Beerhippie
Far NE Oregon
Surprised you didn't make your own.
I intend to use this primarily as a recovery point. A recovery point failure can result in injuries or deaths. I figure letting someone certified in welding do the job makes good sense.
A man's gotta know his limitations--and it was $175, which I figure is a pretty good deal.
regguy1
On Mount Olympus with Zeus
I did a brake job on the 2019 Chevy Colorado. This vehicle belongs to a good friend of mine who is also a doctor and he always gets me in appointments immediately so I wanted to take good care of him he uses this truck to tow his boat where he goes fishing out on Lake Erie. Before I disassembled everything I cleaned the calipers with degrease, rinse them with water and blew them dry then I painted the calipers with cast blast paint so they look nice I want to give him a deluxe detailed job. I bought drilled and slotted rotors and ceramic pads with hardware / when I remove the rear rotors one side had no lining on the parking brake shoes so I had to replace those too. Everything was so rusty it was really time consuming to make everything just so.
KwikFab
Central Valley, CA
Make it even safer for you and everyone around you and implement the use of soft shackles.
I carry my dampener inside my tool box along with my recovery gear - a dampener is a huge life saver by itself.
2001ZR2
Kansas City
Decided that today was a good day to tempt fate.
Got the ladder and Chainsaw out....found my chain was dull. Discovered the file I had set aside to sharpen it was too large.
Found new chain right where I put it but the fact I remembered where it was and found it in 90 seconds was disorienting.
Cut a 5 inch limb over the driveway but moved all the vehicles first.
Cut and stacked the big pieces but since it was 100 degrees today I quit. And I'm *******. 4425.jpg4424.jpg
rd65
Granite Falls, WA
Got a couple hours worth of work done on the 4runner. RR trans input shaft seal, reinstalled the mounting plate. Whoever worked on this last used red rtv for sealant but did not seal the bolt threads. Lots of cleaning needed. I used MotoSeal to seal the plate and bolt threads. Plan is spend more time working on this tomorrow.
Motorman55
South Jersey
Slow but sure....
Ordered a black 33" L battery power tool organizer from Walmart. Went together with no hiccups. I mounted it between the WEN drill press and the Craftsman tool boxes. l had to notch out the top right corner of the red pegboard to clear the motor's capacitor otherwise the installation went smoothly too.
The organizer came with a 4 receptical extension cord with a on/off switch. I fastened the cords from both the drill press and the bandsaw up the side of the pegboard. Also ran the Bauer battery charger to it.
Working on the right side of the garage, I removed a small Craftsman drill press and a 18" L, 3-drawer Craftsman toolbox ( which I placed on top of the other Craftsman boxes ), then disassembled the 5' Lx 2" D metal workbench. Next I mounted two 18" L gray metal drawer cabinets under the matching 36" L gray steel shelving.
Tomorrows task(s)
1. Remove the metal 30 drawer cabinet from the right side wall.
2. Box up a lot of the spillover, some to keep and others go to the kid along with the drawer cabinet.
3. Patch all the holes in the wall and paint it white primer.
Heres a couple pics...1788401352477.jpeg1788400778253.jpeg1788400728425.jpeg1788400667201.jpeg1788400436235.jpeg1788400362297.jpeg
Got 'er done!
Still have access to the receiver pin?
rharman
SoCal
With the number of people on this forum, I'd be surprised if no one offered to print something for someone just because.
Agreed. So many people here willing to help - it's awesome.
But, if you can get it local it would be quicker and cheaper. Nice to support your community resources as well. Tough to do an iterative process though.
rharman
SoCal
Planter upgrade time !! It's getting DeltaForce hydraulic up/down force, electric drives and all new seed boxes and wiring.
DeltaForce and one box installed. I gotta move the latches for the boxes tonight and the rest will be ready to go on !!
All kinds of new parts !!
I understand it's an investment as opposed to an expense, but.... YOWZA. I wouldn't want to write that check.
rharman
SoCal
But once again, the warning to "do what you oughter, add lye to water" seems to be what you missed. The difference is, adding the lye crystals to water dilutes them immediately--and water can soak up a hell of a lot of the heat that is released by lye dissolving in water. Adding water to lye leaves you with too little water to dilute or diffuse the heat fast enough. You're lucky it just got hot--often, the water flashes to boiling, resulting in a lye volcano. Lye eats flesh--did I mention that? Lye in the face *****.
Same rule applies to concentrated acids.
Learned that in my first chemistry class in high school. May have already known it - it was kind of a long time ago. :dunno:
jblnut
In the Middle of MN
That’s older Mikes problem. He can do it towards the end of October when the bill comes due 😂
This is just SOP for farmers. Respect.
For some it is. For us this is a major investment. It’ll be close to $50k when it’s all up and running again. A new planter with the features we’re installing is close to $200k so this is quite a bit less expensive.
I totally get that. As stated, I understand it's an investment - with an associated expected return on that investment.
Skipping a paragraph of math I expect a return in around 6yrs between increased yields and input savings. Plus there is a “it’s easier now” factor that is hard to put a number on.
rharman
SoCal
And, cheaper.
jblnut
In the Middle of MN
And, cheaper.
Yes but it is still $50k’ish and the return is subject to whatever Mother Nature wants to let us have lol
I’d rather spend money on the planter as a choice than repair bill for the terrain following system for my sprayer. Sort of feel like I got railroaded into that one. “Oh the system you have is obsolete and you won’t be able to get parts”. “Yeah BS I can find anything”. Well I can’t so I had to spend more than the sprayer is worth to make it work again AND I just got the stuff a few weeks ago so I couldn’t use it for spring applications. Not real happy about that spend.
Fordguy1964
Houston County, Alabama
Stage 2 of my gas tank sealing. This is the etching stage. So far so good. Sloshed around the solution for almost 2 hours then flushed with water 3 times. Placed the tank in the same location again where the sun will cook it dry once again. Tomorrow is the last stage. Finally to the sealing stage.
Ordered a new carb for my Muller concrete mixer. After sitting for over 15 years it decided it wouldn't run right without being almost 100% choked. Found a Chinesium carb on the Jungle website. It was so cheap I couldn't have bought 3 cans of carb cleaner for what I paid. I also got a new air filter, gaskets, fuel hose and fuel filter for less that $20! I have a project at work that I will need to use the mixer. It's a good of a time as any. It really needs a paint job. I'm not sure yet if it will get it or not. I don't really use it enough to keep it but I'm bad about not selling tools.
While on the Jungle website I went ahead and ordered an ultrasonic cleaner. I'll be using that to clean the carb for the K code. I got a big one so it is big enough to put the whole carb inside. I've never used one before. I've been told that they do pretty good but to be careful using any cleaning solutions because they will turn aluminum dark. I'm going to try it first with water only and see how that does. Anyone have experience using these? It is supposed to arrive by Saturday.
kaymccampbell
Upstate New York
Ordered a new carb for my Mueller concrete mixer. After sitting for over 15 years it decided it wouldn't run right without being almost 100% choked. Found a Chinesium carb on the Jungle website. It was so cheap I couldn't have bought 3 cans of carb cleaner for what I paid. I also got a new air filter, gaskets, fuel hose and fuel filter for less that $20! I have a project at work that I will need to use the mixer. It's a good of a time as any. It really needs a paint job. I'm not sure yet if it will get it or not. I don't really use it enough to keep it but I'm bad about not selling tools.
Put your part in a baggie with your chosen cleaning solution, then float that in the water in the ultrasonic cleaner. It keeps the machine tank clean and still works well. I put distilled water in my tank. Since it's pretty much a one time thing, it's cheap and clean.
I put a couple drops of Dawn in the baggie full of water, too. It hasn't ruined anything so far.
