Small gauge wire strippers
dnschmidt
Phoenix, AZ
bwringer
Indianapolis
dscheidt
I like automatic self adjusting ones for wire that small. They’re consumable, but the cheap ones work fine.
Steve_P
I have the Klein shown above and also an automatic one recommended here that looks like it came from Fisher Price but works pretty well.
Wamsutta
Amarillo, Texas
The Williams is the same as an Imperial IE-159.
Imperial Tools is the manufacturer and they do a lot of private label stuff for other brands.
I have a pair of Craftsman branded Imperials that I got from Sears before they went out of business.
Imperial makes very nice pliers. You guys might remember Milbar safety wire pliers. Another Imperial made brand.
cbracer
Costa Mesa, CA
good question. I can say from experience they have lasted much longer and I use both types stripping wires for work often. One reason is resistance to corrosion which I experience in my travel tool bag that goes on planes all the time. Every tool gets some rust even inside the pelican travel case with all of my trips. But I still use them in my office in the tool drawer that doesn't travel and they keep sharp longer.
From google likely from the manufacturer:
High-grade stainless steel maintains its structural integrity and sharp edges through thousands of repetitive stripping and cutting cycles without warping or wearing down as fast as softer standard steel
But I posted both stainless and non stainless, but I've had to replace the non stainless once and not yet replaced the stainless one over my 8 years of use. It's easy to see the wear on the non-stainless because the black oxide coating comes off quickly. Then the edge gets dull and that's easy to see when cutting tiny stranded wire.
