Small gauge wire strippers
dnschmidt
Phoenix, AZ
bwringer
Indianapolis
Steve_P
I have the Klein shown above and also an automatic one recommended here that looks like it came from Fisher Price but works pretty well.
Wamsutta
Amarillo, Texas
The Williams is the same as an Imperial IE-159.
Imperial Tools is the manufacturer and they do a lot of private label stuff for other brands.
I have a pair of Craftsman branded Imperials that I got from Sears before they went out of business.
Imperial makes very nice pliers. You guys might remember Milbar safety wire pliers. Another Imperial made brand.
cbracer
Costa Mesa, CA
good question. I can say from experience they have lasted much longer and I use both types stripping wires for work often. One reason is resistance to corrosion which I experience in my travel tool bag that goes on planes all the time. Every tool gets some rust even inside the pelican travel case with all of my trips. But I still use them in my office in the tool drawer that doesn't travel and they keep sharp longer.
From google likely from the manufacturer:
High-grade stainless steel maintains its structural integrity and sharp edges through thousands of repetitive stripping and cutting cycles without warping or wearing down as fast as softer standard steel
But I posted both stainless and non stainless, but I've had to replace the non stainless once and not yet replaced the stainless one over my 8 years of use. It's easy to see the wear on the non-stainless because the black oxide coating comes off quickly. Then the edge gets dull and that's easy to see when cutting tiny stranded wire.
T
theoldwizard1
SE MI
I bought these and the 16 to 26 AWG blades. I will let you know how well they work.
I just got them and have tried them on a few small gauge wires and ...
I LIKE THEM !
Of course the reason I like them is probably the reason many people will NOT like them ! They are NOT automatic ! This means you need to choose the proper size hole in the die when stripping !
I have NOT received the smaller dies yet so it fails to strip 24AWG.
The one thing I don't like about them is they are quite bulky so they take up a fair mount of room in my tool box drawer.
KnurledNut
n/a
I have a small toolbag set up for electronics, appliances, tool maintenance and other small product repairs.
I replaced two individual strippers with the Klein 1019 as they strip and crimp a wide range of sizes.
I also really like the cushiony grips and the lack of a spring which I often find annoying more than helpful on smaller wires.
https://www.kleintools.com/catalog/...n-kurve-wire-strippercrimpercutter-multi-tool
T
theoldwizard1
SE MI
I actually have 2 sets of the old style Ideal T-strippers (straight handles, no spring) plus the Ideal 30-428 combination stripper, crimper machine screw cutter.
I might retire one set for these !
Kscardsfan
The Little Apple
I have the Klein for residential (normal) wire, and the same basic model with fine gauge wire cut outs instead of the larger ones. Makes it easy to use and muscle memory is nice.
gtae07
Fayetteville, GA
I LIKE THEM !
I have a couple of these between my house and the hangar. They work very well on smaller wire gauges and I much prefer them over pliers-style strippers.
Hakeem
Chicago
I LIKE THEM !
How come you don’t like the automatic ones? I have the HF automatic stripper and it’s been fantastic for me
Torque&Recoil
NE Ohio
No, no, no. I think I have about 8 pairs of wire strippers. The best performing ones do not "look" the best. But they do the best job of stripping small gauge wire. These. Made by Ideal. Trust me on this.
134k
We used Stripmasters in the Navy in my avionics shop and they're still widely used at avionics Depot repair (Navy FRC). They have dies for Tefzel, which says how highly regarded they are for aerospace work. I still have my first set from the 90s still cutting nicely. Ideal also makes the T Stripper which IMHO is a lot more reliable and the current plier styles out there.
moemc
The Tefzel dies make them pretty expensive. I think it was around $250 for my tefzel stripmaster. Works perfect though. In fact, its the only stripers I found that works well on Tefzel. Once you start screwing with aerospace wire you notice that stripper hole diameters are really just taking a shot in the dark until they are made for the exact wire you are stripping. This is probably why different people come up with different opinions on the same model strippers. If they aren't using the same wire, performance will change.
T
theoldwizard1
SE MI
Which cane first ? The chicken or the egg ,?
The Capri 20010 look like a straight knock off of the Stripmaste 45-097 !
cbracer
Costa Mesa, CA
For automatic strippers, I prefer this:
Pinne
I like automatic self adjusting ones for wire that small. They’re consumable, but the cheap ones work fine.
I agree with this. I have some Klein automatic ones and they work perfectly for very small wires.
