I'm tempted to replace the knobs with nuts for more security.
Maybe 12 pt nuts so they aren't just a crescent wrench away?
Also, is the Pulaski USFS stamped?
FSS. You leave it in the woods, you lose.is the Pulaski USFS stamped?
By "security" I was thinking more of "not falling off".Maybe 12 pt nuts so they aren't just a crescent wrench away?
I intend to use this primarily as a recovery point. A recovery point failure can result in injuries or deaths. I figure letting someone certified in welding do the job makes good sense.Surprised you didn't make your own.
A man's gotta know his limitations--and it was $175, which I figure is a pretty good deal.
Good thinking!Cut a 5 inch limb over the driveway but moved all the vehicles first.
Looks like I'll be making a goof plate.
Got 'er done!
Failure to really think out my lay-out. Total beginner mistake--cutting the wrong end of the cut.Failure to CAD?
Yep. The receiver was designed for this bumper. I wanted to save $150 by modifying that center piece myself, so I bought the receiver only. Did a bang-up job of that.Still have access to the receiver pin?
With the number of people on this forum, I'd be surprised if no one offered to print something for someone just because.
I was wondering if you need a bungee or some other backup retention in case the nuts shake loose.By "security" I was thinking more of "not falling off".
It's eight feet off the ground and I take the ladder off if I park anywhere sketchy.
This is just SOP for farmers. Respect.I understand it's an investment as opposed to an expense, but.... YOWZA. I wouldn't want to write that check.
I totally get that. As stated, I understand it's an investment - with an associated expected return on that investment.This is just SOP for farmers. Respect.
Learned that in my first chemistry class in high school. May have already known it - it was kind of a long time ago.But once again, the warning to "do what you oughter, add lye to water" seems to be what you missed. The difference is, adding the lye crystals to water dilutes them immediately--and water can soak up a hell of a lot of the heat that is released by lye dissolving in water. Adding water to lye leaves you with too little water to dilute or diffuse the heat fast enough. You're lucky it just got hot--often, the water flashes to boiling, resulting in a lye volcano. Lye eats flesh--did I mention that? Lye in the face *****.
Same rule applies to concentrated acids.
That’s older Mikes problem. He can do it towards the end of October when the bill comes dueI understand it's an investment as opposed to an expense, but.... YOWZA. I wouldn't want to write that check.
For some it is. For us this is a major investment. It’ll be close to $50k when it’s all up and running again. A new planter with the features we’re installing is close to $200k so this is quite a bit less expensive.This is just SOP for farmers. Respect.
Skipping a paragraph of math I expect a return in around 6yrs between increased yields and input savings. Plus there is a “it’s easier now” factor that is hard to put a number on.I totally get that. As stated, I understand it's an investment - with an associated expected return on that investment.
Yes but it is still $50k’ish and the return is subject to whatever Mother Nature wants to let us have lolAnd, cheaper.
Put your part in a baggie with your chosen cleaning solution, then float that in the water in the ultrasonic cleaner. It keeps the machine tank clean and still works well. I put distilled water in my tank. Since it's pretty much a one time thing, it's cheap and clean.Stage 2 of my gas tank sealing. This is the etching stage. So far so good. Sloshed around the solution for almost 2 hours then flushed with water 3 times. Placed the tank in the same location again where the sun will cook it dry once again. Tomorrow is the last stage. Finally to the sealing stage.
Ordered a new carb for my Mueller concrete mixer. After sitting for over 15 years it decided it wouldn't run right without being almost 100% choked. Found a Chinesium carb on the Jungle website. It was so cheap I couldn't have bought 3 cans of carb cleaner for what I paid. I also got a new air filter, gaskets, fuel hose and fuel filter for less that $20! I have a project at work that I will need to use the mixer. It's a good of a time as any. It really needs a paint job. I'm not sure yet if it will get it or not. I don't really use it enough to keep it but I'm bad about not selling tools.
While on the Jungle website I went ahead and ordered an ultrasonic cleaner. I'll be using that to clean the carb for the K code. I got a big one so it is big enough to put the whole carb inside. I've never used one before. I've been told that they do pretty good but to be careful using any cleaning solutions because they will turn aluminum dark. I'm going to try it first with water only and see how that does. Anyone have experience using these? It is supposed to arrive by Saturday.
