Between 265 & 485 SQ/FT Kwik Fab's Small Shop
PugetDude
Superstition Mountains, AZ
Naaaaw, definitely a stray!
It wanted nothing to do with me, but was trusting enough to eat as close to me as it did probably because it was starving.
If it does linger more often, I'll keep it fed. Any recommendations on an outdoor shelter, in the event that it needs one to stave off the heat?
Paging @Grizz1963
rharman
SoCal
If you’re gonna feed it get it fixed.
We have a setup like below on each of our two back porches. Kitty Tube with a Rubbermaid tub on top. The platform has PVC legs and is clipped at 45° across the front to align with the tube opening. As we call it.... The platform is the "veranda" and the tub is the "cabana".
The Kitty Tube is insulated and ventilated. They're really nice but you're probably not going to like the price. Available from Kitty Tube or on Amazon. Free shipping though.
We did these shelters after we adopted 4 ferals (or, they adopted us) in 2012 and knew they were going to be keepers. We still have 2 of them. One had given birth to her second (that we know of) litter when we found her. Pretty amazing for ferals to make it to 15 years old now.
If you keep the cat, you should look into TNR (Trap, Neuter, Return) services near you. Likely much less expensive than a local vet unless they offer some type of deal. That's what we did with ours. Fresno appears to have 3-4 offerings.
Good luck!!
Krfjkm
Charlotte / Mint Hill NC
I’ve heard to use an old igloo cooler— gives warmth in the winter
K
KwikFab
Central Valley, CA
Good luck!!
Damn you're right, those aren't cheap. Haven't seen the little guy though as I've been sick as a dog unfortunately.
I'm more worried about the heat; winter isn't really a thing out here as it never gets cooler than 40s or so. It's board shorts weather year round.
M.Brane
1 hr N/W of LA LA Land
And so it begins....
We have a black cat that's adopted us. Well he's adopted my girl. Loves her. Me not so much though I've graduated to door man. She got him fixed, and got all his shots current. We have a water bowl outside for him, but food is indoors to avoid attracting other neighborhood critters.
He's very aware of his surroundings, and very cautious. Probably why he's still around. Maybe one day he'll warm up to me, but I'm not holding my breath. The female cat we have that we inherited from some friends loves me, but she's still a little autistic *****.
rharman
SoCal
Of our 4 ferals, only one of them warmed up to us a little bit. If it was feeding time, you could pet him quite a bit. Other than that... NO way. That worked to our advantage when he had a major eye infection. Taking him to the vet would have been impossible. The vet gave us the antibiotic injection and we were able to grab him and give it to him. Sadly, he was the first to pass.
The remaining 2, and the 3rd that passed away last year, stayed feral. Feeding time is OK to open the door and, maybe, a quick pet before they realize it. When we think about it, we're actually glad they're that way. I'm sure it's contributed to their longevity.
K
KwikFab
Central Valley, CA
When I welded up those parts the other day, I was already feeling under the weather. Well later that evening I had the worst headache for the rest of the weekend.
Only now starting to feel a bit better, but I was able to get my business partner to pick up my parts for powder coat. Picked them up today and they're looking freaking great.
Even though I cut and bent 7 sets, I opted to get only 4 done so I can turn these around quickly. Already sold 2 and just posted the other 2 so we'll see how fast they go before I get the others done.
As for my press brake, I called and when I began to explain the situation (and my troubleshooting) I was met with a response saying "we'll send you a new board".
Apparently some of the boards they received did not get the "best packaging" so they've had reports of some having intermittent issues. They suspect it could be something like a broken solder joint which will be a really easy fix for me if that's the case.
For now I decided not to remove it, but the replacement does arrive tomorrow. If I get issues again with the backgauge, I'll remove it and inspect the port and the PCB for signs of any broken connections and reflow it leaving me with a new replacement board as a backup.
That's best case scenario of course.
