Drkuhar
Well I decided I needed to find a trailer to haul my deere 1023 and attachments and wanted an aluminum trailer. I found one being sold through an estate sale that needed work and was close. I normally think purchases through but jumped the gun on this and it needs more work than I counted on.. was told it needed tires and suspension equilizers and a couple of broken boards.
The bolt on fenders had cracked welds all over from bouncing around with the suspension messed up, the the brakes where shot.. I so far have replaced the equilizers and shackles using a wet kit that can be greased. I repacked the bearings and reset the bearing nuts. Removed the damaged brake parts for now(magnets were broke off and bouncing around in 3 wheels and shoes were contaminated with grease on 2 and liners were off the shoes on 2)..
To fix the fenders I am thinking of getting stainless bolts and bolting the backing plate to the curved fender top and putting thread zerts in the frame to bolt the fenders to..
I have found some cracks in the frame area where he had a winch mounted. I am going to get it to a shop to get welded up. I can build anything out of steel but don't have the aluminum spool gun or argon for my welder. At what price point would you say say enough is enough and try to cut your losses. I'm probably upside down in this thing. It's a 2016 10k gvwr trailer with alum ramps
