Sawstop Base Jack
LOW1
ontario
Yesterday I had to replace the hydraulic jack in my Sawstop table saw’s industrial mobile base. It’s a pain in the rear sort of job for one person and involves a big *** pry bar. Fortunately my neighbor wandered by looking for his afternoon beer and helped.
I am a bit miffed that the jack in an expensive Sawstop base would not hold oil. My Harbor Freight floor jack manages to do so.
matt_i
SE Michigan
U cup or o ring (?). Either can cause a hydraulic leak. If you could source a replacement you might be back on the road.
strength_and_power
If the saw still saves fingers, a jack is pretty minor in my book.
strength_and_power
Agreed. But in my view a high end mobile base should do better. It’s like the steering wheel not working on an Audi.
That problem is usually the loose nut behind the wheel 😂
Hydraulic jacks IME, fall into two categories, one that you use and abuse for years and they just don’t die and others that fail sometimes while still in the box.
