New aluminum trailer project
Drkuhar
Girard, IL
Well I decided I needed to find a trailer to haul my deere 1023 and attachments and wanted an aluminum trailer. I found one being sold through an estate sale that needed work and was close. I normally think purchases through but jumped the gun on this and it needs more work than I counted on.. was told it needed tires and suspension equilizers and a couple of broken boards.
The bolt on fenders had cracked welds all over from bouncing around with the suspension messed up, the the brakes where shot.. I so far have replaced the equilizers and shackles using a wet kit that can be greased. I repacked the bearings and reset the bearing nuts. Removed the damaged brake parts for now(magnets were broke off and bouncing around in 3 wheels and shoes were contaminated with grease on 2 and liners were off the shoes on 2)..
To fix the fenders I am thinking of getting stainless bolts and bolting the backing plate to the curved fender top and putting thread zerts in the frame to bolt the fenders to..
I have found some cracks in the frame area where he had a winch mounted. I am going to get it to a shop to get welded up. I can build anything out of steel but don't have the aluminum spool gun or argon for my welder. At what price point would you say say enough is enough and try to cut your losses. I'm probably upside down in this thing. It's a 2016 10k gvwr trailer with alum ramps
dcg9381
Austin, TX
I wouldn't. I'd buy the equipment to weld aluminum... If I was lazy (and I am) I might take it to a buddy with a TIG.
That's pretty shot, but that stuff is easy to replace and needs to be gone through anyway. Honestly, I've seen that type of bushing wear out of trailers that are 2 years old and used "not much". First thing I do on new trailers is throw that **** away and go to "wet" bolt kits and brass bushings and heavy duty shackles. I've been known to completely start over with new axles if the brakes are shot and everything is rusted.
Trailer will last you "forever" once you get it sorted. That's a $10k (new) trailer around here...
D
Drkuhar
Girard, IL
I don't mind doing the work. Just worried I was getting upside down in this. But if your price is right I got a ways to go
bugnut
Central Ohio
used market here is $7k or so, except the welding, looks like mostly bolt on items, parts and labor. Good luck!
Sweetcorn
North Central Ohio
Stressed aluminum micro fractures and many/most times you will find that even if you do everything right, you will be chasing cracks forever.
Others will disagree but it is what it is.
jack stand
Lakes Region Maine
^^^ this.
I don't think that by just replacing a steel designed trailer with aluminum components is successful in the long term unfortunately.
