Gerstner Leatherette Restoration
Ohio Andy
Columbus, Ohio
Yes, a ridiculous hobby for sure. All those stamps should be applied to letters and posted.
I inherited so many. I've been purposely writing letters. Just trying to use up a bunch of the low value ones...
Some stamps are only available from the post office and rolls of a thousand or more. So who buys the whole roll to get a couple? My dad, my dad did that... Rolls of $0.04 stamps, $0.05 stamps....
AEAdam
SE PA
Here the hardware after soaking it in the remover. I think I can sto here.IMG_0534.JPG
What’s the plan to stop rust, spray lacquer? Consider cold bluing? What are your options? I feel like I’ve been here before and never had a good answer.
P
pocosso
Ravenna
My plan is to keep brushing with Brass wire dremel the use some wax to protect the metal. I like to patina and I do not want to cover it. Someone suggested me to spray it with transparent lacquer, I am still trying to understand what is the best solution but actually I think I will leave it natural.
P
pocosso
Ravenna
Guys,
I finally found the Leatherette I was looking for, not extremely cheap, but very similar to the Gerstner one and no crazy shipping fees to get it.
After may researches and thanks to your inputs, I found this one that match.
Here the link.
Can't wait to start glue it to the chest.
I also bought some Rabbit skin glue. Will see.
D.
P
pocosso
Ravenna
I finally decided to polish the hardware with some scotch-rite tools, will keep you posted...
P
pocosso
Ravenna
Another Update,
just removed the original old Stain from the drawers, removed the metal bottoms, cleaned and sprayed with primer. Next step I will paint with Brown acrylic spray the metal and the Wood with Vintage Oak Stainer.
P
pocosso
Ravenna
Here the drawers withe the Metal Bottom installed.
Not yet definitive wit the spikes as I am thinking to sand the internal side. External has been cleaned with Isopropyl alcohol to remove residuals of paint remover.
DaveAndStuff
Bangkok
I would nickel plate the hardware.
DaveAndStuff
Bangkok
It was one of the option, but honestly i like the patina that remained on it after the treatment. Not sure yet but i think i will skip it.
Suit yourself, and they look great as is, but you have removed all the zinc, and uncoated they will rust.
Are you keeping or selling it?
gahrajmahal
Cincinnati, Ohio
I am thinking to keep it, rust is my concern, what about if i paint with transparent? What do you think?
Lacquer is pretty soft and will easily scratch off of bare metal, especially if you choose to use spray can paint. A more durable clear would be automotive clears that use a hardener. Even powder coat would wear off if you are using your restored box and moving it into and out of your vehicle and taking it to a job site. I don’t mind a bit of surface rust either and I would have done as you did and just buff all the hardware with a wire wheel.
I’m really enjoying your thread and am learning a lot. I had not heard of the product called “Tolex”. I do not know if we could easily find the “leatherette” that you are using here in the states. It’s looking great!
P
pocosso
Ravenna
I bought Tolex, but to be honest it is too soft at the touch, nothing bad on it, just different than the original one. I found this one in UK it is not for fourniture but for book covering, more paperish and AXA Lt same feeling that the old original one.
P
pocosso
Ravenna
Some one mentioned to use some kind of wax to prtect the hardware from the rust, not sure what to use, any idea?
DaveAndStuff
Bangkok
A good clear coat would if untouched would be okay, but everywhere the hinged and clasps and whatnot rub, I think it will inevitably rub off. I know there are some hard-coat products that would likely work, but I don't think there are DIY and it would likely cost much more than nickel plate.
If you are only going to display it, laquear may be okay. If you're going to use it, probably no.
To be clear, you've poured a lot of heart in this thing, and I think it looks outstanding. I would absolutely go with the original hardware.
Beerhippie
Far NE Oregon
I use this stuff:
Not cheap, but I'm less than halfway through one of those tubs after over ten years and have waxed a LOT of things with it.
Ohio Andy
Columbus, Ohio
I use this stuff:
I second that, it costs a lot but it lasts forever. I still haven't finished my first container of it and I've had it for a very long time. They like to use that in museums.
Beerhippie
Far NE Oregon
According to the can, it was formulated with the British Museum for preserving everything from wood to leather to metal--ferrous or otherwise.
I've waxed over a hundred of my gasoline lanterns from the single can, plus lots of other things.
How much you buff it determines how shiny it is, from satin to high-gloss.
JradM
Alberta
I would nickel plate it. It won't preserve the patina per se, but you don't have to take the metal all the way to a high polish first to get the protection. It's cheap and not that hard to do.
Barring that you could heat up the metal and dip it in oil, rust blue it (there are professional products, but you can do it with some vinegar/water/salt solution to initiate the effect, then just boil the parts to turn the rust black and polish with steel wool), multiple thin coats of BLO, parkerize with POR-15 metal prep, heat and brush it with a pure brass wire wheel... what color you want?
