or even looked at them.
I think that first you need to decide if you want (or need):
  • Reversible
  • Flex Head
  • Standard wrench with an open end or just a double ended
  • Handle Length
From there, you can narrow down what you want. I own Blue Point because Olsa Tools was out of stock on the SAE for months. I strongly prefer switchable, and I like how Proto switches, but not my Blue Point Stubbies.
Olsa Tools, with no direction lever and only from 8mm-19mm, which covers most things:
The Icon are reversible 10mm-19mm so no small sizes
https://www.harborfreight.com/anti-...ng-combination-wrench-set-10-piece-64840.html
Here is their flexible set
All of Tekton's ratcheting wrenches:
Tekton has wrenches up to 24mm, which is nice, but I don't thinkk that you can get flex head and reversible (but I did not check to see if that has changed).
whateg01
doo dah, kansas, usa
I have flex head and reversible and both sets get used at different times. I would say that the flex head is more versatile but sometimes the reversible is more convenient
C
CC268
People like what they want sometimes for nothing more than brand loyalty. I'll just say this, spend the extra cash and make sure you get reversible (with a lever) set.
Yea it seems like maybe best to start out with a reversible set.
C
CC268
Yea I mean ultimately I think I’ll end up with both sets
C
CC268
  • Reversible
  • Flex Head
  • Handle Length
Yea I hadn’t even thought of box end ratcheting wrenches. One of those things where you don’t really know what you need till you need it lol
