Workshop build in Ireland
Anto
Laois, Ireland
Hey lads,
Firstly this is a great site, love it always go onto it to have a quick look but end up loosing hours flicking through posts on it. ive being on the site a good while but dont think i posted anything before, usually just read.
Anyway couldnt take looking at all ye're pads anymore so ive started my garage. its roughly 61' x 32', know its an odd size but i made it to get the best value out of the steel i had.
I intend to do mainly restoration and rally prep in it so mainly sheet metal work and fabrication.
Hope these pics come out as never put up pics before. :headscrat
A
Anto
Laois, Ireland
Hey it worked :bounce:
so i used 8 inch channel for the main structure, 17' 6" rafters and 12' 6" uprights(as you can see i had 30' channel so made shed to suit), 15 deg pitch.
poured 3' foundation all around, with steel and bolted frame to it. actually i bolted the base plates to the ground first then stood up the legs with the help of my thrusty hiab and then welded them in position when everything was plumb.
rickycobra
Nice looking place and I'm very glad to hear that you all occasionally leave the bar. ;) Be sure to update it's interesting to watch how they evolve in time.
A
Anto
Laois, Ireland
Hey thanks for the replies lads, yea im only 25 so its my first shop and first attempt at building a steel structure aswell so im learning as i go along. have being doing a lot of reasearch dough to try get it right first time, will get more pics up during the week. Was trying to get the walls up there the last two weeks but works at a stand still now cause its snowing here, was -10deg celcius last night. think thats 14 deg F in yere language.
bought my first lift for it aswell, 3.5 ton rotary scissors lift im mounting in the floor. hoping to buy a 2 post for it next year.
A
Anto
Laois, Ireland
ha ricky ive being tempted to leave it lately and head to the bar the weathers so cold here at the min. think its the coldest november on record here in ireland now.
little d
NW Oklahoma
Anto, i heard ya all have been gettin pounded over there, where is that global warming they are always talkin about? I helped my little brother build a 40' by 50' on his place, damn that is a nice sized shop! anyway, good start and good luck with it.
A
Anto
Laois, Ireland
scotty, only autocrossing and quarries at the minute lad. was building a house lad so rallying is gone out the window for a few years. will build myself a mk2 dough when time comes. have a road going one at the min with a 2.0 XE in it.
Anyway few more updates for everyone. got footings done up to damp proof coarse. got the road dug out with the help of my uncles mini digger and got broken stone in the road and in the base of the shed.
A
Anto
Laois, Ireland
damn pictures never came out:mad:
A
Anto
Laois, Ireland
a few more pics.
A
Anto
Laois, Ireland
You not been hit with the snow yet?Up to my **** in the white stuff over here!
Great progress:thumbup:
Hey mark yea weve being under snow for the last two weeks now, got nothing done since cause temps are too low to lay blocks. disaster as was ment to be fitting my lift this week.
A
Anto
Laois, Ireland
some snow pics for everyone :) this is how the garage stands at the min, no work has being done in over a week as temps are too low so waiting for weather to warm up a bit to finish blocking then can finish the roof.
A
Anto
Laois, Ireland
a few updated pics, snow finally went away so i got the blocks finished
and got the roof on. got my scissors lift aswell :pimpflash
Bib Overalls
Jonesboro, Arkansas
Just assumed you would use metal on the walls. So I was surprised to see the block work. With the steel framework and block walls it should last forever. Nice work.
willysrule
Herminie, PA
Nice shop!!
I believe I was thru Co. Laois when I was over there...we stayed two nights in Carlow...spent 3.5 weeks in your great country, it's quite a beautiful place!!
quititman
Denver CO
Anto,
Do you have slaves to help? Quite impressive for one man. Your building methods seem so different from the states, it reminds me of my house built in 1903 with the double brick walls. Will you fill the void with insulation, or will the air gap be sufficient?
I see some sort of heater, what is this?
A
Anto
Laois, Ireland
Nice shop!!
Willysrule...... yea you probably did drive through it if you were heading to carlow from dublin or anywhere in the northern half of country, laois is right in the middle.
Bib Overalls... thanks for reply, yea hopefully it will be a lifetime job. all the steel is galvanised aswell so should help things and cavity walls are insulated also.
A
Anto
Laois, Ireland
Anto,
Quititman..... void is partially filled with insulation, its double foil backed insulation stuck to inside leaf of blocks. 4" concrete block on inside, 4" cavity with 80mm insulation stuck to inside leaf and then 4" concrete block on outside leaf aswell tied together with stainless wall ties. pretty standard method of building houses in ireland(and in my opinion the best method)
heres typical drawing......
http://pdf.archiexpo.com/pdf/xtratherm/cavity-wall-uk/62174-53387-_2.html
jam0o0
Katy, TX
wow. that is an awesome way to build a wall. i'm taking notes for my dream shop. thanks for sharing.
A
Anto
Laois, Ireland
Also worth taking note of damp proof membrane on top of footings(in this pic third row of bricks and around windows) to stop rising damp and to keep inner leaf dry.
A
Anto
Laois, Ireland
Anto, Nice space. I like the lift and the skylights too. What car(s) is going to occupy that space?
Thanks for all the replies lads.
Boosted1.... at the min theres no cars in it cause im still building it but here is a few pics of my machine. she's a 1975 ford ****** mk2 i restored with the help of my da. hope you like the pics, i dont think these cars ever made it to the states but there big over here with the rally lads.
A
Anto
Laois, Ireland
And a progress report on the garage, got my lights up in 2 out of the 3 bays. 12 5 foot t8 doubles i think is what ye would call them with prolux bulbs. didnt put up any lights in third bay as i intend to try set up a spray booth and prep room in it and loft it for a milling machine/lathe and storage area(long term)
also got to test the lift with my da's van. :bounce:
e-tek
Saskatoon, SK
Lots of land there!! We're used to seeing postage-stamp-sized places in Europe!! BEst of luck finishing it out - I'll be watching with interest! :)
A
Anto
Laois, Ireland
installed my two post lift aswell with some help form a mate and da, never installed one of these before so was a learning experience but it turned out well.
had to use my own van to test it dough so it was a kind of fingers and toes crossed moment!!!! luckily it was fine and am actually suprised how strong it was. (2 post lift was a chinese lift in comparassion to the rotary scissors lift)
Boosted1
Georgetown, KY
Anto,
Very nice result on your finished garage. Congrats. No those cars didn't make it to the states, but I really like the clean purposeful build of your car. Looks like it would be a blast to rally.
PeteMoore
N.Ireland
And it'll still be ****** cold in winter :p
Nice Mk2 by the way.
Cris B
Lancashire, UK
If you search on you tube there are some videos of Ken Block driving one of those Escorts on a gravel stage. He loved it so much he bought one and had it shipped back to the states. OP - Great car and amazing workshop :) A real achievement!
For those that missed it:
http://speedhunters.com/archive/2010/12/10/car-spotlight-gt-gt-an-******-from-the-future.aspx
A
Anto
Laois, Ireland
Great job. I really like the way houses ( shops) are built in Ireland. I've been in the building trades for most of my life so I'm always interested in different techniques. Ireland is my favorite country next to the U.S. One thing that I really noticed was, there are few wooden buildings in Ireland and all the new house construction I saw had slate roofs and fireplaces. Love the smell of turf burning, So much so that I bought about 150 bricks of it from a guy who imports it not far from me. Burned with wood it pretty much lasted the winter burning only a brick or two at a time.Love that smell, it reminds me of Ireland.
Hi Jack, its gas the way people love the way things are done everywhere else. i would have given anything to have built an american style timber barn with a gambrel style roof. i love yere old barns but you are not allowed build gambrel style roofs in ireland, cant get planning for them.
I actually burn a lot of turf dough :bounce: must get up a few pics for you, will be at it next month now when weather gets better. its gas we take it for granted, could be acres of turf cut where we are. hard to beat it in the winter dough!!
Cris B, yea think ken has one. there a fun car allright, light and rwd!!! great combination :3gears:
Anto,
Boosted1, thanks for the reply. dont actually compete in this one as ive spent too much time on body of it. it does get driven hard dough and have done coarse car for a few rallys with it.
zagamuffin
Cork,Ireland
Anto,
Is that a garage or an Nct center...lol
Fair play,havnt seen a personnal garage with that space in Ireland.....love it
The expensive bit is filling it with toys now
kippieland
Western Washington
Great shop! I also love to see how things are built over there compared to N.America. I would imagine brick construction would perform better with all the rain over there. Maybe less moisture and rot problems. Anyways, looks awesome!
