New mig gun
Rick1754
Backyard
Ihave a millermatic 200 with the original ka-18 gun. I need to replace with a good replacement but not some astronautical price. I do not weld enough for that kind of costs. Which one would y'all recommend. Something middle of the road.
scooby074
Nova Scotia
Make sure you can get consumables. Tips and liners.
That said, most guns where Ive worked were replaced first day the new welder came with Bernards or Tregaskis (same company today) depending on the shop.
strength_and_power
You may want to consider original whip length and get the same. A longer whip can be nice but the drive system may not be up for pushing the extra length. Definitely want to be able to get consumables . If you are friendly with your local welding supply, you may ask if they have any take offs.
BigMike782
Part of the reason I suggested the gun above is that it uses Tweco consumables that are every where.
If I were to guess it is a Tweco Weldskill copy from the look of it.
I run a 15' 300 amp Bernard Centerfire on my Millermatic 252 because I like the Centerfire style. I also have a 25' Tweco(not sure if it's a Classic or a Weldskill), it works but I would not use it long term as it is tough on the drive motor.
NUTTSGT
Northern Central Ohio
I would probably start my search on Cyberweld.com for atleast what is available and pricing.
I've bought a Miller welder, Hobart plasma cutter, Miller helmet and other consumables from them.
LXCam
I replaced my Miller 255 with a 15’ twecko gun last year. I’ve got maybe 30yrs on it with zero issues.
BigMike782
A 15' gun is fine on a 250 amp machine(it most likely came new that way). It's when you put a 15' gun on a 140/180/200/210 amp machine you run the risk of overloading the drive and damaging something......they simply were never engineered to push wire that far.
tarbellb
Oregon
Usaweld.com typically has good options
LWS can **** it, never a good deal. Just company accounts and bend you over pricing.
Only a good option if your company relies on service, and better hope service falls on their limits hours
I would wager a cheap Amazon gun will last 150lbs of wire, long enough for most.
BigMike782
Yup, lump every LWS in one big group. :rolleyes:
BigMike782
Bernard Q guns are all I've used for 20 plus years at work. Ebay used to have deals on them but I haven't checked on them in a while.
389101282464 Here is one. I don't know if these are a Chinese knock off?
It definitely looks like a copy. Trigger is very different and Bernard doesn't do the hook like Tweco.
Just because it's a copy does that mean it's bad.....just sayin.
phred
NC
I just picked up a 15’ Bernard gun. Of course I neglected to grab the tips I need. Looking forward to trying this fun out as the original miller has round miles of wire through it.
