Shortest 3/8 " drive extension?
YoshiMoshi3
I know tekton makes a mini extension set that is likely the world record for the shortest. But they are chrome. Does anyone make mini impact extensions? What is the shortest. I was in the situation where my 3/8 extension was to long so I had to use chrome. Had I had a shorter impact extension I could have probably used an impact and it would have been faster. I know Harbor Freight has a 3/8 drive one that is 1 and 3/4 long. Are there shorter ones out there?
OldDoItAll
Oklahoma
google.com can be your friend too.
It's a good tool for finding most anything in this world we live in. It'll also tell you who will sell it to you.
finn
The UP, God's country
My forty year old Craftsman and sixty year old SK chrome short extensions work fine on an impact, although I typically just reach for a deeper impact socket in a case like this.
Nobody-named-Olli
nicks78camaro
Pittsburgh, PA
Just use the Tekton mini
Twisted Sid
CA
Y
YoshiMoshi3
The Astro Nano adaptor is about as short as you are gonna get. It also comes in wobble plus.
https://www.astrotools.com/product/5pc-3-8-nano-drive-size-adapter-set/
This is very delicious. Never thought of using a 3/8 to 3/8 adapter as an extension, but that would do exactly that and act as a mini extension. Any idea what the overall length is? I might have to get one of these sets. Looking online I couldn't find the dimensions. Do you have this set? It seems like 3/8 to 3/8 adapters are not to common!
I was working on a 2014 Acura TSX brake caliper bracket bolt on the top. I tried a Capri semi-deep but it was to long and interfered with the stud, nut, and cotter pin, for the upper ball joint. A shallow socket would have worked, but I needed a very stubby extension, and the smallest I had was 3 inches lol. I also tried a wobble socket but that was about the same length as the semi-deep and also wouldn't work. So I just gave up and brought out a ratchet. Had I had a impact setup that worked I could have gotten it off faster.
Dick Tracy
Windy City
I was working on a 2014 Acura TSX brake caliper bracket bolt on the top. I tried a Capri semi-deep but it was too long and interfered with the stud, nut, and cotter pin, for the upper ball joint. A shallow socket would have worked, but I needed a very stubby extension, and the smallest I had was 3 inches lol. I also tried a wobble socket but that was about the same length as the semi-deep and also wouldn't work. So I just gave up and brought out a ratchet. Had I had an impact setup that worked I could have gotten it off faster.
Delicious?? Gross…
Y
YoshiMoshi3
Thank you very much. At just over an inch long. I believe we may have found the world's smallest 3/8 extension. I might get one of these sets. My mouth is salvating.
