1/4" Hex Bit Mini Ratchet Options (Mac, Matco, etc.)
centerknurk
I find myself frequently encountering tight situations where I need to get a 1/4" hex bit in a small space but I can't get them there via a screwdriver-type driver. I need something more 90 degree-ish that can ratchet.
I found this Mac one that looks pretty cool. Double flex end, flat handle, very compact: https://www.mactools.com/products/s...3jdltDL_NR1XVHnlyalFJqiOVQcjY83rNbIUTXIdDQAxU
What's important to me if the clearance between where the bit sits and where the end of the ratchet head is (see picture). Looks like Matco makes a ratchet that's pretty small as well but it's a little bigger than the Mac one. Problem is, the Mac one is $85. Anyone know of an alternative? Anyone own the Mac one and can comment on it's quality?
Dave455
Sussex, England
The problem you encounter is all too common. Some years back Bit ratchets were in the “occasionally useful” category, but now they seem to be needed regularly.
You basically have two options. One is the bit ratchets that are essentially variations of 1/4” square drive ratchets. The second is to go for something designed as a bit ratchet. If you need minimal head size, then it is definitely the latter you need.
Almost all of these are made in Taiwan, generally by Hi-Five, so I would see no advantage in paying truck prices. Just pick the variety that you like.
I like the Facom R-PE, and use mine probably the most of any. I appreciate Facom can be difficult to obtain in the U.S. but is the same tool available as Craftsman V Series?
Also by Facom is the R-180, which offers a flex head. Be careful with flex heads on bit ratchets as you often need some downforce to make them work, but this is one of the better ones as it locks.
About the most compact I use regularly is the Wera Zyklop. Every time I use this, usually in a confined space, I marvel at the design. The head is relatively small, the handle just enough, but note how it is cut away just behind the head to enable maximum swing.
Like all these ratchets, the bit holder has a recess behind for finger pressure, and I find this invaluable too.
I have a fair few bit ratchets (more than this) so can offer a rundown of any if needed.
Dave455
Sussex, England
What's the one that's horizontal at the bottom called? My buddy gave me one years ago and it's one of my favorite ratchets, but the name has been worn off.
That’s a Facom R.PE360.
For those not familiar with the design, it’s incredibly clever.
You can use it like a regular ratchet, albeit a “flip over” style. This itself is quite clever for a bit ratchet, and there‘s a free floating spacer that provides a stop for the bit, but enables it to be easily removed.
Now the clever bit. Twist the handle (e.g. clockwise) and you can turn the bit clockwise, without moving the handle about any other axis.
Now the really clever bit, twist the handle anti clockwise, and it also turns the bit clockwise….! This results in a really fast action.
Some folks have said this is the same as the “sidewinder” of the 1990’s, but I’ve got one of those, and it’s not. This is a much more advanced mechanism.
There are relatively few job where this design is essential, but when you encounter one, these can save you a lot of work.
Tarantula
Doesn't Harbor freight sell a bit ratchet with a swivel head?
They do have two versions in the Icon line. Affectionately referred to as the meme tool by its fans. The classic model here is probably my favorite tool in their catalog just for having something I can throw in a pocket and go with.
Handy little thing for awkward angles or tight spaces. No unlocking the head for free swinging though.
IMG_20260902_163605985_HDR.jpgIMG_20260902_163643646_HDR.jpgIMG_20260902_163722989_HDR.jpgIMG_20260902_163803897_HDR.jpg
Steel_Rain
A true, first class reply from @Dave455
You are a GJ legend sir! +1
Ohio Andy
Columbus, Ohio
Many are discussed here:
Including extensive comparisons.
I really like the look of the MAC because of the double flex head, makes me think it might get into some really interesting places.
Dave455
Sussex, England
I feel honoured!
I possibly got into bit ratchets at an early stage. I can recall when they were pretty much a dedicated aerospace tool, but that didn’t last.
Sometimes a bit ratchet is the only option, but I’m an exceptionally lazy individual, and often a bit ratchet saves me having to remove no end of stuff. Some BMW header tanks (the ones that split, which is actually most of them) come to mind.
But I’ve used mine even in domestic situations, working behind a hot water tank, and doing electrical work. I carry one in my road box now.
Dave455
Sussex, England
One thing I would like is one with slightly longer reach.
This Gearwrench might be a good option, but I have heard mixed things.
I would have total confidence in this Tone, although it is slightly shorter.
With regard to best value, I can’t really comment on the U.S. but in the U.K. and Europe these Toptul can be had for the equivalent of 40 USD.
Ohio Andy
Columbus, Ohio
The 45 piece set had been ok for me, but I don't use it often because of where I store it.... So I only use it when I really need it. About $50 today
Ratchet alone is $32
Tone set is also about $50 with only one ratchet
The toptul set is $90, is it really worth that much more? Never tried they're stuff.
Even vim has something similar... I like all the other things I have from them, but I have never tried that variety (about $40, but only three pieces)
Dave455
Sussex, England
Dave is the best honestly.
You folks are too kind!
About the same price for me. I might be tempted…!
That’s still a good price I think. The Tone obviously uses the same “reverse gear” ratcheting mechanism that most of the Taiwan made tools do, and it’s decent. Like the metal box too.
Sadly, I don’t think it’s worth anything more. The attraction where I am is the price!
I feel honoured!
You are one of a very few here who have something more along the lines of a "comprehensive view" of what's available on the market, and how various brands perform, with what appears to be a fairly minute degree of "confirmation bias".
The "bit ratchet" thing has been going on for several years now.
Different manufacturers are taking stabs at it.
I do not think that all of the manufacturers actually have a grasp of the reality facing a modern-day "automotive repair technician" when he opens the hood of a late-model car to replace some widget.
The tiny Utoku would be a solution, if they hadn't maddeningly put a 1/4" square drive anvil on the other side of the head. I wonder if it could simply be sawn off?
Steel_Rain
I have quite the variety at home, but I do tend to favor the Wurth and Wiha most often:
I picked up one of these a few weeks ago. https://www.amazon.com/dp/B09T9J8N5Z?tag=atomicindus08-20
Very small. Seems well made, but I obviously don't have a lot of use on it. Made in Taiwan.
Excellent choice @LeeG , I also picked this up recently:
Like @Dave455 already implied, the use case really decides what's best for your needs. For me, being a GJ member, I just want them all :ROFLMAO: .
CoconutPete
Charlotte, NC & Denmark
Thank you!!!! I love that little thing.
LXCam
I can’t add to the wealth of info already provided. I’ve got a really good assortment of the small stuff as well. But what I did want to point out is the gearwrench extra long ratchet that I more or less bought as a joke has become a major go to unit. I can’t tell you how many times that extra length has made accessing a small area so much easier to manage. Not having your hands or fingers in the same 4” space can be a godsend.
u2slow
BC
I have the Canadian Tire version, and ordered a couple other cheapos from amazon, for work.
I dont use them often or for high torque.
orangeblood
Texas
Take a look at the boxed set from Felo. there are few variations (different bit assortments) of this set but i like this one because of the variety of bits.
Felo Bit Ratchet
Mini ratchet 1/4" Hex
Adapter 1/4" hex to square drive (30mm)
Bit Holder 58mm
Slotted: 1/8", 3/16", 1/4"
Hex (Metric): 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm
Phillips: #0, #1, #2 (x2), #3
Pozidriv: #1, #2 (x2), #3
Torx: T6, T7, T8, T9
Security (Tamper Resistant) Torx: T10s, T15s, T20s, T25s, T27s, T30s, T40s
