... And HF has them on sale for $20 right now, through NOV 28th.i was impressed for the price
Question where is the blasting media at in the stores? I have yet to see any
I saw that at that price i might get a few more to use in other places since i have work shop, Barn and garage everyone knows your in one building the tool you need is always in another building or in the other tool box.
In the two stores I go to, it's on the bottom shelf under the casters. If you don't see it, just ask someone. Since they all sell the cabinets, I'm sure most all stores normally carry the media too.Question where is the blasting media at in the stores? I have yet to see any
I purchased yesterday the chrome steel, 3 piece (1/4", 3/8", 1/2" drive) clip socket rail set (item # 01147). The set is made in Taiwan. I paid $2.49 for it.
I gave it a PASS. Each socket rail has 16 clips. The rails do not bend easily. The clips hold sockets securely even when positioning the rails upside down and shaking vigorously.
Dave
With well over 100 pages to surf & too lazy, have any of you tried their racing floor jacks ?
Too bad we can't have a "tool search", on this great thread !
This weekend, this one sells for $80.00
3000 Lb. Capacity Aluminum Racing Jack with LEDs
http://www.harborfreight.com/3000-l...final-day&utm_medium=email&utm_campaign=4710b
Multi-Use Transfer Pump #66418 - PASS
I've used it to siphon gasoline to and from gas tank to jerry cans and it works without a hitch. I put about 3 drops of 3-in-1 oil where the shaft meets the pump housing, pump it a few times to lubcricate and its worked every time I've needed it (about twice a month for the past six months). When done, i was it with regular dishwashing soap and water, then re-oil the pump. And, you can catch it on sale for $7.99...or less.
29 Piece HSS drill bit set, Part number 2642...
Complete and utter FAIL. This set of bits aren't even worthy of the metal box they come in. I've broken every single bit from 1/4" on down...
http://www.harborfreight.com/29-pie...with-3-8-eighth-inch-cutdown-shanks-2642.html
HF drill bits do **** donkey ****
I somewhat disagree; yes most all of their drill bits **** "donkey ****," but these are fantastic. I have had zero issues with them.
http://www.harborfreight.com/29-piece-135-degree-split-point-cobalt-drill-bit-set-36891.html
OK I was going to get that $10 spring compressor from HFT but I decided my life is worth more and got a better tool.. I picked up one from Autozone with the pins.
It also says on the package to make sure the threads have oil on them.. So I guess motor oil is ok?
I just 'borrowed' a set for free from Autozone.
These look like a decent deal:
http://images.harborfreight.com/hftusa/itc/7721/images/159.jpg
Only use synthetic oil on those threads ... kidding, any oil will work.
