Ideas for Outdoor bench and vise setup.
bigredcornhead
Does anyone have a setup outside their shop for a bench and vise? I was thinking if i can get my hands on a scraped expanded metal picnic table top, i can pour some small footings, and either use some metal legs or 4x4 posts. Then add a vise either leg vise or bench top to do all my cutting and grinding outside. Keep some of the filth and grime outside. Any suggestion, ive seen a few people with vises outside might just do that instead of the bench as well.
NUTTSGT
Northern Central Ohio
How about a vise mounted on a piece of tubing that is welded to a steel rim or something similar that can be moved.
Edit: forgot steel rim
lolaetype
North Western Arkansas
All my grinding and most of my cutting metal is done outside. I don't do a lot of it, but I don't want to do it in the garage (too lazy to clean everything). I use a BD Workmate for the bench because it's easy to move around to where I need it and fold it out of the way when I'm done. I've bolted a 4.5" vice to a 12" length of 2X6 that I either clamp onto the workmate or hold in place with a "C" clamp. If I need more table area a have a 2' X 3" piece of 1" thick plywood with a 2" X 3", 2 feet long screwed on center onto the plywood. I can clamp that in the workmate and "C" clamp the vice to it.
Wish the casters were bigger.
Make you a hell of a deal on some new Grizzly 6-inch "all terrain" casters, but shipping would be deadly. Maybe I need to go check out the Wallowas. :unsure:
I found a home-made, rolling metal work cart. My plan is to go over to Earthwise Salvage, have them slice me off a couple pieces of 1-1/2" butcher block, glue them together side-to-side to make a top with an edge around the perimeter which will allow the top to be dropped onto the top of the cart but not slide off, and make a provision for a "quick-on/quick-off" little 4-inch Taiwanese vise I have out in the garage. It would be light enough I could just lift it off or put it on as the situation calls for (as I actually rarely use a vise.)
bigredcornhead
I use this with grinding and dirty ****…I have a nice Vice mounted to a 2” receiver tube that slides into that mount. Works great and gets the vice outa the weather.IMG_5637.jpeg
Now this is what I'm talking about thanks for sharing great idea on the hitch receiver also!
tarmy
Nor Cal
I will try to remember to take a pic of the vice mounted I made and with it installed. You need a big bolt or handle to secure the vice when the BFH comes out…
tool_scrounge
Southern California
Find a vintage cast iron machinery base for cheap. I knew a scrap dealer who found an old overhead pin router cast iron machine base and used that as a nice stand for a vise. Very heavy and he liked the style. The entire top of the machine unbolted and he just added a steel adapter plate for the vise. The fully assembled pin router (image found on the internet) is shown below.
The Metric System
For years at a previous shop I had a ~ 3' x 5' outdoor workbench adjacent to the garage, it was great for exactly the type of dirty work you describe: anything that generates chips/dust/smells/fumes that I didn't want in the building.
A few tips based on what worked well for mine:
  • Build the top out of pressure treated dimensional lumber rather than sheet goods or expanded metal. Something like 2x6s will allow rain to drain through but give you a mostly solid surface that small hardware can rest on safely. If a single piece degrades or is damaged it's easy to replace piecemeal.
  • A cheap no-name knockoff vise will likely work well for the sort of light-duty fixturing you will be doing out here, you don't need something good or fancy. Presumably you have a better vise indoors if you really need to get medieval on a workpiece. The cheap vise I had on mine had some cosmetic rust but otherwise held up fine to the weather; consider all the service trucks you've seen with a vise permanently mounted to the rear bumper exposed to vast amounts of salt and road spray.
  • An air line within easy reach of the bench is handy to blow away those chips and dust you are creating.
  • Get in the habit of checking for wasp nests before you start using the bench. A bunch of stinging insects coming after you when you have your hands full with a grinder is no bueno.
bigredcornhead
As promised…IMG_5776.jpegDang Hip, i want your vise too that is my grail vise, been looking for some time, i will find one eventually!
All great tips need to him my local salvage yard for some expanded metal.
SMOKEYBEAR
I just recently did this project, my version similar to others.
1SG
Near Spokane, WA
Thomas Payne built a heavy duty bench to roll in and out, called it the PDR (Portable Dirty Room). The bench can be seen beside the welders in post number 1. Links from the index of the "Restored 1930's Auto Shop":
Project PDR start, post #5366:
http://garagejournal.com/forum/showpost.php?p=2463700&postcount=5366
Laying out the table for PDR, Post #5380:
http://garagejournal.com/forum/showpost.php?p=2469925&postcount=5380
Project PDR makes its way to the powdercoater. Post #5385:
http://garagejournal.com/forum/showpost.php?p=2481863&postcount=5385
Construction details on project PDR. Post #5414:
http://garagejournal.com/forum/showpost.php?p=2488723&postcount=5414
m.d.hunter63@hotmail.
I used a semi drum brake 4 inch steel pipe and 1/2 steel plate welded to the top. Welded an eye bolt to a piece of 1 inch plate, clamp the eye bolt plate in the vise jaws, and move the vise anywhere on the farm that I need it with the tractor
Shiftless
East Bay SFO
tarmy:
I too admired your good taste in selecting such a great vise. In case others don’t recognize it, that vise is a Craftsman 5191 dating from the early 1950’s.
nadogail
Coronado, CA
My Buddy brought me a truck tire and rim. I added tabs to a length of 4” schedule 40 pipe and bolted it to the rim.
The advantage is that the wheel and tire can be repurposed to fit on a truck again.
tarmy
Nor Cal
tarmy:
That was my dad’s and has been kept for decades…I have my gramps one too…circa 1955image.jpgimage.jpgimage.jpgimage.jpg
