The well known chrome discoloration common to Plomb wrenches of the period
Indeed. And for those for whom those electroplating rack marks may not be so well known and who have not seen the thread dedicated to the subject while perusing the A to Z Index of Threads in the Stickie at the top of the forum...
r_olson_06
SD
Hit up an estate sale up in Washington and scored a handful of good bits! I’m excited to see if servicing the 4951 makes it buttery smooth. I sold my last one in my collection reset recently and regretted it.
Nice. Is that a WF-126?
r_olson_06
SD
Found this one in a bucket that contained mostly Model A tools and wrenches marked Ford.
Plomb 3140-S 1-1/4" angled wrench, appears to have a date code but need to remove the paint to be sure. IMG_1673.JPGIMG_1672.JPG
That is what the Plomb catalog calls a Hog Jaw wrench. Not easy to come by. I think they had 4 sizes and that is the most common one by what I have seen. Overall a very great find in the wild. I have only ever seen 5 in my years of collecting.
One of the Plomb items that came with my Ell handle was this WF-38 1/2” drive ratchet missing a screw and the detent piece and spring. The remaining screw was so damaged that I was forced to drill off the head to get it apart. IMG_8954.jpeg
I have spare screws in the Bay Area to get it working again. I have seen a correct size ball bearing used with a spring in place of the missing detent so I may try that. I have a rusty non WF 5449 1940 version of this ratchet so this one may end up being used as a parts donor. IMG_4595.jpegIMG_4596.jpegIMG_4597.jpegIMG_0014.jpeg
I decided to pick up a later WF-38 to use as a donor for the handle posted above. When it arrived it was in good enough condition to clean up and put back together. IMG_9535.jpegIMG_9536.jpegIMG_9537.jpeg
I probably need to stretch out the springs a little as it isn’t staying in its set position in one direction. Here are the two WF-38 ratchets together. IMG_9660.jpeg
r_olson_06
SD
There are so many variants for the WF ratchets. I think @RubiconJK posted some of his a while back.
Fred Knox
Nor Cal
My No. 2411 leatherette roll holding the full allotment of ignition/radio/refrigerator wrenches, all forged, and with two different size openings on each wrench - one at 15° and the other at 60° angles.
3210/3211 pair with 13/64” and 15/64” openings
3215/3216 pair with 7/32” and 1/4” openings
3220/3221 pair with 9/32” and 5/16” openings
3225/3226 pair with 11/32” and 3/8” openings
r_olson_06
SD
Nice Leatherette set!
r_olson_06
SD
Finally joined the Plomb WF-6 club!
Also, a nice 5265 Plomb Tool Co. Proto dual marked 3/8” breaker bar.
USAAF engraved.
With 9/32 WF-8 ratchet.
Nice! What's the back story to it? I have been searching for quite a while for one and this is the 1st one I have seen turn up in about 4-5 years.
MR.X
Funky number on this large early chisel / punch? Long azz extension and a couple other unusual wrenches.
